Project: Pioneer SX-1010
Super Noob
Project Pioneer: SX-1010
In my neverending quest for 70s silver face bliss, the adventure continues.
There was a post in BT for a somewhat local unloved Pioneer SX-1010 with more than a few operational & cosmetic issues. This was my first purchase off BT since my status was updated to subscriber more than a year ago.
@reardonp6 = thanks Pat.
27np1PxcYQr0sCO36PYq0_1T_XEEB6cv0tbJbPGE4Xf_XcH0yWqIGaGUDgKNsrCYXjwKsYAHZWrFNCRmO-XumaTKJrVuzY94EQylUgfEaFSUuW0YgCTk3iRoLrGXxfVBycJtRfDF9A=w800-h600-no
As you may know, have much love for all things 70s stereo related, and this was a chance to get into a unit that was arguably the first shot fired in the 70s power war. With 100 watts per channel at 20 Hz @ 8 Ohm - the SX-1010 was a game changer for sure.
M6nmWXwgvRVHErmUS0_0EmIkLEVRn_eTvY58m9hCcQlOsZ4fWP1bDXcpvwM5u2KfvKVwCvvxgfkndJJ3UTDC1jTI8UOwWJKt-mYRMCQ3aJH1shpetr1Myz2tgn3uJN1_xM0Ox62TXA=w620-h827-no
The birth year of the SX-1010 coincides with mine = 1974. My patient though was a very late production unit with a serial number of "VL" = December 1975. It has some nuances that are untypical of the early models.
Over the last three years or so, I have rebuilt so many units but have always found the Pioneer equipment had exceptional build quality and always responded great to recaps / rebuilds. SX-1250 (2), SX-950 (1), SX-850 (1), SX-750 (1), and SX-727 (1). The SX-727 was a lower wattage unit that showed me early Pioneer gear (prior to the SX-xx50 line) were worthwhile. In fact many folks here - in the know - feel that the SX-1010 is one of the best sounding Pioneers ever built.
The patient was in non-functioning state with front glass busted, no top cover, missing knobs and switch covers, busted power toggle, speaker switch 'A' non-functioning. I would consider my 1010 a "barn find" with some light corrosion and definitely a basket case; however, I do enjoy testing my limited skills and patience that non-working units present.
My boy Issac - @ivandezande - hooked me up with a top cover and some knobs. Thanks Dude!
yx0jij5P8sLiIU-xaVxfaKeqKJaY-G86Hkey7pE_7sHps_WL4g_3TBrl1adhmSXSYPJWZzYxzBo2HrYGpUvuOJr4henu5RnFTnaAJ3JMDFaUkY8kh42IZur0Hv5q0fFGAANmcVeFGzWoZR1qA9qzDoa5NWfKV9tnrTu1d3CZqgaECd9Z6vEmCNMzbQpija3ef4sEPqO_Xzh15NNibYLqWiL19BH6YnbSeimHgRsrFCIBsbNddkSo1lkwVq8JVRU-isd4X3QWba45wb9V1hjvKARQHxHSLTjYTan3bZRztNbYi8u05cGtOstLbVJ2PE63EClzFLjEB2x-QPMNqrtY9zso2S6KFTcaSjcPB4AiasFHi0CvCXwRAF8-PWNGnAsdSCzMVfXskPQ6bMCAmybilHjYUMjjEEYMerBK6M4Rp8NlMXj9UonDLRc99JGcLCzYySosAcxGG0JmO7PLUBG_-sIA1iljIOujp-y35NsexOi82PeUiK5flHnVqvotMjMaFlglZ9ArxtMxp3NdcS--4qytMMRc2Dy67JsTPxiZW3uGsKIWuIdm2WhnKz3ozUlBXk6sx4TbalwwXt4aMUqUbInZk-ti5ZASTDCIVuhpi5EOwCq99l923pkEQSUuTpSeX4HZfDEvdusTvVbvTPYkVtQBCkBMg2h7VffsF05x9cTfhjBZTwAU34DWqW3ton3Xmm1CA4UK0XOd53SmYglwddppP0e76HUQQf3L_u5_dNkirucK9bC8OA=w645-h860-no
oj1sUqFKL2g5CHtxbeiUUScXR5oHOaHXSKinCE4IS3DygWsOJhF8jr9wUZeVkjpAObXBRyah_3p3jzpfAOeoC2GpIs_7LqtEWoWtTbQragyIvdu2OynsrqA0Ot4_vK8TVTzsVcN7NrCaBa_dQAQOh852aXMdBtGWlI5m2T281CdhRBXvGlaLPTa8qV451eOpidjL4E5ye4QbHNHMe8RaWu97nBwnIo5ORd6Ti4cdTRCm05CjdBt3UkTPoB65m4-2z5jiBs2QZssZFO2WccMPBBXiVhHMCxjXLPW1EMdPSXngF-urjp_ODMOk_9rbRHumpGKXROs8mTPhHxvp7L-FQ3TAAq-2m6CefJOaV3LgHx41Swqdfl5A_YhbaxC0ZAPokum5hJHbyaoQjYojznTOqnV7BteCa6b4Qx4B_9hnEUbuG4mQ11OD4BYibnAQXpMrvAni8s7WNnpsK0bLU61gDb5I25LytlqqbXe1YsA4OffVqdUEkcLZvxmJbyhq2cQfqVjTl4u-Hp-mtFIYU3yAMgpGv9hqUfQR8h85YVHRMWLvxRy-N78iUHZRLvS7Ojti1ZGcCIIHQnnTp4oVmoD1KE8o0DPC7Ne0Rg4gEGT0EVESKTpvQwPYK1yRzWhugGQJEBJTkdQpq5iNmeHpxIroYMSu4q5_3gqRrU356wTR5_wqCLdEGsHy_e2CRcKqUV_K8CkxWRl2lriLU7-A82DICbpQbVedVvEZONoWCgaJx28D4TYdgxko9A=w645-h860-no
The following posts will breakdown my rebuild that occurred over the past few months. Hope you enjoy and are inspired to be safe and tackle a build in the future. Most of the lists utilize the work previously done by @markthefixer @EchoWars & @zebulon1 @kevzep @larryderouin @mattsd. These folks are inspiring and extremely charitable with their years of knowledge = thanks.
Power Supply Assembly (AWM-54)
Capacitors:
C8 470 uF 80v Electro, 470 uF 100v UPW2A471MHD
C9 470 uF 80v Electro, 470 uF 100v UPW2A471MHD
C10 100 uF 63v Electro, 100 uF 63v UPW1J101MPD1TD
C11 100 uF 63v Electro,100 uF 63v UPW1J101MPD1TD
C12 100 uF 35v Electro,100 uF 35v UPW1V101MPD
C13 100 uF 35v Electro,100 uF 35v UPW1V101MPD
C14 47 uF 50v Electro,47 uF 50v UPW1H470MED
C18 1000 uF 35v Electro ,1000 uF 50v UPW1H102MHD
C19 220 uF 16v Electro, 220 uF 25v UPW1E221MPD
C20 2200 uF 10v Electro, 2200 uF 16v UPW1C222MHD
C21 2200 uF 10v Electro, 2200 uF 16v UPW1C222MHD
Transistors:
Q1 2SD313, MJE15032G
Q2 2SC869, KSC2383YTA
Q3 2SC869, KSC2383YTA
Q4 2SB507, MJE15033G
Q5 2SA628A,KSA1013YBU
Q6 2SA628A,KSA1013YBU
Q7 2SD313, MJE15032G
Q8 2SC1384,KSC2690AYS
Diodes:
D1 SIB01-04, 1A / 400V, EGP20G (2A)
D2 SIB01-04, 1A / 400V, EGP20G (2A)
D3 SIB01-04 ,1A / 400V, EGP20G (2A)
