Sam Burden
Ok would like opinions on these 3 units. I have all 3 and would like input from others. Pros cons what you like or dislike. Thanks and let the fun begin,
I think they are all heavy, higher powered receivers that pack a lot into one box. For the value of these and the difficulty in moving them, I prefer to get separate components. A 20-pound tuner, 20-preamp and a heavy amp (stereo) or two (mono units). I am missing the Knobs, Switches, Buttons and Dials all packed onto one faceplate and use up more shelves for the rig but it is much more manageable for me. Of course, there are those that love receivers and those three are well liked.
I agree with you on the weight issue the sx-1250 weighs in at a wopping 74 pounds but l still like them anyway. I have not done a sound test yet. I have fully restored the 1250 and the 2325 has been recapped as well as service updates but the Sansui is original and l have not gotten around to recapping it yet so at some point l will do a test with same speakers and same input to see what my thoughts are. Right now they are on shelves and a pia to move out and rewire so it might be a bit before l do it. The sx 1250 came to me with catastrophic right channel failure, outputs blown, resistors burned and open, blown transistors and a few diodes so l ended up doing a full blown rebuild on it. All transistors, diodes and caps replaced and updated/upgraded through out the entire unit using Nichicon FGs and Wimas. Used mostly Fairchild and OnSemi for transistors and diodes.It sounds pretty amazing.
I would value your opinion since you have all 3. Have the units had any work done (restore/refurb/recap whatever...)?I have all 3 and would like input from others.
Are they sounding as good as they can/should?
I'm also moving into separates, the engineers didn't have the same restrictions on size/space/weight...
Thanks for the reply actually its a 2325 not the 2385. I havnt really done comparison tests so to speak yet. Yhe 1250 has been co pletely gone through see a couple of my replys above for what has been done. I like all 3 but still need to test equally to see for comparisons and l think l would like to do a full recapp on the 9090 so it would be refreshed in that dept.Happy days! You have a fine collection. 9090DB is a little under-powered in this company, a better Sansui contender would be the G-9000.
Of the three on your list, I would rank as follows:
1. 2385
2. 9090DB
3. SX-1250
2385 needs no introduction. 9090DB reputation is well earned. SX-1250 is last because SQ is not to my liking. 1250 was tuned for the ultra-bright HPM-100 line so with most other speakers, the 1250 sounds slow ans lifeless.
IMO and IME. For the record, I have owned all three and many other Monsters. All are gone now except for the Concept 16.5.
Will post comments when l do.Curious what you think when you can compare them all.
I have had all three here and have rebuilt all three. The pioneer is the best built by far. I fully rebuilt a 2325 and was pleasantly surprised with the results. It sounded very good.
I preferred my stock 9090DB over 9090's I restored.
Hmm, I didn't comment on the sound of the SX-1250.
Rob
I would be interested in learning your impressions after hearing them connected to the same pair of speakers
As in you didnt like the sound of the 1250? Orl have not done anything with my 9090 l am curious as to what caps you used in the ones you rebuilt. l have another 9090db that l had to repair and completely rebuild the amplifier board as well as replace the outputs. Maybe l will recap it and compare the 2 since l am partly there anyway. l have been using either Nichicon FGs or Elna Silmic ii for my rebuilds and like them both although the Elnas are bigger in physical size than the FGs and in tight spots can be a problem. Also in the one that has been repaired one of the BA312 ics was bad so l replaced both of them with the replacement boards from Sparko Labs so it would be interesting to compare and see.
