Looks pretty good cosmetically. :thmbsp:
Just out of curiosity, what type of work are you anticipating ?
looks like your missing an anti-skate counter weight that sticks out on the left. I have one of these sitting on my dining room table.
check out these picts I got off of the web
http://www.smugmug.com/gallery/715005#31882669_cEpFE
It arrived, dust cover is toast, platter was not removed , it came loose... Oh well.
I can do something with it.:scratch2:
Thanks,
John.![]()
I'm just curious, John. Clearly you've been doing this for quite awhile. Do you give any instructions on packing or do you simply roll the dice and accept whatever you get?
The 115D is indeed a nice table. I had mine at the AK Fest, and it sounded quite good, even versus some of the pricier competition.
I'm in the process of slowly tweaking it. First stop was to spray some undercoating on the underside of the platter. The platter rings like a bell, and the undercoat deadened it up quite a bit.
The weight that sticks out to the left is not an anti-skate counterweight. It is a lateral counterweight designed to distribute weight on the tonearm bearings a bit more evenly. I don't think it ever really made much difference, and while many early S-shaped arms came with the lateral weight, it was dropped on later models. So, removing it (or the fact that its missing on the subject table) shouldn't matter at all.
My next tweak will likely be new cables.
Good luck with it John,
I used a 117 for awhile when I first got back into LP's, and it never let me down.
Thanks,
John.![]()
Thanks,
John.![]()
I see those pictures and can't believe they packed it like that as I said Assholes.
If you buy a TT from FL and the elderly person has NO clue about packing, you really can't blame them. If they take to UPS or USPS they should inform them that, Hey this isn't going to make there in one piece. I am going to make a video explaining how to pack stuff!
Plus it is MORE $$$ for them if they don't have to purchase packing materials.
Good something to do tomorrow..
Thanks,
John.![]()
