UPDATE:
With all due respect to Mary Shelly:
IT'S ALIVE!!!! Well, the left channel is anyway....... And with little fanfair, too. It just powered up as if it had done so for years. The output tubes easily biased properly, as did the DC Balance settings of the input stage tubes. The AC Balance is has been left centered at this point. All voltages were either dead on, or so close as to be inconsequential.
The right channel only needs to have the two plate connections on the primary side of the OPT installed, and that's it. Well, almost that's it. Initial testing has put a spotlight on one issue that needs to be addressed (in both channels), and then the right channel will need to have it's output tubes installed, adjusted, and performance checked of course. But assuming nothing untoward comes from that effort, then: that's it.
I felt that with one channel completed, I ought to go ahead and do some initial testing, which at least would then allow for a complete check of the power supply under dynamic conditions. It would also highlight any issues specific to the left channel, or any issues that potentially might affect both channels. It would also let me know just where I am in the ball park with the channel I've got -- whether I'm in it, near it, or nowhere close. Because of the nature of this project and the resulting attention to details it has commanded (wrong chassis making for a 10 lb load in a 5 lb bucket and origin/original build/schematic issues), it ended up being a project that has been every bit as intense as a scratch new build of this amplifier would have been, and maybe even more so given the issues involved. With so much work having been completed then so that one channel could be operational, I thought it best to take stock of finding out just where things are. Obviously of course, there are no sonic observations to report as yet, and I wouldn't want to start those anyway until I was comfortable that the complete unit was operating as intended. So at this point it is very basic lab testing only, which has been enlightening to say the least. With that then, Here is the initial data I've gleaned from the left channel:
Test Conditions: Operating directly from my AC line of 120.5 vac. New generally matched Sylvania 6550 output tubes installed and biased to 52 mA each (ARC specifies 65 mA for each tube, but there's no reason to cook things that hot just yet). DC Balance set as specified. 4Ω load connected between the 4 and 16 Ohm terminals with 4Ω tap representing ground -- this because of ARC's floating Common terminal due to the partially cathode coupled output stage connection. Right channel small signal tubes installed and operating. This does not exactly replicate ARC's test conditions with regards to AC line voltage, output tube quiescent current draw, power supply current draw, and loading conditions, but is close enough for the general testing being done at this point.
Test Equipment: Heath IG-5218 Sine/Square generator, HP 3466A DVM, HP 400EL AC Voltmeter, and Tektronix 475A analog scope.
Modifications Installed:
1. Output tube screen stopper resistors have been changed from 47Ω 2W resistors, to 100Ω 0.25 watt resistors. This has no material effect on measured amplifier performance or its specifications, but provides for improved protection against the formation of any parasitic oscillations in the output stage, and improved circuit protection should an output tube decide to go off the ranch.
2. Output tube cathode sampling resistors have been changed from 1Ω 2W resistors, to 1Ω 0.5 watt resistors. Provides for improved protection under catastrophic output stage failure conditions. Both this change and that in #1 above still allow for the amplifier to develop full sustained rated power output for an indefinite period as might be required.
3. Screen grid regulator pass tube has been changed to a KT120 tube. Provides for original regulator operation as designed for 6550 pass tube, but with higher ratings to allow for full sustained power output in both channels without over dissipation of the pass tube (which clearly happens under those conditions with the 6550 tube originally specified). Because of this change, ZD16 in the cathode circuit of the 12AT7 error amplifier remains at the originally specified 12 volt designation, rather than updating this to the final 15 volt designation that final production units used at this location.
4. Output stage coupling and power supply HF decoupling caps upgraded in voltage rating only as needed so as not to have their ratings exceeded at any time when the amplifier is in operation.
5. Input garbage filter series resistor increased from schematic value by an order of 10X to match other ARC designs and considerations for this filter.
BELOW: Here we go!
Power Output: Maximum power output at 1 kHz at the onset of clipping, was exactly as specified at 110 watts RMS. Granted, this was only with one channel operating, where as the specification is with both channels operating. However, the output tube plate B+ supply only dropped 12 vdc from 0 to maximum power output (425 to 413 vdc), so the addition of the other channel will only have a minor effect if any on these results. Screen grid voltage is of course regulated, which is the most important design point regarding power output specifications.
