a few oscilloscope snapshots and waveforms.
a rather messy layout, needed a larger variac since beyond 110v mains tends to pop a 5a fuse (500va variac in background).
idle numbers hi-z mode, dc bias around 350mv each channel, 8r speakers connected.
power caps were discharged down to below 1v prior to every inrush measurement. fairly uniform inrush wave.
focusing on first 16ms (60hz) wave to see max stress on startup. poor little 5a variac fuse, never stood a change against that magnitude of inrush.
one rail voltage when amp is fed 120v mains. something to note when comparing to 125v rated filter caps.
idle numbers for lo-z mode, dc bias around 300mv, i should do an inrush scope photo for this mode (forgot to do so) to compare with hi-z.
one rail voltage in lo-z mode.
and this is the odd waveform when measuring in real-time (amp idle, hi-z). bob is doing a lot of weird things under the hood unless this is textbook class-b.
