jwhitelan
Well - still try the two together as described above.
I doubt you've "done" anything to it to change it's condition.
Ok I will still give this a shot then. I did try the headphones and nothing but silence.
Could be, but that doesn't answer why it HAS been clicking so far.
Work all the switches and knobs back and forth, up/down/in/out as appropriate numerous times to see if you can disldges some gunk for sound to pass.
I have not used anything on the unit other than good ole air from a can and Jet Vac and a dry lint free cloth.
Yeah mine does not have the Junction jumpers. I did however use 2 RCA cords and connected it to each port. I also tried to connect my EQ up to the ports as well and go that route and still nothing. I have ask around to see if anyone know where I could order replacement jumpers but know one has answered that.
I tried that already with an RCA cord. I just removed them for the photo. Here it is with the cable connected.
I'm thinking you mean fig. 21 and 22 on page 23?
Basically - you'll want to connect from the "pre out" of the 9500 to the "power in" of the 9900, and then slide the switch - figure 21. There is probably still the little plastic stopper that you'll have to unscrew a screw to enable you to slide it down on the 9900.
If that works - then the pre-portion is working on the 9500 and the problem is somewhere in the amp section.
IF it doesn't work, then you'll want to reverse course. Hook the pre out from the 9900 into the power in of the 9500...
This will help isolate the issue.
IF it is just a matter of dirty switches / pots, then the later should work.
Did you try headphones yet?
You didn't answer the "clean it" question entirely.
Did you clean the controls with something like deoxit?
If there was 40 years of dust in it, it may just have such dirty controls that it will not play
Thanks for the update. On the Fig it was on the SA-9500II manual. I will give this a try in just a few and see what works.
I also picked up a converter for my beats headphones to see if those work in the SA-9500II. I will test the converter with the beats in the SA-9900 first to make sure it all works.
I wonder if the relay is bad and is the problem.
Everyone thanks for all the great advice and help. I have been deployed for work and will not have access to continue to test until the 22nd. Once I get back I will continue to test.
One newbie question before I have to leave town. Could the relay not click because there are no speakers attached to it? I just realized that is the difference from last time. I had speakers connected to it when I powered it on each time. I moved it to my bench and didn't connect speakers to it.
Shouldn't be a factor. Relay should click without them connected.
Compressed air will not clean your switches and controls.
Hello - I'm kind of the same situation - I hear the click but no power light. and no sound. But before I ask too many questions ,I really should check the fuses and can't find the correct hex driver for the volume knob. Do you know the size of the hex screw in the volume knob? That way I can go to my local ACE hard ware store and be able to access the internal parts of this unit at least check the fuses to start. Then I can follow some of the greatly appreciated post on this subject. Just checking Thank youIt uses the jumpers, make sure they are present and plugged in to bridge the "pre-out/main-in" jacks. If the jumpers aren't there you can use ordinary RCA cables to connect preamp outputs to the main amp inputs. As mentioned above make sure tape monitors and adapter switches are set to source too. If it clicks it ain't DOA, great amp!
I can't find the correct hex driver for the volume knob. Do you know the size of the hex screw in the volume knob? That way I can go to my local ACE hard ware store and be able to access the internal parts of this unit at least check the fuses to start. Then I can follow some of the greatly appreciated post on this subject. Just checking Thank you
Thank you - That works. Now what I have to do is find out why the relay clicks but there is no power light or sound.Hex size is 1.5 mm.
Thank youYou don't need to remove the volume knob on the 9500II to get to the fuses. It has a metal cage with only four screws, two on each side.
I also own this integrated amp and if you are hearing the relay click, then the amp portion is most likely 99.99 percent ok.
I had mine apart recently for a recap and forgot to see how many fuses it has but I know mine were good. I'll have to see if I still have the 9500II schematic on my other computer to see if there is a fuse for the front end.
