I just rescued a pair of Infinity Reference Standard 1.5 for the price of a Happy Meal.
Again a quite beefy crossover network except for two or three electrolytics that will soon go bye-bye.
Lucky Boy tubed!
Do you have a LCR meter to check the big blue caps with? I was surprised to find that the big can caps in my Q1's were within 5% of spec after all these years.
:guitar:Infinity Kappa 8's
Needed some TLC. I have cleaned them up and refoamed the woofers. Trying to figure out why one of the tweeters does not work but reads an impedance of 3.6 ohms. Also, can't get an impdeance reading at the posts but they play lovely music.
Very nice! Just brought a pair home yesterday needing some tlc. Will cost me a tune up on a buddy`s Aprilia.
What amp are you using. Thinking of using my GFP-565/GFA-555II to at least try out.
GFA555II are exactly what you need to try a set of 8 Kappa if the amps are in proper condition. You really lucked out in that respect. The Adcom will handle the heavy load with the toggle in back of the 8s set to "extended". I have a set of 555II I use on a couple of sets of 8 Kappa when it's all set up to play. I believe the consensus is that the 555II sound a bit grainy in the top and there are better sounding amps, but whatever someone uses has to be able to drive the amp killing load of the 8 Kappa.
Dunno if you realize it but your Polydomes are dead. Time to set up an email search on eBay. Get ready to shell out 2-3 hundred USD for a decent set to replace them. You probably should check the integrity of the foam on the woofers before you crank them too. Great speakers when they're working properly.
Aragon 4004 Mark II. The bass is amazing.
My Modulus system. Satellites/Sub/stands/crossover. Bought new back when I thought I had money for this type of thing before my kiddo was born.
Just love this setup!
