pickerng styli
Pickering XV-15 = Stanton 500. The factory stylus carriers looked very different, but any 500 stylus will fit.
I didn't see anyone point out the error in this post. The XV-15 isn't a Stanton 500 -- it's a Stanton 680/681 (you were perhaps thinking of the V-15). The Stanton 500-series stylii will fit onto an XV-15 but won't work (or at least won't work well).
My recommendation for a replacement stylus is:
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=STNS680EES
Or perhaps this one if you'd like a lower-cost option:
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=PICKSXV15625E
The first is marketed as a Stanton 680 stylus; the latter as a Pickering XV-15 stylus. They do look quite different, but either will fit and work in your XV-15.
i just noticed that the stylis isnt a 200 its a d1200 is there a diffrince between the 2
The original Pickering D1200 stylus was a higher-end stylus than the original Pickering D200. Those numbers don't mean much now, however, as you'll be looking at 3rd-party/aftermarket stylii that are not exact copies of the originals. Still, an aftermarket option labeled "D1200" will probably be at least somewhat better than one that they've labeled "D200".
V15= Stanton 500
Phase IV= Stanton 600
XV15= Stanton 680-681
Note: 600 and 680 are different and incompatible. 680 and 681 interchange with each other. Stereohedron II styli the best (their line contact, no longer made, and expensive NOS). When this line was in production there was a very wide range of styli for every need from heavy tracking conical to Stereohedron II and all specialty options any archivist or broadcaster ever desired. The Jico Shibata is the best aftermarket replacement for XV15/681 users.
You were too quick for us.:D
The D1200 tracks at a much lower tracking force (0.5-1.25g) than the D200 (2-4g), and is a higher quality stylus. The Pickering XV-15 1200E was the exact equivalent of the Stanton 681EEE, so it needs a topline 0.2x0.7 mil elliptical stylus, or even better, a Shibata (Pickering D1800). So look for a Pickering D1200 or D1800 stylus, or a Pickering XV-15 1200E or XV-15 1800S or Stanton 681EEE/681EEE-S replacement stylus, and you should be safe that it will be a high quality one. The others have posted some good quality suggestions. The best value Shibata is LPGear's D1800 stylus here http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=PICKSXV151800S , and they also have a lower cost replacement for the D1200 here http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=PICKSXV151200E .
Despite the fact they look quite different, the Pickering XV-15 and Stanton 680/681 styli will both fit the body - the Stanton styli wrap over the top, while the Pickering ones wrap around the sides, but the Stanton ones seem to be more expensive for equivalent quality, so I'd choose the Pickering replacements.
I have an LPGear replacement for my XV-15 as well as an Ed Saunders. You can't go wrong either way in my opinion.
Vinyl Engine has the XV-15s listed as moving magnet cartridges, which would make them Stanton 500s. If that's wrong, someone needs to tell them to fix the cartridge database.
I have the box from a formerly NOS XV-15/150 sitting on my desk, it doesn't say what design is used inside the body.
Yep... the XV-15 is a moving iron cartridge. This is by no means the first time I've encountered erroneous information in VinylEngine's cartridge database... and there seems to be no way to send them corrections.
It's good to know the correct info there. My original post had the XF-15/68x connection, but I edited it after finding the "moving magnet" info in their cartridge database.
