Unplug the unit from the wall/DBT. Set your meter on the Ohms range. turn on the power switch. Measure across the power plug for resistance. Should be a low resistance, more than 5Ω but not an open circuit.
If you have an open circuit measure resistance from pin 4 to pin 5 of the Surge Killer PCB AWX-098. On later models Pioneer used a different board AWX-108, but it does the same job, same pins. Should measure about 3.3Ω or slightly more.
This is the AWX-098:
This is the AWX-108:
It is next to one of the big main filter caps.
If it is open between pins 4 and 5 measure resistance across the thermal fuse, it should be 0Ω. If it is open you have a bad fuse. Replacements are available.
