One thing I should mention on LED bulbs is that the absolute "home run" LED upgrade is in refrigerator bulbs. The standard bulbs in many older refrigerators are small (A15) 25-watt incandescent bulbs. The downsides of these bulbs is they are fairly dim, run very very hot (working directly against the refrigerator's cooling with 3 hot bulbs), and the color temp is 2700k (which is great in normal lighting, but is not the best color for refrigerator illumination).
The 60-watt equivalent and even 100-watt equivalent LED bulbs are much, much brighter, run cool so they don't work against the cooling, and the "daylight" color makes even old refrigerators look new.
It is transformational in lighting quality, color, and efficiency (double benefit -- uses 1/4th the energy of the incandescents, and doesn't heat the refrigerator).
Your wife will thank you, and/or you'll thank yourself, after the upgrade.
60-watt eq: https://www.homedepot.com/p/EcoSmar...t-Bulb-Bright-White-3-Pack-FG-03220/308706275
100-watt eq: https://www.homedepot.com/p/EcoSmar...Light-Bulb-Daylight-3-Pack-FG-04208/316021875
