Pioneer SA-9500 : Troubleshooting Noise
@Skywatcher
So you opened a can of worms as they say. Most of my gear/components have no earth ground. (i.e 2 prong). Are they concentric to their own circuit/ground?
They weren't designed to have an Earth ground. It's too easy to create ground loops, especially with house wiring being inconsistent. When you add a ground, you create a 3rd path, the wormhole. :D The Earth is where the worms crawl. :p
Thanks again. I have been learning a lot. Advantage of being retired and having time to read and watch videos most of the day. @merlynski mentioned warmer days; that also entails more yardwork and therefore not as much time for learning. But still a lot compared to a working bloke.
I also have an out shop that is really nice. Came with the house (purchased 5 years ago) and the fellow who owned it was an engineer and built it. He did it right. He wired over 10 circuits and many outlets are on their own circuit. He ran it from a 100amp breaker from the house and is on the same earth ground. [EDIT: I'm not sure if it is on the same earth ground. Need to check that out.] It does have it's own breaker box too. No heat, but does have a window AC. The truth is I haven't been able to use it because when we moved in it got filled with boxes and junk. I intend to remedy that soon.
It looks like Monday to start on the SA-9500 because of honey do's and doing a little work on my mom's house. My wife still works and the weekend is usually busy. I finally heard back from Mouser and they cancelled the order. I don't blame them. I should have ordered the back-ordered items separately.
Lastly, I have no issue getting of topic, when actually it's not. It's about audio and friendship. Life is music.
Cheers!
Rick
Rick,
Do you have the 30th Anniversary Edition of DSOTM that's the "hybrid SACD": https://www.amazon.com/Dark-Side-Moon-30th-Anniversary/dp/B00008CLOA. If so what do you play it on and how does it sound compared to other mixes?
merlyn
Yes. I have that version. I play it on a SONY BDP S590 or a SONY UBP-X800M2. I like the S590 because it has RCA out for stereo SACD. The other is only HDMI, but has great surround sound. Supposedly David Gilmour said it is the best version. Not sure where that came from.
Because SONY (and Philips) developed the SACD, most of their Blu-Ray players will play SACD. It is 5.1 and sounds great, but I am normally not a big fan of Surround sound music. Unless is was recorded in multi-channel as was the case of DSOTM. I think at one show (Wimberley?) they set up a quad system live. There is a YouTube documentary about that concert.
It is not my favorite version but is very, very good. I ripped it in 5.1 DSD format but the SACD sounds better. I think it decodes the DSD better. I personally like DSD over any format. It doesn't feel as choppy as PCM; I guess the 1 bit stream and high kHz. To my knowledge all SACD's are in DSD.
I mentioned above about a YouTube documentary. It may be on YouTube but I watched it on Amazon Prime. Prime has many Pink Floyd documentaries.
After much research that seems to be its strength, and downfall. And that signal cannot be passed through co-axial or optical connections (S/PDIF).
My HT system is a Pioneer VSX-D412, that has analog 5.1 audio inputs.
Do you have any experience with or input on a Sony DVP-NS775V DVD/CD/SACD Player?
Not sure what chip it has but should play fine. There should be settings for DSD and Pure Direct. I believe it has 5.1 RCA outputs. The RCA is what I use for stereo. I may take a look at that Pioneer VSX-D412. It looks nice. I am using a Sony AMP with my 5.1 (7.2)
One of the reasons I picked it (VSX-D412) was because it is rated 100W per channel. No HDMI though, but will handle composite video.
It was cheap from the 'bay, and needed no refurbishment.
I am considering a HT preamp, though, with vintage power amps for audio.
Hi,
Was finally about to start working on replacing the transistors and noticed that one of the parts I received is not similar to the one on the board. The part numbers are what was suggested in the link for AWM-074. Wanted to make sure it is correct before I start. It just looks different. The poles/post are what concerned me. They are flat; not round.
Thanks!