D4 SIB01-04, 1A / 400V, EGP20G (2A)
D5 1S1885, 14004G
D6 1S1885, 14004G
D7 1S1885, 14004G
D8 WZ-320, 33V, 1/2 Watt, BZX55833
D9 WZ-320, 33V, 1/2 Watt BZX55833
D10 WZ-140, 14V, 1/2 Watt 1N5244B
Heat Sinks:
Avid, 507302B00000G, Qty 6
jpBQpr_sUqUOjO5T8vYIrXiEYgJRveHYe-oRIJeeByacJYHWRuoqNiNS4ioIfDyKJYKg2nLb1xdKghtZFM3_nvTm6SeE1YX5hEpQPVbR42mwywpqS3tY3cAa9FrhHV0-KtOX8ukRGTrPjWlLX8KG33f5mL-0WHZSp_ao4hEj4xdI803bu8Iwd2fM42d78bF3QtczhpVy3x0UO_nBZ5YzOIGQYLG5ly1X8PhXIAAjOEb4e4yAZCSytVyDLz9m0O0rq1tZNZp8B9vQ45pqnhwr1QVxpUpSnPOlmBMkYd4A_I8XB9dXbmNDDhkhSiNBq4YVBVQQW7grVS5kQbmg-i9fZPdOrkNuRogW1Z9iZACYdHLFs-CaAsis7SBnT0Je8SCbKWUurKRlfpP7g-x9Rw97yDiI6cm5z81gew4m48rLx-lgx7-xw9LKTorLZvkDf-tWduNVzJrOxg1QNeWft-lUw9eJ9uYJ60JixPD6wLjuP6IJOKRP2CSG8lFIgwE_uZAtcaVmoZLZsNr8zgBxSuD0GgtyRIDtn8ER4ji4AYrnpTweAMMMD0tSl2yKvripoAuw7maPAl1qRIrdMUSkz43QPkeOU5UdOBoDJTlRbPvGTzK6sbCv5YQS-1_PkvGZZCpC3RidZVhRtDzyh-tsKJI1W_O3f5ode_GNYb5_x0U0ho_y4Jx1w62WrXwGahEN-Z3olgVg0fS063FGsCyNcionVxh-xyNN_xYSaMIuA89jeg5dcjK-v5PzYg=w814-h802-no
Pmt_SHWC8IH4OdbDtaPQOLpvZhWsk6hU8yyhQq_4k8Xb0NR3SIUfhNGiAD9bYNOQAvIniL-ieL5aIsbar4ywNa8Kya4RZJ9TJ4-_btyfyF3wZr7SCiR4kwygc-mNUntSBnut4AU96GvqRjX6BGLmcgxRYInDeIwgaOBq6S7T7A_G8eu07_T_5s2sbrIejkq1YvyU1bE-wLQdS_xClZgsQLRXpSAsfLQx_LyslPuCqf-KPCXb8bjCgTLVcUau4irKg2HkPA-SW6B-2W5AFfBnGs8LNhxacN8ZfmmfYM7AI8MynFOIxYVa5De9uefQWWZ0rh6YEyyzD1L7gCKSkUSrPHuEWdnBRumIE0niZmF-ymVboxzhcUFDcg6hGRGSBuUchkTgCnJKI5XzGDBKIu3wNqNTcaoLMazm18MHvmxaYoTlpwAyBiZEy7WTAVbkLnmdq2XnZaKerOLghji1hyFZYIjaxNnVD-IaLo97-dDG6R5l3BycqzN45BmKpcooqUCcjfAH7q-4lu7rKu-LgTPhKoDiREIZMy38qtit0mWjX1f5NhykuEIQkPIiCiiAnR-eWL9wX8zckPEl6EMcSqYzYQ25bFKyiz98MJyAPboxrik6yeBs5k2MrWpCgBTvasAORAtdqBs5k47VK_8vYb_ifjZ5K9Q9gimsQHb0wgS8zjknQlp2HbqzOMdCXLHKWXVSPzL-RFWSD8gfNre7MS8o2wOWmt_mSYJk1Q9gWGeBMEaCtTPdSs9ErQ=w797-h410-no
3YONiMKwSQs9wBkcg5h61-ptrPxLbAWpQC7l77UHbl1rnqwXBzxhPYUMynM7iSroOq9bp_x7XIiHMXz5WQnjsNZX97QFBAGnJXw7EKaAyyiC9AqPUtymPjktANtHFs8iQ8UYZOCXMBP8r77kXjHE3HEy0qh_DFAfWy4GtEM59xNmUMHMb7mo8kYiIXvYt1rIkN0gX_tVuOTmt7fzwr0_jeLYgfKo2xH_FdJ0VzwCIobb9liriLys8JPhr-SqZm5nuAJobUuDCxbRM157Z0o-4kBxLgAVAUrasZRuud5DxVU80Rz16LfsOKovBkxw9ZIDatSpVweDcimQvv63Yn70AiINug8Xfs92_BQsWOTLwhgDBlncfEaIA03ljlrJW32TwWewIfux0x4GQ7bTtFz6pLjynniNEgXJQlr_grYd-Ubz1oKKWveFqXJPHZ2qaZX4nQ8ZeEc6IVnEKoZmP17igLGCtM7y4dy5rHDK_DwRDVaX9kH-T9NHUvzCCz5ptTYI41BWpK5zXtIwjWIIlPbFnaCV7QooZuKjG4Va6ej4d7oqMYbQnUf2_Vux1Lyv8GNvGOo5o0-LWttpRhAAEpoadsBpAps5IU35nJWcfyWREDTib3e0HY4Ik_WYYrfmj508RF8iXjTTEWj0mFj6j6iBuC1TFHFQgxw41PVnZeLWfWaXo4KYhxUOtcG6Ek8AiP15c71njKLLQyZEycPMpf_UgDvJKOq099TN6JbLfluJRaWm9K1uW3R_Ww=w410-h495-no
Found some things amiss with caps, one of the transistors toasted, some traces were compromised.
l41dH6pZDl1sav6v4lcYx_BLTvCKuc-Wst7clmhXXnCL6ZEfii-d9QjvddTyrh0jlRbkT5pIVedBxcimIyTbEbC7crJ80ybtQhFXgP4Ru7uuN-fTB1k9aslkR-dsrgwtGGC3CH_pKLIejd6a0IfIpEtyl1sUojlhE-4S2cVLV4d9lhoA-4WoV_Ab4s2-1ofDcbwrWemTjk2BHD6YARP13s4Xf777vpcQt8jv3K7hiWKRzH5mJLIl1DXhORIUYjj79PGowHHS7kFSii-BLXlywF3-YJQN-tpQOzgwpHG-Glx7lWWDFhj1f3XwhlMSeRQ3rOCPLEpIezNc-qenoIi0PzfqTFGWMSCn-4MIrTL9ccKHJ5j0lCzZDjl-Km0ewuHkPsHnoZ9IHR-7r_fcO9-kS-Fs0tP5hU54592-LdjR2sX7T59oOAjVEl82UORL0j_Iq96MZQr-pd_D6WXFFWS6LLGsuPTvAtZO9nOrIC31E1WEd_FVkZIMVx6dYOClT54IHT65U7fmxN0yyaSqkNwLrBEnLQxeS67bD-oll8hdbpPzf-xF16vv9yOZqgbwjo0a03zbgG9KOgzUxKMLMlNvr2QJzR4Ml9sY-n23pUIfGwL4wp_L7fDDIEyu8e5fvGt_vQC7AQ22YHYZtAmx_KNwJ1sQNfVqfkOZw5gxfS0MmRoAtfcX-6_vnVNlrL_k2P0ryT5kHhWNYAuxW5UgcjIGPi7Pokn6cADuqhRcaTZRjx9RP7647T0vTQ=w645-h860-no
pOThyQu_S5B0zmXSIWTSwRfLGzEGVrTyfHY6nWvvkjKWfzhG3NGlGdUMqah028QljpSUCf-ALODURSRoPzg3qG8ikRfagS0gHI1ckXAQ27eN59LVqGoH0HZb4IACM6-lBjVO1zKv2goLIx7bfbROyRLHbbf4P6HDDagYbfpXmKPbdszppiuaZnqCsrtODlQ2d58xnFgAccBN4Mr2x1nr52EaCDkskfcCLjV6O5yoCEz7CUDyRRGV7dl4UKQF_oH3cfckwe3hhOA0g8y9-dKAIsi1-6jtprK4s7sEs2Tf5OFMZgZAcClqMrs3Z58Y9bK5NS97vFLfV-1S5bCcTamsfU8Gwn7n3v0D6pQjoXVPLFnyDG8hFnSAETEnXI35jZ_l-Rqn7ePlbkfMrm33FkroHGu5ov4NYI6MLI1_-q2GWiuPH2RQTWlnIKdK_SaO34gUBc24zHtAC8C_gnj8Zr2ZGrhxJvVHeb8Ofp9lOrvgICkmv2Qy5nMtoRUhygt-5VNFmzwaLVomnKh-S-FjtRKBHJdjnoUtsfc6qQAYcCE_3aw4P8HQNt7u17sOGCbEtjMh6k-Oz8pQWfUn_0ypZDjfDLYfyPG9xZG4AtOJMonyJdh5ZO3r5AR-eYkp-jk7medGnAlTUCwlEjawBG7iKPAo67zW8FfxzKBguToNJtrfv4lCZWX13g5fQ8VLCyMpAetY2ACT1d_n6-mKp3nBnPnV0iIFfZLiJW6kYsfdadUoHcVWccYif1CXIQ=w645-h860-no
2VW2Wjk1MIRmGjLKko-aFIzl7UxdJbeCHHWmZRaSF11nVLajuvN76AJCHWuw5IZgNjVqHgzPnIvXD16iNdO5d8Xqh8n8GbmqYqKs4d6WJ1IFkTmAhcjpicqUIHIjoS8kgeosB0ihfKMwtIy1K7wgfN7gpouRZYrUXscB3f3GG6nd7MkAm2-xaCmWy3c0_vF6E_GE2HVA8AteR9Ed--OnviIMxBALIoxt-dJjPzYc7levLqnFnInlYA8vpJyFFnrzvzd3EcQiv-ZjdSs5p_HQbFcKQa_8i20p9ge30XSy2IdFqRkBF8yQtdIJrMnJCwATrmBnTUtTUTfgQNpMkmrwTORAvaaSkolsga_NTLJg_0qHyNACNmli0eyMMmmITlea4ddXrTs2PNRj5tI5v1oHQSUHe8gcwnVF1Se-op6bppdvhcQo5ZXRQ5_UaMuOTidxxhCgWeeeJ1Jhf75CDUcJ46LAw6FxGQWd6dyM-JeQGxQSx2GKTXNmVQhC636qyaxZMeKPBPFSp39l8EwwHu9JbENXihy8Fq7B7BS9mNUIg1XuLpr1_7zpBO3pjHB3gBd14IeyAc947secC89kxm8XNJtSEDN4rPShjmYMX6_IOGwBYYT86qEpe-7y430V3MdUwSJ-AfneibD0kWGr5tYV5K21rkAO2HI5atdwtnFrimLA8oBCPNzKnxRecR3mBwpmEWOcUJbByV5Ta1IFSaAamBKXb4tPu5jZ6AxuhxnUphqtM7cwqHq3OQ=w645-h860-no