More specifically, power output across the 20 Hz to 20 kHz audio band is also well met, with the test conditions/power supply comments above also applying here as well. In fact, the amplifier did so well, that other than for the limitations of my analog scope, it's virtually impossible to tell a 100 watt 1 kHz sine wave:
From a 100 watt 20 Hz sine wave:
From a 100 watt 20 kHz sine wave:
This is impressive performance to say the least, where many an output transformer's limitations are on full display at the frequency extremes. Not so here. The transformers are fully capable of the power response specification as given by ARC. No distortion readings as yet, as that won't happen until I can move the unit over to my test bench, which has load resistors capable of the full sustained power output of which this amplifier is capable, and my HP 339A and Heath IM 5248 distortion analyzers. Suffice to say that the wave forms presented here indicate that the amplifier should have little trouble meeting these power output levels within the specified THD limit (<1% at 100 watts), and IMD limit (<0.1% at 1 db below 100 watts equivalent power output).
Frequency & Transient response: And here we hit a hiccup. A 10 kHz square wave into a normal resistive load produced the following results:
What a heart breaker -- until I decided to bridge the input garbage filter series resistor with an appropriate external resistor to effectively bring it's value down to the schematic value of 3.92K. What a difference that makes!:
To produce the specified 5 µsec rise time then (with a 10 kHz square wave), the schematic value of 3.92K is clearly the correct value (and also brings the unit much more in keeping with the specified Input Impedance and Input Sensitivity specifications as well).
While no frequency response information is specified for the D115 MK II, in measured response form, the two different resistor values look like this (Ref: 1 kHz = 0 db @ 1 Watt):
1. At 39.2K:
@10kHz= -0.50db,
@20kHz= -1.80db,
@30kHz= -3.50db,
@40kHz= -5.00db,
@50kHz= -6.30db,
@60kHz= -7.60db. It's pointless to go any further.
2. At 3.92K:
@10kHz= -0.15db,
@20kHz= -0.40db,
@30kHz= -0.80db,
@40kHz= -1.20db,
@50kHz= -1.65 db,
@60kHz= -2.15db,
@70kHz= -2.60db,
@80kHz= -3.10db.
COMMENT: So what does this say of (at least) the D76A and D70 amplifiers that are schematic specified to use the 39.2K series resistor value (the D76A uses different value components to achieve the same effective time constant)? Circuit wise, the D70 is a D115 with two output tubes ripped off from each channel. The input circuitry is equivalently identical. Ergo, if the effect of the resistor is as great as that shown above (which would be audible), it must similarly affect the D70 and D76A as well. Clearly then, there is no way that the D115 can meet its specified rise time, input impedance, or input sensitivity using a 39.2K input series resistor. So, the input jack assemblies will have to be removed again -- and before any listening tests can begin -- so that the original input series resistors can be reinstalled........again........ UGH!!
Transient Stability: Even with the input series resistor bridged down to 3.9K, the stability of the amplifier is nothing short of remarkable. With a cap only load and 10 kHz square wave input, a value of .25 µF across the 16Ω terminals produced about as much fuss as the amplifier would make, which was:
Which is to say hardly any fuss at all.
Equally remarkable is the LF stability as well. When pulsed, the amplifier rises to the occasion of the pulse, and then the scope baseline falls right back to home -- no bounce, no muss, no fuss at all. And it does this
whether there is a load on the amplifier or not!
Now, there is one caveat to the LF stability. If the pulse contains a strong DC component to it such as a pulsed square wave would represent, you can see the pulse momentarily deform the leading edge at the top of the square waveform as the input stages catches up to the new biasing conditions. There is no input coupling cap in the D115, and the output of it's first stage is direct coupled to its succeeding stages. So if the bias hiccups on the input stage, it hiccups on all the succeeding stages as well. Now any good preamp will have an output coupling cap which will prevent this event from occurring. Buuuutttt, the mentality of that day still lingers on with some to this day, so if your preamp's output coupling cap is so large that it can pass the DC component of a spike presented to it long enough to upset the D115's input stage bias, then that super hefty size coupling cap is likely doing you more harm than good, and could be yet another reason that some ARC output tube blow ups were so spectacular.......
Misc: Input sensitivity for 100 watts output came in at 0.61 vac rms, which is spot on for the MK II specifications, while hum and noise measured -90 db below 100 watts
even with no bottom cover or tube cage cover installed.
As remarkable as this all was, there are things to pic at as well. Setting the DC Balance and output tube Bias is in fact the royal pain everybody as claimed it to be. The DC Balance pots are really too big in value, so that you sneeze in the next room, and it will impact the setting. Getting to the bias test points defies any sense of practicality, and then there's the heat. I'll go into these and other comments in more detail later, and there's still a whole bunch of tests to perform, but for now, suffice to say that this puppy appears to have all the goods it claims to.
Another pause while I redo the input jack assemblies and bring the right channel up to speed as time permits.
Dave