AWM-074: Q6: 2SC945: 512-KSC2383YTA
AWM-074: Q7: 2SC1384: 512-KSC2690AYS
Here is the one I received for 512-KSC2690AYS:
I use analog amps for all my music playing; even though I play my HiRes FLAC & DSD files through a PC and DAC. The DAC has RCA out to my Pioneer SA-9500. I do use HDMI Sony amp/receiver for video. I am mainly a Pioneer guy, but SONY for video. I'm sure there are better, but I don't watch TV and it is for my wife and she is happy because it all works with one remote. Haha.
Rick
Hi,
Thanks!
It's the correct one. :thumbsup: The "S" won't be on the transistor.
Kind of' bored for a bit and thought I would post something (waiting on my wife). It just dawned on me that I have service manuals and owners manuals for most of my stuff; even used components I purchased. I have service & owners manuals for my RT-707, CT-F750, SX-626, CT-S705, even my AKAI X-1800SD, etc.
I have an original, almost pristine service manual for my SA-9500, but I can't find my SA-9500 owners manual that I got with it when purchased new in 1976-7. I looked on the bay and the price is $50+ in poor condition. I guess I will settle for my digital copy from hifiengine.
I'm working on SA 9500 also . My SA 9500 is in great shape and passed the DBT. Upon internal inspection I found the PS to be ailing ,one of 470uf caps was bulging . If I was running a stock SA9500 I would pop the hood and check this. I need to put mine back together and do the relay and big can caps .
Hi @calman46
Thanks for joining our conversation and sharing
My caps looked good with visual inspection. I was concerned about the caps on my RT-707 and was told they rarely go out. I assumed the same was true for the SA-9500, but I guess they are different in use and function. Do bad caps on amp boards lead to weaker right or left channel? I have another amp that has weak right channel. I will work on it next. Most of my Pioneer components are in pretty good shape. My SX-626 which I only use as a pre-amp/tuner has a speaker issue, but the headphones work great.
I was fortunate last year and given two amps, one tuner, two turntables, and four cassette decks. All in need of work. Also some of what I already owned needs works. I have plenty to do.
Cheers!
Rick
P.S. I posted this in another thread on AK:
"Nice to have a place like AK to get feedback on audio repair/restore projects and not try to work alone in a vacuum (pun intended). The input I am getting here in the AK community is invaluable. I'm getting help on repairing my Pioneer SA-9500 in another post and I couldn't have done it without them. Pooling ideas and suggestions is awesome."
Hi,
Ready (again) to install the transistors. @Skywatcher suggested on page 1 that while I was at it to replace the capacitors. Several are not in stock at Digi-Key or Mouser:
AWM-074: C1: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v - NOT IN STOCK [Lead time 21 weeks]
AWM-074: C2: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v - SAME AS ABOVE
AWM-074: C3: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v - NOT IN STOCK [Lead time 21 weeks]
AWM-074: C4: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v - SAME AS ABOVE
AWM-074: C5: 4.7uF 25v CEA: 647-UPW1E4R7MDD 4.7uF 25v - IN STOCK
AWM-074: C6: 100uF 16v CEA: 647-UPW1V101MPD 100uF 35v - NOT IN STOCK [Lead time 21 weeks]
My preference would be to use the Nichicon. Fortunately I have two amps working (Pioneer SX-626 & Sherwood S-9500, also a Sony STR-DH190). Is there Nichicon alternatives? Should I just replace the transistors and hope for the best and move on. I want to do what is best in the long run. What I don't want to do is take it apart, put it back together, take it apart, etc. I have other amp projects as well that I am working on. I am in no rush, but do want it back to use. My favorite amp.
Really, really appreciate you guys helping and respect your advice/opinions.
Cheers!
Rick
Hi,
Cheers!
Rick
You can use any PET type of film cap for the 0.22uf
You can use up to 25v for any 6.3v caps.
You can use 35v or 50v for the 16v and 25v caps.
Other brands such as Rubycon, UCC, Panasonic, Wurth are fine too. I mainly use Panasonic FC if I don't have Nichicon UPW on hand, and all the others as well depending on what and where.
