are they connected to different taps? 10k with 150pf on the 16 ohm tap would give near enough to the same feedback level as 4.7k and 250pf on the 4 ohm. Voltage at the 16 ohm tap is double what it is at the 4 ohm, so the resistor is double the size. The caps scale in the opposite way, so double the resistor, half the cap.
and just to toss a wrench in there, 6.8k is about right for a connection on the 8 ohm tap, cap would be about 180 pf, but it could be some either way depending on the specific HF properties of the tap but thats how you'd calculate a starting point.