Xfmx2Ml5HmycTDbXUXOQrt4t15AbM2z6tLDWb1cS1fAOzvjLNKJALwRtmMMs3GKJ0Au2-57xPhdNHaJZvmrzoknQXlksl-477E_ALuLnhK0XBQ45GaMKrt5RWyzTSsw4VVT3gPBhr99b4iJUjvOd_U79nqmcf4DqqOHfv0znkOitSx_QsKnsW3Njxac2FtZ5VNxuMSn1n2tzbeROQO0l_HhZgyctmFokSaUru9Ozt5p2nKHC2e-TnmUG5cDzL7F7R4b6BJKBl64RezgEy38LH5_1CBh_GkAvRosbVqKk8-cGpCsBuLrnxInAin-1LeleRUqFlVCtKq_wYgSZCqnqHhLqexLnZ18unOFbBYHrTtNMKzumqK11mLYD3gmneg4LYcDAelpsK0ShCm3sdzxen8xee3XIk3lPP_KfXaaTZ9PLHN7ThwfpABV7HLHKWElV7aaqVFkw-fxBkp1SkrMMuTsqdUgOZnPAUtE6NE-m5pZEPtfpxf2kq2l3YcucbdEa_wZ9IqfvgzIRoS3sWU_Hx5vOrH0wAavzivAi7fID-iHWz3A-4OXMqljqDACjVXawcIRXwvcY9bWySKMWOQFVdF_OJa6iZTxE1l4EnYtic8LO6Ydr42Uj3qbO53NjntatfdDNrSKkSzGS9Sk7pQPRAZzOapItu5cnN6wGDeFCmiUROQBA-69LR46ld7L33qw_C2gBeEVQSeX2KH-ydqGJWIQFEDQ4-Xl-NdfVPWgQSmiAqoxbJ38Ctg=w645-h860-no
gUOQMdm-FPb32zZTsgrKtKapvb7ewZRejTPsBIGBSBEt9GXhAntSrbR_9UoVVl6SQrCSdjvsewzhfwZWoCUrBWLbxPmJGodZmiIA5eKOK7blWOxCgEHwQsVigdQO1GpTTebS8ziPEC4WwsSb_FJQZFEDk7A8tKkDVEX72igUkb8RAie4OXb4vBJ2LHVQ0s0opw23y3gRkPZghh3Wj2664DPZ0h8Mts_A-u9qJGsSQT2GLz3_Vmf2L5CM6bNjBIzdR99gedgni42aAEOip-J0cTT_wxcqPjSVzSqVWjBeGrVGyL0gORA-2Gq8lZ1Lw8TnoUlnzCkuVsMdbl7kI9Prxl05kTuVr22qQ72KwCtB-M-bJFQmoXH28LXelyckCdT9gaPYqU-UXRrBs6ds7LxmcCzzIaGjsGofZDcl7O42cvNUjXV63F-Hi9_0whc1cx0nqvMIvA9-rFZwFtHz6z6NaW3OCBbO-8MIcVoK5I3ixnCceNAtylIfhycUsIZuW4HylrB1waw8fcTCalJ8lSt7e7EpjKv1BMEGm4EY3JgJaVVumlbBtTf2461Kn6ogQ-_3szZ-kNbYOD7pug1hTXarb3z87zzShBDmQ9XNxznaMsFIZQXXNptFjCCAbZG4datxmOz-lWli7ONsTn7xd8QbJJpbqrFkdnt7V7WnLDzpfqzUJHbbuQhX0SKYnVv60k_GUrGZxzxmHg0GAG9oe5w57dNgiuwCQ8QEN-whqe80E10Nck356dAtWg=w645-h860-no
ANUXfYfKpdS9u9PteVv5r40B0Q6ut1iXSJi54XkTvxZZn6ojUR1mVZPG8UTqw9FOcUdt_k63g3CHUFeivbk2HqM2krlgYevAhM-ueCeVsitt24jirWrDYtXhahZoe6lyMl7aXUstqdcvwfqc_yyHe89EzNt3v_IRzemb-H41lalmtw0Ux-OqKj-EWMNBC8VTJPe2IPh78SIqDPMmi4AV1dqiQS-AQyo9ya_VPTexyZA7ZJCyNVi-7zyfN0_N19Sz0qJsuAB2aeXW1XGjRP3gUTAi_4ylPa77rEOYt2lUX95vM8KHf5LMo-1BVjItUWudA0iNeA0-TsfX8mzQaIV8L1sUxqzXk4foMYwM5OyHS_jmJ-AjWZfPGIUqcENWCPsawQ87PnIzXudbO9pquDMcFiuIH0oQ2PhuX5BjI-Fq81Ili2mt_HuiFeKoC1G22kbubJSZhwq9D3sFup-_-oqdhUvMf2zM9MPyVxgBQ1m7XuQVYOYa0WSOnFp3OmU6xr5o20b_dsxJXkl3wn2S05HgMd7ZWNNZyBq3F8Z1GmKfQnt5nZ7zbAE8z0RGfji8MLOo2L5VjYI9iXkd8Wh5I5jMyxYbQ0u-G0thJioZohZXPK6yB4LXbbXqkvi8uODLAb3ZZwDB4dld3uFC8FZQuOGmb2F6cQ_84mpYLvDoKuGAuJSv3QXaHXeXE_iuM3gzr7JoAcP0Erz_EG49zBYNA-y0eJjNUjSKJ6_Dy_4LKaGo4LwtmCfUi6Uing=w645-h860-no
sAoU2Luzn9BBRKWB-psKjiI9sqSVSFXxrluC4lEELBCXwtEc-4A9mkI6c_P3JshiXVFJj6OiGFAjtiGjnFEzByg9n5Rz09_BKnZ7v6izdXOKQtPIr3zQ0oKd6S7d3VzcZX4v55eeMS9ISYRqgkoYJbCDaLJsuvMPKy30rf0e1XVUiprH5iFJ_UJunUwwA6NXdMUYjn5qP1Tb0ukXA6E-5L9pnFcndlCLu49MeBpRR5hOZNJsdwIKLSijHqYTv9-1-nBGJw-1mWt7QHdQWzM41Suhgipuch0MtIyVghvDJiEHDjxVhOahSMXQpkEzUqmkFvrc9t8ddAWhRrmR24LL25b6lP-aNl-4zuhx87VVFe-rshxqjkaG1Ra6NmCJu4bb-5ymWde7t5qcS4Al9NVMrKqeORQMz-h1-guW164u2pDGn5Hb5Yf6S-3Z2m_C39cW4fij0NkVzGdpuZXEmHwFHDX7XBnoRKW2Pww6c9JK4_tGosmisb8HXqIF262785Qff0-Zn_HJ7EBhmRoRgOnjYuTfvH7XIp_Tq9cYvyGRZYY09wBRlUgERRcMWBxm7h2Fh4JeokTNWO0LwHDMlhZPwj1HXl8buJ7bziBvUPE7DJroV6YHLPNYlPQy_VOY3XOXGuOolKS4-c6h731wD6Pa979I0Js_-BJ-Gctqco1_nAJj6cAmrET0xJX9UADJ0xqQ_H0ogcE4XATmUdH59tZpq4Ic_wp6tH0U3-7gBVbiUacAJTnesg5A4Q=w645-h860-no
Fbn8EPi5x_PO2-o0Lay5GB0Qvfdok1DWwWvCJu3VFZUKL5NRe9aYLsVHTyU2sq-FtsCqUDU-KCDabi4I7LLoC1exo9XgG6NAthw9zpWkevj5vRThZE6xZ7tdp7MZgRmIeyIPiI2gT1XKmQujwvEJ6cAUV4o78e8-Ru1oNKtfE68HaEQy_0L1J99jzb12-_Gu815xJjSn8p6_GPBWL47kcdOJ61e9emXCm9Pacw_PU00nHS14EUySdRDnaHADKY2JrzsX96WQpV9-BSLRCB8ACWneFjfzT1wFenofUeV-BRG_t_ydy-0iezEQ5YGcRylTU-v2ivZG4o3fBW9-EShW_w79CifUfyouskGbr1fwkUkjCt0kYpAdtIGKQP4DhvsKVDKVaL34-OgfEky-Y4EWxK1k2qdQB5s45NXu5SuTtU2XIlHiSAjZ7D7ew_pwEmDTtjm75IITHdzzvbMssO0ee0E-lfM12u3raBrLwsWPXLzoAIy7agva9e9Y7i8b-yQK6bqVn4cOnAJSACpYXujC9OZO17bmrnB1DGSkQyXGl38sqpQp6BR_d4cPFFM7FKZdYjTU1ULGpQQPLK-D6Ajoz0Fh9_Ud4cAXfgPNh4DA9oVG_NdXbtw7LV3E5BbhWvXgwC2YH0NqemeAlo8HeLb0ZhMblr5JPwSQ2R24_mLhYmVdZVzKrxGuPJmqV_0ZGaY1xZrumhirVlI31bmWh5gdZ9AsdJhKrmrl4JrPUOyRMabVupYDUtFaUw=w645-h860-no
4XwahuROoMnZ28KIBkIsB7RC6eJvNwFG4Tlr_f4YbZSKPsPrRG0oIIlxAPUogSlLEo63wUvooFwXUcMXJE9_vxL-X69SCeJIxllbpRezpH8kmBnY46CpY0C6xW_BlXyeFbODn37b29DNcF2rf3B6ihRL3RFdP13n90d9SFhT6n5TSFVzsKCAohE043mfDcQFyGC1z8_kPbOf5EZF3VI3TxNEBabjCzDlZEGYcJp51G77mbycGGCVax5iJeuzz7qx9TuShZBvq5k6zWWaAxanqynnUxkQbpizQ65Ed2wCHEByjRT-uxTfrU3HPsAwfYUz1lzUG_cJH-SlzQwd8xoCm-JHNzlrW3HQQrWnLiRzViJI-7w2I59DCLF873rlWtTqsifS4DQ4ldYdHY2Ify0_s2LnB5F2Sv_WnQMQORl9i8juSZ9keFSe9OBK70pOoM2ddRI1kN4rFr7SGRfKpRovtm7NoEBCPc2TQfMhpxrfC54CnVApSx_wKcABJDbiM1W-uRnKl_AKgsI9ire9TIOn-KXdEjHAkA1eyLGNqyLVLX-8NUv17631hTPsypiRAyrFewqdwaZAMfkzQY4jaZoN-asINgDJjGQkMCaRnhIp7xxJeid5eqq5fq1vjNI2LqN6wfG_0mswAbyqF3aVtSIznWJuZXManJ756kMAhY4zs2-Z8a9ZQcjSLYVNJejGvQ3Yywkt30Sb1SUMoZXdf-XLSvH5NBmDFNeIG_QCvYCvNZeo-1jDAZqB1g=w645-h860-no
For some reason - like all builds I do, am missing a good exclusive shot of the finished power supply.
