RICK KING
Nonlinear
Hi,
I bought the SA-9500 new in early 1977, but pretty sure it is a 76. I have never serviced it. It sat from about 1990 until last year (2020) when I brought it out to use with my phono system. So was used almost every day for 16 years.
I opened up and did basic cleaning and once pots and such were cleaned, seemed to be in good shape. I have been using it pretty much every day for a year.
Recently, it has begun to pop when turned off, even if volume is off. Also I noticed a few other things:
Grounding did not seem to be effective for my phono as well as my Pioneer SX-626.
Some "bleed through" noise from other inputs (e.g. if I have the tuner playing I can hear it slightly in the next selector device AUX 1). Also, just yesterday, when turned on there is a noise coming out of the left speaker. It goes away within a few seconds.
I did check DC offset and if I did it correctly both channels are around 20 mV.
I checked all connections one-at-a-time. Removed every device from the same circuit; still has pop when turning off.
It may be time for servicing. I am a novice at repair, but have equipment to service it myself, but would need advice from you guys to walk me through it. I have 70 MHz Oscilloscope, several types of multimeters including Auto RMS with frequency, regulated variable power supply, software driven signal generator, soldering iron etc. Just learning to use scope. I have the original service manual and can somewhat read schematics. I ordered a Engineer SS-02 Solder Sucker. I have one, but it does not suck. Haha.
Also, I found here a list of all parts needed if you advised to go that route.
I can give more info, but this is start. Should I start troubleshooting, or assume it needs complete overhaul?
I would really appreciate your help. I am retired from IT, but was not a tech. I have plenty of time to work on this and have several other amps to use while the SA-9500 is down. A 1973 Pioneer SX-626 (Quad) and 1965 Sherwood S-9500, etc.
Cheers!
Rick
Cheers!
Rick
If the protection board doesn't cure the pop, at least it is eliminated from the list, and is already rebuilt.
so listen to him more than me.
, remove some covers to access the power switch. Of course with it NOT plugged in.
