davstev
Well-Known Member
I have a dial pointer on the T-101 that is burnt out. This may be the same as the T-100, i am not sure. The bulb needs to be replaced. Has anyone done this? I can't figure out how to get the bulb out; it's nestled inside the pointer assembly itself, which is like a long narrow box, and there are two wires that come out of the assembly. The service manual doesn't help at all. See attached pics, the bulb is inside the narrow black box called the "pointer assembly", which is somehow attached at ninety degrees to the gold-coloured horizontal triangle slider bit.