B9HvTmlwroQsFrpV2fhIfzadp5hiqohiPLDvKslqvly55wNWpPJ-5tC_7VJQmLgtSt6-LB8XVEn6kZmE391KMPDhTPlYN5lceCqGk6cEm7sSaNteqryOMpvrrYIVLpfic0TXG8X-l5CE1m4y1lo4lPUEtz5Gu5C1WDzTiSD_oDgKE4hDSuzZ5zCIDIY5NilrSf4qzd9M-XoWDgGLE9pSDk5H3HSfjrIAvQB9Fh2rl1HEZ0glLGIIt-UAf_9PiDZo5CCMSy5kyzV-VsmPBtAWAQNr__xjFhUpYMdFvGZ7ZdtZlBHL41kAffb8Bt-dCOkTUsc6UOPPm8VpBoZ9-iuK_sfProWGW1Kxv6VihLv8QDpkYxAte8SElqrKRtnImWC8sQxPLNwx5Gm6qKFy-QSbhVR-xASNcCnowK1T3LuQ-Hm1wbUEglNtSipVnziZUAGidtjMP2YtPBSSn1zVEexNmZRrueSnGP0R5jT1z4U4hasBUMzLnw6CUp_zWQH7Rq_EaA2YwC0MHmOoLQYUNQ0oAlvZL4suzs7KxTMFsL1zLaf3libB8OeaD4c-JdQtHfOZWxhOBraiw8Q1IZyh6LcDNIAPJObEyJ3qXAS2b6fYHBoMV_ql74AQCwqRGthiRQfH7gaTUhzqLRvumtpk0GARMzWr9K1MdubXCfOkpM3eOQaFKuzhllig9XbK9Q-IRrkhL6k3PiBi3I0vDcHmNFixlEzS40cY7RGJIK0hnQAJpvgpgjDXLAp2dQ=w225-h330-no
Protection Board (AWH-62)
Capacitors:
C1, 0.22 uF, 10v, Electro (CSSA), 0.22 uF, 100v, MKS2D032201C00KI00
C2, 0.22 uF, 10v, Electro (CSSA), 0.22 uF , 100v , MKS2D032201C00KI00
C3, 330 uF, 6.3v, Electro (CEA), 330 uF, 16v, UPW1C331MPD
C4, 330 uF, 6.3v, Electro (CEA), 330 uF, 16v, UPW1C331MPD
C5, 4.7 uF, 25v, Electro (CEA), 4.7 uF, 63v, MKS2C044701M00JO00
C6, 100 uF, 16v, Electro (CEA),100 uF, 25v, UPW1E101MED
Transistors:
Q1, 2SC869, KSC1845
Q2, 2SC869, KSC1845
Q3,2SC945, KSD1616A
Q4, 2SC945, KSD1616A
Q5,, 2SC733, KSA733CLTA
Q6, 2SC945,KSC2383YTA
Q7, 2SC1384, KSC2690AYS
Diodes:
D1, 1S2472, 1N4148
D2, 1S2472, 1N4148
D3, 1S2472, 1N4148
D4, 1S2472, 1N4148
D5, 1S2472, 1N4148
D6, 1S2473, 1N4148
D7, 1S2473, 1N4148
D8, 1S2473, 1N4148
1N4004 flyback diode is added between pins 9 (anode +) and 10 (cathode -)
cg7nXOJlU0oZkJsEFMQY26GzzO0pjmj7ywwd76kjtO-RaQs5vifBRNhFTUMwYR8pF9VHTqDki7FZsVLXRxNLFCBk_XfOtOM5kb55x_-Aj-xCO1QKHkJybIu2eypfdq_ODo3XpfTUW0qr8SkAI9-y4Co_dssJlKQ-4NYvjf9jzIm89UTN7bGP5ZeDydcpbypzGVlZkFXBESwN62Q8-SXfQBWzjbFkNAjE2ZeqvnexMZBreYu32m7vC5mce44l6VDGBop6BZmZiUU2aTgecEtbU3nUK3xNOMzqQIXrn-RgrO7P3He8-oePcJimPkl8VwjVCOSazFXO0TWypN6WW4CPAhnfZ9jN8TMf5_qEK2AZLPA5QCveO1_U2Zu4zFoWaf399p6IM6jsMEwyTD4sbTIDzXC3WDv-tmyaYamaKi4pjtVkOwb6QvNZ59-lYrI9A7YzyNYVGnAMghMGiJphgJL4GoMAZV-kdho0vDwqf169ariclPDpnJE8H_yrcdJP5pZgg6MxaEtGrVKKTBwJes8AkX6J5CeQdRu2ylgkSxX71-AGLcJw-FV50hGSP0Z20f3lTGp6CuPxpSHq-OljrNuB0quJZRl3SeyKSqMrSE0dzrNZSoJvtePPNW36DIST9wmPxo6164FsF1i7XHBvHaQSFc3irThcLz6D8kXpTJ79JcHHreRd2HjxigoeGul0LP66kOS8LeiHV5ejzxGQTDOtQuQ4lON3YlFVS6gSP5iYiHayy68HpyMvxw=w1067-h589-no
tNJm8v1WFHFVWQApFHcuBCBdhvJMn49rHJrQs77uM2OhZLmmasnXzdE8bDEzNLLIZ4oNcYDbKvws9zgzW6yScNYlH9SqY8BzmTzn5vJe3ox_qFqe0cv9eHduRSErpYMq3oo443DjJLJCTa_HZJNtOM6NYAAhrcKlcKZc_bEYXEEB-PDA7DtLXwK0O1F9fPOXejdTcoaIW4uPYZ76KWKR8j8KnVi02rMBtjkPD_rDtcY805sLuBmjS19tYZEQLzgaoU9P_uNnSt3PA_SouNdglsy_OncJ81DVR8LXdRC9PhrNymC_xypU--cBxNug9x6iH-7RBfzDjt2g-uNiqnbI9KXUe4amiYaBPfb52j9vKFYw8a61uFEfQsRiguRlGKdTcPIFQQjGrnu_9ifpKcZN8V686bnlTERudJJj_vPnrmI9Pc45fID72JTPMNybtUrWQYycTgzZdW8qSeFAFzp2d-KXqpSwONWtBeMvISz75HFRDXN48OqzTMHSP5cTZtdl3_YTEvgBCwXX2VyRHuZLpMpW1ZGFj_p_rmEgfSsnvLdrbvRl2ocpKFymPVMDBFMGwlpV8aVZWzSUGBNLdlLLE05z3XlRX4P5F37UscrJ6zU_X4yNpAcLkyZeROkE--s_R1vtKvCn4c7w4uToDBstsFJLzPbPRkZkDi50zMIeyhOzDaPsFoTCHUQcLsE19HHn8fIN5aBCq6D3iGOi0rOFLtGnxKXh4BKhrLsHVfL_HfOJl2tsKhkJzw=w923-h694-no
oGqcZouuCkFc9golYjsvQnCQBehJsTa7Ok68jo5y-IceIk26eTiFfRmTbeoeBx5Ogv_hM9GaAzFBlGNfE-SdUuBEEHfHFdBZI1QRDBhDMZrRMe5CsyN0__rJrhkChT6MQB34RfLHkrhSGwunyokxNJP9VHXfsTwPNeptCCeWKUQ_QZUlWXu6VGufYI5--YJloZnbS38qLpOupvZ_QZ86X6AEi9odChVLT6tLg1ujpEagYpfq1h-ZcFm3nCsavpnyYUknYMN6QXiUdNMR7YrdNJCwq204nSgPYpA2jN04TkRfnyVDlr2-_GxjrLFTorqA02Nl1rGp5G4N9aAm8PsDxk_-YTygN1TMYzhVcZfGOwDqzQkDHKLBFD8NtF5vwkP0pHNg1AVR0EmZLpuYAzeNT5ZYgO3O8cJ0pS2xZrunz2wCk-jDRXV4XhedcBXgv0WLIncwy_oZl_-fQ0xnsoT46svCMBILbhEE-hBoJADY0n4yxwO52N0aMoG5OgO4x3Lk7GkjukTAo65xn1AxK-rBFjzwnoACXOeb3hihZ-cStJDR-Pq278RXMS0_fvdP80-GXmLt30J0rFezbT7EqyKHSukdNNzl71sVxrrjrNW3eq3A0FEBmW9YqU8dFanD6lhGccVxPLG6NFrGpj3ED7nQcNsddz_GODqt7RvnWSDxblWbLnZpU3epIVBPORgukkLu9btQDOOFt7xB5SQxPMRYSp-Vko1Pe_NpdB695KNs7jbw0yrjPl1qVQ=w413-h516-no
