Franco989
Member
New guy here, been a lurker for a while but you all seam really knowledgeable, hoping someone can help with my problem below.
The problem that I have is that the reel tape plays way to fast, and only after it has been powered on for a while will the tape play at a normal speed I have already tried some of the suggestions found on this forum including the following below:
o The speed change knob and pot is subject to getting very dirty and can malfunction. You need to spray or clean that speed adjustment control thoroughly. (pitch control)
o The speed problem that is a very common issue with the RT-707 and 701 is in the molex style multi pin connector, facing the machine and on the right side, underneath and upside down under the servo control board. There are 6 wires coming out of the capstan motor. They go to the speed-servo board. Clean the board-plug connector for those six wires. Clean the speed-change switch with Deoxit. If the machine has stood for any time the connections in the switch may be tarnished. Change the state of the speed switch about 20 times. This sliding action may clean them up enough to get any movement out of the capstan motor. A critical thing to make sure of is that if your machine suddenly has speedup problems is to clean the pitch control pot with Deoxit fader lube. The white plastic multi pin connector is often the culprit for the dreaded runaway capstan disorder.
I have also tried Deoxiting every other molex connector I could find, running out of ideas. Thanks in advance for your help.
