Poultrygeist
Lunatic Member
With OB's, the "money" driver is the FR's not the woofers. It's the reason MJK used removable baffles to test 5 different full range drivers over his fixed woofers.
OB woofers exist to provide bass augmentation, because what you need and often get can be quite subtle. I expect that may be hard to grasp for those with a subwoofer orientation but no real experience with OB bass.
I've listened to my Beta12LTA's for hours without realizing the plate amps weren't turned on and no bass was coming from the H-frames. Sure I could hear the difference ( fullness/bass weight ) when I switched them on but a lot depends on the type of music that's playing. In my case it's usually small group jazz, a forte of OB's.
I recently discovered that one 100 watt plate amp ( Yung SD100 ) is all I need to drive 4 Alphas with the volume only one click above min. I usually can't see the Alpha's cone move and often touch them to feel their movement - subtle bass that does not draw attention to itself yet natural and alive.
