This turn that the thread has taken is rather curious indeed. In another thread in the General page there was a discussion of why the OP spent $$$ on hi-fi. Of course this was a hot button topic, and the camps came out of the woodwork. One of them being what others refer to as the wallet police, along with the supposedly snobby audiophile who had more money than brains, and the other various factions. And here in this thread I find the same kind of thing happening with this discussion of woofers. Somehow I am not surprised.
I know very little about open baffles, aside form the pair I am listening to now, and some of the planar types of speakers I have heard over the years, that have certain attributes with OB speakers with conventional drivers. But I do know what I hear from my particular set of speakers I bought at the end of last year, and I hear a lot of potential. But speakers are peculiar creatures, and they are far more distinctive than many of the other audio components we have in our systems. So each speaker design is going to have its own particular set of strengths and weaknesses, and therefore will appeal to some people and not others. The attributes of the speaker in question will dictate the configuration of the rest of the system. Unless the owner of said system has strong opinions on what amplification should be, then the speakers must have a certain set of characteristics to be compatible with the amplifier.
And I think that is what is happening in this thread. One particular person is an advocate of low powered tube and chip amplifiers, and that dictates the need for efficient speaker systems. In this case it means full range drivers with higher efficiency, and a woofer system with plate amplifiers to produce the needed SPL to match the higher output drivers. Now if this person were interested in bang for the buck audio, then it means that drivers that are reasonably priced and meets the minimum standards of performance are all that is needed. So we get a recommendation for an affordable driver such as the Eminence Alpha 15. And this position is further bolstered by the writings of others who are well versed in OB design, and it certainly makes sense that this is a good driver for this application. While this thought may not be completely aligned with the teachings of the wallet police, it does seem to be closely affiliated with them.
Yet we have another group that says there is something past the Alpha 15, and to achieve that next level of performance is more expensive, perhaps a bit more complicated, but in the end there are further gains in performance to be had. And they reference the same designer that also used the more affordable driver in his work. Confusing isn't it.
So who is right? What is the truth? All I know is I don't know. As a general rule I tend to avoid the dogmatic stance of my way is the only way....so I would suspect that there are other ways do things other than a full range driver and the Alpha 15's. But that is not to say there is not merit in this combination, and I bet it is very good for the money spent. But I have listened to full range drivers for over a decade, and I understand that they have their own set of strengths and limitations. Seems to be a pattern in audio gear..all gear does some things well and other things not as well. But as designs progress the limitations become smaller, less frequent, and the device is more even keeled across the audio bandwidth. But there is always a but. I have listened to many of the Fostex drivers, Audio Nirvana, Lowther, and what not, and while I found their limitations to be a deal breaker in the long run...I have yet to hear the true upper tier ones like AER. So I cannot say that there is not a full range driver I would like, but at this time I won't spend the money to trial them.
While I do agree that the drivers that cover the music from 50 hertz and on up are the "money drivers", I just think there are many configurations capable of filling this job. Linkwitz uses conventional drivers, SP Technology uses waveguide loaded high efficiency drivers, Hawthorne Speakers horn load an ESS driver with a 10" mid bass driver. So there are a lot of ways of doing this, and each have their own particular strength and weaknesses....and will appeal to some people and not others. But this is the nature of this hobby.
So what does this post mean? Probably not much of anything, especially considering I have limited long term exposure to OB speakers. But I do believe that there is more than one way to design a style of speaker, and more than one way to put together an audio system, and that every one of us has an individual preference of how we want to hear our audio. So the only way to know for sure is to listen to various speaker designs and driver configurations and make up your own mind. Which means you gotta invest some money in these projects and decide where is a good path to follow and a good place to stop. There are no easy answers, and no guru's who can guarantee audio salvation for you, and so you have to be responsible for what you spend your money on and be accountable for what the end result is. Perhaps you get it right the first time, and perhaps not. But audio is a journey, and audio systems are not an appliance like a microwave. You spend some money and enjoy the sounds of what you buy. It is your responsibility to make sure you understand what appeals to you, what brings you satisfaction, and then go on a search for what gear and system confugurations that can bring that about. Well that's how I see it at least.....
Now where did I leave that truffle? Oink snort grunt oink snort sniff sniff sniff.....
Regards
Mister Pig