Bz0oYrqiWc0hJkUmiap-wVuK_w86tpnrYCt_ELhzLhe98bmKtYTBA1QWl42cUljY4EQtPIxi-705hBCQUGxq8l8nIyK7xEEDi6Hvjka1GfPjegfD7GGlpR7hYKg4oJXFQJ3UjklI_i90Rxvnb2CjWRvecn6-i69ojep-2TGGms7ittUszdXJXR6GajyRrWPjjYu_9gXKGIs95o00FP05CLt6YZ13jC4hp3rFRapeSgWzMbj60PJUvXmIy9cS_XLY86dXOKXmqX7EgItb9vxvghuAejPQ-O2FDXKlRXEHAhs8427j7ggL3k4_ZmvyFmgooXeSNLUA_cVoOlP6gNBwF4Rxcjz-E0OzA6IEkXoDqkNnqs5F_9OMNptCYFZs2nxXFDqYtx37kb21yhLm50-_74t1E4Ti6Zo0KrT6DEgMeHbpi9dAsZ6RgokP7QRwGDASkABsK2L_Aw10asFzJaR_DnXj4aGqLxqlrV6hjaMh9iMU8W4SqNPUP4eaM_nG3pu0eaOlTNjfPppfL1Regp-7Gf-yXO6VxSq8c2Dv5U0RGqUFD6zPmyr6TzCBDs7rX6Yi4UkuN62vWSY28WVg6ALGx_2seYF4Xixq06V8vYcx7kB1bawNSazhe2GcxVdBBnAEvFEQjzwfa10Ebkf7iqz0hwRKkEz_ukneSUU0THjmApo1En_9eH_PMsf7ZHLqSYdpSzRnkHm3SY7MxqiZkQrUnGIrGkGPpRper-USpqdv73gFrUKwgSLQ3w=w645-h860-no
rwoe6C0iVOoQlR78D_4AP4Lan_YHjd6cLXlf2o4qJoE7IgR1AeGbNUs8iFqsYFrYE3A3xjOYKM2mad-PeYqqtjqrDemMAZTJXTxNtmGGLtkcbaDvuBoeh5IrFy5hRY0SsgBF70iElq6aVCOPFCrS2amBX85cPj_0uFqROXVwmlgiQ-WGtS9b7Jgj7Np4yxIKRJ8oLDf3Ducxj2wMrf9WC15Y2ZIhNo1r8rmUTo36xGCk0erV-P5wdcLCAYthYS16A2_8v2RP4eztZTe-TqQ82cosUWHXf8EEvVkNIazCakTjMdCk5Pa0fOR3h0o1JTG2L8mZVFLn54pt9k61L6ScakACJJYAiCvvXfJ_fh4GGoQGislXElRV1QaJW0McWhLbVk-lEscn-h4psaBBn1IkH1t5xsMxQTqIk1G8ALS85OgLY-beA-FLJO33v5QxboGNByBFwxW-OzGzSqDLu0OIb_eBcOUOoo2j209I5ggHBryFRCkYQNUPhRegRXtebOr9olGGaPYC5LHb9MCo9e__MAplT3nfiRjkaAQDj5vDwgK8L3qf2hTBe7RWdzHZmI1NHbsJoO8tAlgJlxAcBW524yUXw77K2c8fGEsrwF6icarkwIXENqfS289vYZENfIyzD6FjhJacaN09qghltgd0DSVfbW4o78Qwjvm9_Nu9eb5B3JFLZeg2RElRrgn4hn8EFy5H0rRSmgS5g8Dq-BYWC2-F8awvAIFWg3h-CtGcBGe1t4WfsBPyQA=w645-h860-no
KZFpu_F1dMjakZckoUoXQAiroi_wIrNkStwtkzCnZwdl4xVO9zVbXwpZrd98iSX8azCab7EBB6ytpskOVX3s-DITPo6GdaNvoEAPl2mwFMV84Nf3_ApcL3OeXJ6OS3CSChfjVZ9w0-RhA8c0i-K1JeX3O2Z3XjjN12R5Dwxa2veQ6LUzJ0uuT7DHfc5uppwt5M8WeB2aohh2zKWzbHRKZwXSrwgYJIKCTf0svRSz8IV40ZvfpFR9zJuodbdP29mu_AKebkQcibncJlNwhJIUf5FYS_oyl0skWd1yUkW-854Yr4VKMF265K-DvS3uTliP9ftvA325hY3OFUxOUG9PjTiq4JeKXZdtHZ75ZIKFrhkWb1OthN23dfk3vY9JxhJLm4IZsOvcnOBiV5KiRsxjZ0yLwiNKYd40XTViHSWbyANHEseZF-hVdiPYCk2TBGCDGAqAeIr8J_pZ_9VWbKh0q4egv99awDrzfLPyPjKmkqbBDHEzNaYTMX8tDmiAx56tUz6RNYimnPrcZFr2GNKm2BxCdtpO6JXzxbg3aBTN4YiMi11BoiaqkYp8jiHwM6GUe31j_QJSSCSmGscoP8XqZk1mPY1Na9xgalNC5SGuc3D1cEFq5XNmaUy-ni7suau2GKFrZe9Qu1DZCGJXJIEE00YjMY71Wh9PNT99GOCITRko92Sp-F8bjB6QU9lwyiHGggDBiOYcfFIxng6JjU5f__sBWi1ATl5Hv3JSTIHWOrCNqbJI-Hj_nQ=w645-h860-no
sYV0J6HwASnwNX7nOKncZuPuzP85UV5CKRT9cl9BJS5ELJ1utmsos_OVCFxVycXzn7_XrPFj7hqLaS2kgfitoRkMLWAX18SrvO-3yj7Tj8gAG8oNyHLdO_pQzYzcIZcbIfLdX0cqybAzNjUGLalMacrakL9CYmEfoZXSISvd7ElNS6B1AWoSJOiv430e0nYfxySDpV5hovk3N4fBN1YmS_DXtiNN1xhxL0E-Vmu5c-HTiIiUD9zYNLDjh9oi8V-kqZj5r_gRMtA9k6XSw17zhZ7oIA3lnoPIVQ8MmFMtM-iSm1nvaP2HEN1xmqgAD6j1tcLxBdxywih7sYhM_ibtQIp2pBtegbKKUAlHHrkfWXNBnnKfjPzb6zPZPVMajuhQP92Ttb5r-rGOVTME1jZE2Ul1nzkUP3x8U1lKf72DK-lc1xm1Bikjk1zfUf4Djqq_0N-ZYQ5hubQj1zzxGRDrBbrHe6uQ3D0V4Bq_MKGZ3b_dbjrMxAiZKW4ZlLZichjHlEqo1DlMgjHTIrRcGkgxM02C4mx0HFI3WU24eOTxt4XklU-UjbOhC_kmhHV1OJPofgxrHQXQ6RrAN8iADs2xywHwD4JJ4YUOHcqvf7inx32PO_uYIWAJVDq2Al3oaQa0Pr_AneXtYVmgpY-d6t6__1SFa7xZ8FTBVNJ83s1Dixwrt0DlqWHFg_KhfZdP0JuVPs4yBlCoAykgPch-3z05gdUqoaG_NQzZlIchkNFgxvT8h9dlP2ydrw=w645-h860-no
Relay and Main Filters:
At this point.... am getting good measurements. Am able to set bias and offset = but still in protection / no relay click? 1st picture will show the issue.
