parisphoto
I never heard them, but I am familiar w/AR-2ax's.
What's your opinion on the Ar-12's?
I have owned all three of these AR models as well has ar90's and AR3a's (no longer have the AR11's or the 90's) and prefer the AR12 to any other AR speaker I have owned or heard. The only time they fall short is in a very large to massive room (500 sq ft or more) where the 10/11/AR3A/90 may have the edge when it comes to bass repsonse. Sonically IMO they easily outperform the AR3A and AR10 as well as any of the JBLs and HPM's I have owned. That mid range driver in the AR12 is simply outstanding and in my opinion, one of the best ever made. It is truly magical. Too bad and very odd that it was only used in that single speaker model. The 12 just got everything right. You can play Miles Davis, Ted Nugent, Pink Floyd or Bob Marley at any volume and still get the correct experience. I am 62 and have been heavily into quality audio since I was 16 and the AR12's are my "deserted island" speakers hands down
I have a set of 12's, and agree with all the previous comments, they are fantastic.That's very interesting, does the tweeter also use ferrofluid? Is there also a procedure that can be found on how to go about this, whether it be the mid or tweeter?
As a follow up on the AR12's I highly recommend you remove and replace the ferro-fluid on the mid range every 10-15 years as its true performance depends on it. The mid range cone has NO spider mechanism whatsoever and floats in the ferro-fluid providing true linear movement. I can get dried and "gunked up" over time but it is relatively easy to r&r.
I'd also love to know the process for this... I have a set of AR12s and one mid seems slightly sticky.As a follow up on the AR12's I highly recommend you remove and replace the ferro-fluid on the mid range every 10-15 years as its true performance depends on it. The mid range cone has NO spider mechanism whatsoever and floats in the ferro-fluid providing true linear movement. I can get dried and "gunked up" over time but it is relatively easy to r&r.
PICTURES!I'd also love to know the process for this... I have a set of AR12s and one mid seems slightly sticky.
Link to my resto thread, lots of pics.PICTURES!
As far as I can see you never had to actually disassemble the mids and never attempted to redo the ferrofluid?Link to my resto thread, lots of pics.
https://audiokarma.org/forums/index.php?threads/ar-12-restoration-pics.698197/
No, the ferrofluid was good, the dome/VC moved easily and easy to center when replacing the surround.As far as I can see you never had to actually disassemble the mids and never attempted to redo the ferrofluid?
