What's the point??? If you're gonna use a cart that is under 100$, use the phono section of your receiver, the difference isn,t gonna be worth 100$, very negligible in my opinion.
On the other hand, I'd rather have a Dynavector 10X5/receiver phono combo than a Shure MX 97e/dedicated phono pre.
That's just me, I'd rather have a better cartridge than a better phono preamp. After you have upgraded to a high performance cart, go for the dedicated phono. Then it's a worthwhile move.
What's the point??? If you're gonna use a cart that is under 100$, I'd rather have a better cartridge than a better phono preamp. After you have upgraded to a high performance cart, go for the dedicated phono. Then it's a worthwhile move.
Matching the performance of the cartridge and phono stage is the plan I would hope. My Music hall Tracker clearly shows the difference between my Cambridge 540P, the Rega Fono Mini and my receivers phono stage...if a $70 cartridge can show the benefits then imagine what a 10x5 would do...I can I had one.