Relay (1) LY2F-DC24
Qty (4) FM2110-3005-SS (4.5mm od 3mm x 0.5 thread 15mm male female stainless steel)
Main Filters Capacitors:
Qty (2), 18000 uF, 63v, Electro, 50mm x 90 mm, 22000 uF, 63v, ALS30A223KE063 Kemet, 51mm x 82mm
Qty (2), 2.2 uF, 450V, Polypropylene, Bypass Caps, ECW-FE2W225J
Recently Tried Kemet Large Filters = was impressed and now try to use - specs are impressive (would have upped the voltage slightly, but unavailable above 63v with Kemet)
sR50eFdAKvmTPcI8ewqzUgYtOuruqYXX-yXJUJTbVM_Z7Lff8jY6HrxB_B4xmAYfDB8ThSrmKVW9iUyu5-7-zVe8msbNXtM2AX8GiSBJ2arPsMgOSZ0IzZu7OXdPS7S_VRvkmp8zmknTnVyrhpWI4EEimOaHNVo41UOq9KlJLnF4fLQ-j5slK3fBf5TRBv2dE9obM0dEFl-SUM6MGSdPRfwOvUMVp7Oy-W1Z-Tll69vbphYuouxP2Opiq6g1LyeV4_X__qmqDJfEH0JcrX9Am5wQ5-e5kGoueSX-s1K-yChBNI7Jg5D8YaQiOP14MjrbDWZqilCYaeTK94nvFUj2pVPZeTA0kgfY_78g_dUuiO44l2LBi2pI3IwhpkX8IXNmEgMr8jducjoHSblyu26W_GEfR9SHaLnMwadM__X9k1cJ4pFHEZWKXP0DT9cqi6X9TbFPk4H6R8JR-Jwz3lF5u0mOYDzZcorvA3DGZtGb4w6xsio_clGSVjfW6CyAoOK43Y8Q6yztyyZKpfY9LOiM4upodLG-QCyA0Upc6i6JHnZaM_vLTbHemYYWrUQmMktEw2jyLmgPEhcISmK_C7hljyPK19bTnEmDP7peiBKD4PV8idqK_Ig5RI-X_vjqLAAxvdFvHRNhgkkwc2PAcLdnlBvi7bM1ezNLG5TAV7cjpFB9pjcTIuP7OrtANJAW8U4GXj86W6EjoQFZhrU0SzPQsNbE8BGoK4imMCmpgcLl5i4O444JegIasg=w645-h860-no
wMv1QGITdff-2S1ikcN1BTjsXCdASqp2Z3p4HLzLxate9YnE7AGQ1Gh-QnUrdsud7RR5xWnKToJhFJwUhnvVOgRPN3-5qr5CH50DQPl-rHobWmb1aHsN-nxrbrH8Ec_BC05VC0pdmWxDcKvmtmb69NBUwEQimhQJHkYa2NFZac2JgeIQoEWuRjWGByKJvFpPU6l35sBi73jNq6bGSloHiwr2AnpaBM_2B3diysPzgs_828489iWzlRlSw5V2cCSVQ3w8kdcpKuYoUWySglqIiQHNlC8hmcpGEKTdqF0vJXHtF5hreULFDezZ4BgSckyIpoRYRafphL8hzZ3ikv_AySCVhdz6gV0jga6WL4PUW3zwJQBdsNV9RbUb1WWZbMq_fo6G8txkn86qnPr1OsOYrZP6U141rwFELLGiKx2aE-SuztBSlVfIxFwut0i82Ifn0WKsUYQ047HfpU4Mx-LPtQpAogpTgrPyWdNbCLrUPF2ePu2HUCqEXCkNUCbiSacz0d5hKxGLSN8eyvriS7pE1xa1JFu5_E0ENi24qWOBhBQFNDsteHeyNwjlBARNEmiX1rjmKIiJ4W-GTZjXL8nZs2aY3k2ye14hP_Pzeb3fyjgmbcij_iQkk5uCpNOq81PbP_zk9Bl2nwzfUSFGwXBQBRgyfluF44uQefOnuVqdh2xuhshhvojfjpLSh-iBOIoFWzKaXOPx-ljzPv5eiFpii72JAXqUiWKmwX0ExNMqE2bYqpDXgfe07w=w645-h860-no
AFdkhAZB7EcRxFimW2XJX4FiEexIvk1VMo6knp52VpLIVNcl704NsUs_wWcYSOWRH80PpkjXisoz6LEymJzKGY7QyIk-wiogHkVFOFFVyOMeLe9i7PZitI0NsBevfnFvxvodNPkAbRWSHR7or1EVk7pNSX-Bi03sXEfPE-jctO4bdYXASzrPauiX_oBTrhA1DC6pttyolhx940nC4ygks4-HKEmnbngkEdBdQiTkIiuAlTEFtQ2S7tA68p4xhetiYTbuTSfb-HKVNJ-dkVhdjUo3SFo2wtHd5P3nl9beKkcf8h-50d3lu-8uAPxC4hv91-6IlqenFfb6vI2rzaxBxIEbMwn3bNOApYUoNWX7xhwMsMeBBOObQh8TaGWwWhco46b9XkQHtuV075IpfD8IOjW0nLKrjwxvSIXh9vv1m2LXW8U6FEoeRvCCFoa46lWRdpugdJgFrV1y53LofibgaMlwUB0O2UI3ogVGNeZEbV9JrbfVrT9lKIfHWyfyNc6dLYiB99yx94oZHvqjjI6xq6CxfHdTOEwicUjdITC3TXVdoBVCK5nS2yZp0H33AoBnkiCESdF9NWxYGksNZqTbdOBGJhjxV2hJMcehpoZqNoiPQIJ9YcoaOS0FvrQ3xipNmiUtpsgDjG3s5Dqd1XS7Xgf8cUJh2HzmzrJ-PwTr8x3GVfE2sqhOQ_M5Qsvmcs18ZLwQolOA_g8o9ufWgisoAydbphdi3jTl7QGKMCiopveDGNLVNitzlw=w645-h860-no
3SvBTsoCUduXQSTxXFXCcwuYJMOQmGEysAcs2_eChYDBAkgS6j5ujz1ZpiAtWFrKwXqLoJWD-sSbcqty7uT8w60R_jXqckVZ44i-1UpCRNGsul4avp1L8COrY0qW6RIFlDBVKGUEAO7YTWksfRTQX74PK3iKLNoi9yun-T_MRdCtZjMl-_ricwBRDZV9jrrhL8FGM3VsHD_ibICClL8-q4ZJnYifXlX73gnVoRDBJEMnQlJPSmuMWA9dmlxWbPrmTTysZSiOGyuD4iBYXC4cD5GEebW26Q_5dORLgwRgPt-pe9PSZXy_LAfOGLHY8mtKLk3JYouf0tPg_21Eq4ZH_W_H4zEIE2jI10twFYTN3ZR_MUyFi8Avdf9I6eOfaH5GHSe-lYWQiX40ZfFnDS3RJInix97NwdRMOiKF0etCs-cUvfcS8Yy1u0AWM7TIViDJN0N-ET2dAKszWS-H1PnVznCdhgg_5zAanNUJSkF3RJusr0ledm16lsYWanIvgOeISbdZwIp2_o6ojnwC307yRxP4Hi3_glf5aubJuToux21uPFjhjVV0NHbgIBRij_UqskQzBLTCQPrdvlPjiPOMgl0YMjb5RXd54NCiRILGR7uNpWRWvCfBwXvref91k2S9UOH0BCzGEmIe9bpFZE1NKcjLzy0yvfRhBvqkWIskL71-4CdcD9ukbBrAn3TMr0fv1zVTWiWhxGuI7sLTnLu4BDAwEC_DGLThamrMQATB0SmWwFNO3G4HUg=w645-h860-no
-e4Ze4_sN_W06MYBmLgZrmXNbt4NBl2r5cmIkeEXRvfJt77q-R-dONBzrHcMY8zUiGCm-Ysl4qyeBWCFEFsXj6mcj0yjZrfzTtuGE3Q4TXTNFrK6VhBJJU0Zythrz1vXCGSaitSWDmldB4tONe2khh4JPBq05JNRQ4p6E7W2QQgOtM02pGK0sbDgo9q6mJAfhw875xnPoLn2TSPItLNn3Ge_QD4rVdHXsf8BuyoTbLqjzvyPIdjYLdnoxZSlOw4q_BT7Guxmslj-hEj1o3NvOvGZKcgga7ZPGAqkxGYpx0sgmvjeKgYx2i6u-7DoXAc5riCm2pVn1wmeIRLRbWqhZa5ZzxTZfaw2zVFyqbEvsBIxC2KL3_ZevMI91RWcjiWuaFro9mgXaxXvcUccN14mk7Xc4ldcN6_CqnVY0RTog1ApFZTD5BdymQar_ZdJFvYvzGdGp9P3FWYSXI2kjnVtt-4EetdKmhRbHo9FY5HNWBAbulGvAJVacxxrroN5SNFr6xxc_3WHbvT9LOFZ1jmcbwCFgLLsiT6l3YMMrvUTTUR__BvAOdaNHxSz17Cb8NSwwUIx0uhzPC6xe1Pjmigb_X_WWpklfCVjkSEYgubr8Mzvd10KUbWeHMCxTv3Q2jUqjZ2vjSeiDMGln5mge3vVXEgTpcjobGSsTq2SxB0ppXlDrWcb0kPrNV_a7iiRMkp5oiB0xm3qvLRb0VYrFXcs8-kuJbxqzs8q07ickzvad8N2I4F6dkCYZg=w645-h860-no
NJyx5sg17sEQZTh-CLcvF6uikpRKSLpG0JDxKHjdFWQYYSEN1IEBr6MSGUfbfthF_yvWKWmnINTDasFJ_luaygESMghLpd5-FGF3nZGN_lfeDagAl7o0nqGp20NAYYXITxyDk2ANaYCP39ZvUyzc9UyvL44c6AWSdcswj2rC8ALiyQsJN1ZYL-b6uhOkQgxAwl9ErlHNdMU3kA1Y-_wyu6JC_dOzgxZpojLwxERNrAVPZUCmfAjIfC15w9klHOjiZOl5e2kMWzUDCSXt9DgzZKKsDdJ29PUcJqHXC_JxIB518E4q9xYrdnzrKXdore0ShXBUxKR1su6p-hIiiICgr9FKadytI2f4NFqMmbC_GjIx2kj2HZ2-DZq8u9-89c9b-V9hhG-QuIxc3wW_nW-g6GwbCPxWQ-5YQuFknHcZQYGLbaV80PmQ2F784VuMBMpm4q9nZR73a6ENAzd2Eg6Dx2tDxPP0KOFhHHb_Ra4sXlWoA7MOWYpHG6dSgcTABtC_KHKP2bPnbFI3JjSjNJf17Veg8S8wyZ6yw-tbqgMyI6XIuMpwrzIXKsR8MtMLiNnd9z1y_VCRTxFRwAdLGxbChC8sYf-q6Ct3h-bNQQTqFweZy3XsJ-bAdEp2okSTRI-ODXGeXuGuIS64GmYLQ7Ei4hEAb517MTDieoSrARsD3KY68gst0nPqnympgZtSamjCdeRn_Q3Xhykkgj_5YXE3RBOlmRZ_noJItKh4wtxf43PEIjLJl24sMA=w645-h860-no
