Yes there are jumpers in the Main in/Pre out jacks.Could be that the power light is burned out. Does it have jumpers in the Main in / Pre out jacks?
Pull up one side of a fuse to test. Testing the fuses in circuit will just test other things also in line with the fuses.
Since the fuses are soldered in I thought the only way to test them would be in circuit but I guess I could lift one side to see it they are good out of circuit. They are REALLY dusty and I can't really see if the internal wiring of the fuse is all there.
I noticed that the big caps were connected together with braid ,I'll attempt to attach a photo. I didn't do the cap connection,should I remove the braid and replace it with wire? Thank you for this conversation.
