Pioneer sx 3700
darren
Hi I got a pioneer sx 3700 for my martin Logan Motion 15. They 5ohms so my question is dose someone know how much power is the sx3700 in to 4ohms
Thanks Darren
Hmm, well the specs from Pioneer do not show what it puts out at 4 ohm sadly, but it does take the 4 ohm speakers per the manual. As you know the 3700 is not a powerhouse, so at 45wpc in 8, I would only imagine it may get to 50wpc....but this is a guess.
If you look at the manual and spec sheets of the major companies such as Pioneer, Marantz, Sansui they usually show the 4 Ohms output to be approximately 20% higher than the 8 Ohm output. so at 45 WPC you may get as much as an additional 10-15 WPC going by the 8 Ohms figure X 20% and added to the original @ 8Ohms 45 WPC gets you to about 55-60 WPC.
( 20% x 45 = 9 - 10 WPC plus 45 WPC equals about 55 WPC in total)
The above formula seems to be the usual amount of difference from 8 - 4 Ohms output wattage totals.
Some manufacturers have different output figures and it depends on how their amplifiers work but using the 20% factor will get you close to the 4 Ohms output amount or at least very close to the true wattage amount for that resistance of speaker load.
Hope that helps you in your search for an answer.
Hermit