eqAPnHLcydTAhEH_D45DoWRFynCGEfvqIHELwrPWLU_yKdjSZ4dliASj5KoF5rnFntAR0ddApnDuEjJGCXvr6bHRK08ixnyaKOD4PJl8KwQoTHK2CUH_piovwqMd99VvGAjIoIA1ff1pF-BOtjU6pxDBSZSIetmq8Rf2m6kyKaTt7xd-RRqBJJYAH8EHSdrzdfrqhAgdFmsM8zXNcDVPkkWOOJ2trkL1YpyUGBCbjj2G-3-Q1tejCYUwodPo1yUwqT9FkIPFS5R8z85-NSoY9VJsdFBAdrq2v1w5Z9VVQtvVIRVUJ1GWs6XI5e7IzwZoPqsEHOUwjFtN4Zr-RNnXa6e3Jm_2QVzSyN_W8uSl8NXXAfOPWvvJr1xyxI1ePMtXnokWslEY5uVe9dSfkbBtjt3jm9ZOvG_LbwzMQJ40OejDFQVBoJcfHxoNKtVmu1VaR1CQADaK0_M80fcgqyolez2k223vEwZ-bNYYzLOQUS1E8WrTdpA7ZQjZk3MEtl04jMovd76PZIw-d_50E4R0LMY7SC7_V0frA7ZU4br4W-93hHkTXHZBNL0Fafh0FNwN7c9LcFaHxKJ_C2mL3fE1VNmFlqDrYHk0UK3oLh2xCLxXHpsmH9VsPMbopSakLAK5KR43jIejS0Ao-Jli4A8WnXA-PItU1utTcgGuq0KFEvcQJcULoQU8zBzch39H5EMVwnEu8TdFFlLs4DWkX_sHO5zvly5RlHPE14yf7QvoFN7Q5AeUi3n8MQ=w1147-h861-no
uYZrsHaflokHeRs39bPOx8axELPXhvZaO4mbHRiatAbMOfMtS18_zCIBr4wIOEybw4a6OJgNTzi9lajq5r6fB92bBIofNtfKPgj23fCPvb8yXtm2RTTuaxi9r-AtokMqkHbudAt-eulGHH7Zz-Zd3ZKAhj-nQU5Zmh2YSWEcisjL--h0q3eQ6KWyNJOM0sd2rzqfpjGpZQfVaUsdFNj030oSyUmaRjtYuvewt5X1_DRHEYctV1s8QlwXO-S1XHOJ1SvS1VGSHqCYY15GAOOmNtBxbYEOcDQf2EMLHKBS3iYcbcy-weF1OE-f6jOWsWHykrLYc7fBmcX30iGr-f17mINhL-j2_jv5qNesU--ioPJY5F56uIwX_YdiEGCpLQE5AZJFsDSJRGeXQk4SBL4d1yLREr_A2jZXRtUQGdbwTTEyGZJmhjyjvp6DB4BDZc4FqbUAVtwBjjgJVZGtDH8hXR_xsiQ8mCx1QlX-LNmhVJ12SVvAvxPTqblKs5Px4gR8mPEqAP8VZ9upU4jtmSEZbbyfhznwij2vzVaLTc9pZV4Yg8NJ0yYJyJZ3mSwljq4rtxGe22FJsrBBguN2AvgoAXEb1ZVpf3iHFKYmFjWSGELBh0j1K9vmQuUUbTfQ6ZRE4z-4A8PzDt0Da4ijLqvTBdJ42tBhpSm8YXoCiw7FnBmN43WL32jw5bbor-Q4i3X0LJv2qi_SuJQaZvhMTwUvdxexQh4q4rbJGNmdHU2DonZ-t4taObhLXQ=w645-h860-no
fg-ufCDfIOvlUooKb7BtPWX1h-Ge_ow6eEGq_4q-NMxrNN8Y8cYfapPy1xIax-wqeUklrCDM2zrP5L5vrLczlKctz3GxPd0XXujeyZGEa4OuJIdkIPlqcOKP8RhNqAQ59_Z-yiuDIEG5F1kvnuqeMr6J0-GOWBoMkivxxiqHrMhjVO6C2YGkj3r6NNjrqhhrMIO3zJM7OkjZBBHtEmydqaQoVBkDgrc7BBfP9YOLgSLXOdLP-ph0O5F2BMCiTYWSYAoi4Njqi8kNSDHiuy5oaeFuoemLq5YqboRuoRZhMdGxIiW8dTkCUAL50-c9YKrtZBM9jUnlXGaGdXYY9SGi89tiVWrxka3gb97mXp8qFvnMlnVHVrS-oQtEDXLLy5OypDD8w8DxzCxxxZcfmPlxtHCjfyrM-7gbwHUcRG7OZYWxp9GAPRDUhhRYrcIof2KfJLDpSfvir28AzNcfr2x8SbzjyP-wGMlvEg12HaRVZ6aU_c565HIXeQ12s-KStT6Odtbog7aVjrA3LE8X9OJ-tRMfZUmyXzA4ng2hxqzLUiYIctTyD3NWokRc20TwMsQiwrMSaMXgzWJar2faYrTZfSC1N6dYfYbr3vNOgSq2gsX7UvIKcdSoCiOeI1RdRKKerJ4pp4gG3XgXIdIpHdPTkNqjqQlCNo1RROYi5omSU6zj6isl15tU80QgJ5HUgt4E297PoXPPEimEFWhCe7Tjdqh7qLru-NTyyGajQLAIq0XpaT6J29QbwQ=w645-h860-no
*** she is alive.... build continues.
AMP Assembly (AWH-032-D) *D Version (your mileage may vary) / Two Boards (2x the quantity)
Capacitors:
C1, 0.68 uF, 25v, Electro (CSSA), 0.68 uF, ECW-FD2W684KB
C2, 1.5 uF, 25v,, Electro (CSSA),1.5 uF, MKS2C041501H00KI00
C4,10 uF, 16v, Electro (CEA),10 uF, 25v, UPW1E100MDD
C8, 330 uF, 6.3v, Electro (CEA),330 uF, 16v, UPW1C331MPD
Transistors:
Q1, 2SA726,(matched Q1-Q3), KSA992FB
Q2, 2SA726,(matched Q1-Q3), KSA992FB
Q3, 2SA726,(matched Q1-Q3), KSA992FB
Q4, 2SB528, KSA1220AYS
Q5, 2SC1451, KSC3503ESTU
Q6, 2SC1451,KSC3503ESTU
Q7, 2SD358, KSC2690AYS
Q8, 2SB528, KSA1220AYS
Q9, 2SC1448, KSC2073
Q10, 2SA740, KSA940
Q11, 2SC945, KSC1845FTA
Q12, 2SA733, KSA992FBU
Diodes
D1, 1S2473,1N4148 (not on D board)
D2 1S2473,1N4148
D3, 1S1886, 200V, 1 AMP MUR130G, 300V, 1 AMP
D4, 1S1886, 200V, 1 AMP MUR130G, 300V, 1 AMP
D6 STV-3, Retain 1.62 V Drop
D7 STV-3, Retain 1.62 V Drop
Trimmers:
VR1, 2.2K Ohm, 3296P-1-202LF (25 Turn)
VR2, 470 Ohm, 3386H-1-501LF (Single Term)
-HFOakey9mxrCoQIrbvB-8Jx_J1fWyAbWmvNdIzA8vzpVoIjOaMcsOyeGa8BS9Alt0t-6MvFuBziGwDeystalDADavoOJmrPE_zQLcgnTt2-GvIc6c0XUVJVOTQAza00qWV_0KYVS5PHWWV4MvCRS5DaWUWgiUm_efZsUvDHPE5uvFW92sLPPzIZtmW-C-_Ubl-6CaBp1acaBNXX3IBcz2NKquHtj0wQmZAEOwxbCgWMm-Nl_7yQWrXK0Os-LsxW-2IeXQjfNLVNMMg1NgIUaT2sNWGW1CqrympyyOxU6m-ZPekIdgtLTk0t5bcm30mv8gRT5_X59tAyYjMuSZWk8CWw3Llasn6smHIWI2JOeO7niB_ssenOEzDsNO3k6lm6z6R6znD0cUB3Z2szybvFt29etX3-VSRubhruAMtBkYZmNd8eQivWpxnKtjdtluGu6dgI1gIPbW_qaA5DJ0OTrZu9q2SvBbQV47uR8LTsSryBqlM7hnlu55UsWYg1ZUJNNYxhz46wcqFEAWdkU2mf-JT9Z62j_kRFUS8xqiDOwHAAKu85BZ-h-lga_7iAWr7Zd5XvR_3pIp3gI2FFS0SlwNGkD1NvaMHNSsygavZAWV32HQT8pAXc2oufRfQ92usZaq0ZPJ1weZAbr_pvuzoVLVHqPfCVI9AHMftedQK_guBbjjwo1muK5J575sysq03PsFd7x_zmozMWoR9DGor35x1fH_ydhqi_1MmMUaYlX2hqdBSKAe0bBw=w989-h828-no
H2jpfRR2nNIG6pOkbKfqheSObmegMReCXJgmZPjcQ0gqAPc5aEy9TpF5XEezu3-P4_6GeyAI0wZR_Gt-xnm-fg7GYeCKWzzPFn4bs5jB5zSHcblOQPiCmXlZ2SE1wfI_BhP88juV-qwIaFoO_T7aRxXjdAO06gUJvbn1y3TJLNXeShtzurBz2JmGtrvRTnVZHDR8qMx8H5VdOEtB5ezzvqVtnssaZ5tDscpsuTVvLd7ytuGu07UzW8qS3I39aXzG7c1hfCTO83F_YrWZxT2h11a0tiM4WPikh4HnT8KYzzwnKQmsLftmjcpA40uvCN4dq5tahXorAurPDwtkKDoq-zOgF_j6nWqheGFm8ikiZAayaXQlQrp7CL-pKOzRNmwYqZe3M2DprcHQo679tBTge_k6l91lsjU1aFC7L7XhrPwnxzEtAfUpxMHO0fs49QN7VysrdS_BZoPh4LjQCsLy4_hifVJMM-LnBTh1TONZnjGQQSqqIKnjbigh8r-hmgzhsv5LshiqJ3Lu4Jp_sP0WITtyOwG5cuK5-gu-IYhslp_iii-WMIg7QqDihPx0DjDvS14FjQyP8orscgPLyig4HQdZj41tDPRVCVsH3zWNHGCDPxtWWe734bKitYKHWE0vPRvkbTYtEaHkPn1LjwpJS-nUrQeGHeo4wU6pjRb9qbzfBWSAr-x3nnKKMN-Q8TWJGIgOx2-ZqminT2IgakuwlbboHHCABDx-9b8yhBeYP4iJkQI-Z4edEQ=w969-h747-no
oX4_-rGYo5nkzhripWD2F1rm1dccTh2kE-5WsPmh5AKHM3H21Mvv-dgrgUKuQ2ab97f7RKfOh6fvVaFWtEQLLO2T5SOty7SSE1dDWJ46DmhHmBmAY099cZq6v4z0cWWGM0O2UUWygpInIkh25hvT7sfwDc1HeEr9TC4Yu0fW49QazqCrT5Tj64ek2y7OM57e3lA-vMxca3Smdtn00VhXQ0TNhZqmh_hWRnZ57KBrXGsgmEzTzJus_duGxFFPzV7yBYL01YZTpIhC1fRZZiVCz4KxSzA6l_EnozvpZ_kC4s3uW1mClAtciWZ1qRyL3ubGB8B_lch8Sfp5oyQCR5Qa32s8m9N_RDwco0rld1Dm0hBKSHcr9_LT83XESJzjBNkO7aumsF5apFFBM91TaD7VbYdVqoUfGyvBcw0lfkkk4wz31Q754BIx6kvxLGn2H92eK62AbDgQraD7_ED_mtA7fFZtyqCK8Lw-524roPCrXON4XW5q2AA-ICOnPwsoLqg6YAiAFJmW547dox33gyDVXFhZE3fIc93ZmJN4n1yLT8t6fJ2bUvO91TyI4-94U-GR6efGXN_o9Z9aLgbk92lAPmXdJS1PlZhU5mPGQnZTza4fqmtU29txqld6ehARHuB54qrVM0JjwfkfqFjuz5Rh1aVh3RhKYmSootrkrG4ByykIn2aZ-jENBolzqU1bwZkm36Ly-fZoci6-DPfmwaQzbrZokQqlhTzBPe4_HeMc9P4IA0b3oun9rw=w424-h659-no
Elected to desolder the 90 degree wire wrap pins at the bottom to get good access.
q3DgdrVc88OEXX3tDf1dO-60e1kHzMV9S_vTliz8fsSKr3zWs7JdPPvsmdyW2rnIyaJemCfVMvX8IuR1VuEq64APNp7KqaTcf4yJvq4ufpzEW3ZFtsEQMzyybL6T-hKKc178sLHEy66E9iLDIU9HBfYAhFpwkuTqPHGxDdPev5ify5K_FR1glI1JTw8sIbuxVKI7uQUh8YvHx26UBphBWORH2TUVqRubeFVenO6UIzEh2YMkzSnEikcFwrrzTH1yGnTIAh2r_fpnKnt-i63ozsd1ZqPfeIdLQEA6uMZzlTnYTjaStCj86bfva-M_pOtDShLhzRBmLGyl0G2EKY-5FH88D3UM7br9S-RD2reI_0dzN65HdOZFvjtfd193KHMiTqp8pJlFtSGtqKpvbsKKc90Urk4tyIggxE18Q2Z9WSnZAkbytqVRJEzN5AVMGRXrJr8F0TBmUNLlzs_QhNETYDKDi-YNQBCgrF1Jz1sIaendEeMlcacX0BagGBbtwAQAajAyVfqRWmKhVjFEUbiZA3ZKdTYphX6kbjAkD4Un1PBO8Uynh0_SzQUitlrJhsx2BxeQukAt1YBczWdQipss1zBlBeuP1utvNuxxOeh1HHcJ62kItVCYVZiFeMMnNauiG21dyOXzXHEmH_BNgzef3Pa2MPJ-JBbTcv3aD5tKg9J6jodpCXxPfhODmWq3jbw76jL7cdNYAjppsYwc1e7DqXg6ZQqOaB_IfE60mH_-E7ilwN7mBiyFXQ=w645-h860-no
TxYgbOKFYYMOL16CY0-Kpxyft5NLNx9VdtSRttpzBqizbEx9Y5aeecaJ7lHlekj_tcB2EBFxJn-2hZUgAaxxT4LrtQoQze1yg9lGoC9m5wc3ZCj696JW5cJZkZFYHUHrsWrwu-8mdsKzdUiK8fm6tC-hBy81sSEWpAvhEh4Q7760f4SI-fkkziMQBJpDebjsXQhwR9UygqxLv4AQH96eX_W7AVON1c86EHaPWAftU0hrtm8gGuBkegXF7wwJ9CPCrg1Xxop-0cK3udTXxLnsENXu_A2euGJjGbtayEANxahG43bSypWrkRgH-P9GJxV3CcQcheIJcsWgk-GSQ4AgctZ66FCtMeRsDU2ybPFaXQOoJC_NXQhRqEseJ9np0zEB30aJeFdHMsp1mtkA1vps4iKloc4arq5ftqrT-yh9nzTHvR57O7ZbT9v-t3DdcWTA1UD9sl2vT9pSw2D5WsX4BCHAAgcXDhzj2waJD4s2BMqNx_ySbcyxxnLBM-p_Qdn2bH7mmZtdW-W9254-WLVMQ2aeg6ZF53pZ-fosobhyj-SVkdz0ggSLmxs_kATIhBODCfnPGOHf-NfcmrLm6E-waybXs5enPIcA6DuRboyUbd9fHwKJ8QoZT4E4awbkz5hW1jxIO86LMdhQ8-1P4pThlbeTSad-T_T_dib-MOxNmZsOS2g-9e6vEJv8MQ5tzqCLSuEnu9_0790NqYk14yEos69z3JptWUuP8-smI2RMEEZSED4P4lPa_Q=w645-h860-no
jkQjq7A9rfq0mC7ul0VLtSNr2jR1hhI5JjvdwV6yvsr-Yj8NpnQHO7kzMx7KUz53jUwiJQ-yRkVZ76Rnke-SaTC9PHY9LhVT6iz4TmnZhQar1kHcfcXCdZ9Pj8olRkKHru_5Q5rTsY7KCAaWmhFaTeiOUW340CHpTTviTA8tluevddB7Tk6uSOxCHklkJav69hJ_OHo1fCXK_V4-MXbvbvIzU4C4MHvYvS3QZayrpaSQDpgDOEOSsECYFhBg1dwlBfOSRD8dbmIGsQhUqgGxocEyXZcFxJjONE0KS2bqiMmXsh_FpBikN-QTZwqcBpmAGFiXA51nZ8WxN3hFFMGehAD2ZAKjEwuBM-k91J-2ps9qYtvVYkOT15QU0FqrlR2LkUjocunv0PWv0OzI_sI_OvSgH70MNYPObZAGi5bGKtrdGyghoJY8q5XLq14rqhpuLRPzOJ_t_tC5__IlGLwer7Dv-F_yz35CNZr4TvTIBW_MoXmRyyTpJHe-HTJGrPGq5biHQ2NyapYeAlG0mB8Q6AXa7aEtOSjvUOdl106pkBLnruEplKK3znM1Sp_mM3u8rNnKrNBrDZUZtuF9-wrTHtHGlemmP0Y7D4Cl7q8eKJYsV-Z4GlZrnzM8SE7Al_KDSJ0FPgAug4x_s0-352JgKnI0qJoj2unvpyJlYr6RwKYnapToo3rWaLU_iX_1kHRBis_gMKJTCvTnAfjPPtywEH-ZdFVdpHvHZ3XWrfkh-DejPIHk5ua6ag=w645-h860-no
p2tVMMNDz1P77zosrVcL82ndMYqhhve9L8ri53zKiR4SMPqRUYwOd_Y-xgiyC94WcOGebtUOpqV6CoijVN7559db7XhYzhaplZA4Os-TN9kDaS0wADIJr0quYLITTaJV1gMwHwDsQy7lE9oG1O1GsSL_hxon8tcIMwz7ugE2E4Zkq4jhCEhjAuF72IldSAlCAjkCAbxveyXv4z1-4AzGZBbsSPLPqXfIu0fUiKPNyW4kuuksj0CiKB2lIlnW2kUTbAh4mpKtyja4fc4M_i9LRjsOhkEwXjchKoMLv8lTDMfzaKhUJKDq2sbgoEEEOoULgcoIZK42IzkTxtFMVuTS150VLJouiT5Z6czOq0-3ymaiULx6iy3ibkyASih9_6SIgUDVQ9foEm6Hqz4H94DQlpseLG5Sqcm39J7T766wCuWsHmThOr9eK3-99KdJBdjc1epGY8KvvzfI955BBReF1ZRqfM5OLs1p68t9gP-ZECNrl3QVuk8S1ZvQQSSzGnegM2HDGuw2b7lkDIwaJhfcQjDhSHpzn7FsKS5UrVAz7Nai6cDZATt90FWlyvBZVGTwb_t9C-zEBZAA1sYlzau7GcQNUfWh3HyzjHivt-4o8nS6SfhDoQwrvMaYqOx30RaR5_xhGsrBTSiz2LsW2k-BPHczLukUIo-qm6IZSjYjSPfOuDZrwRqq6g6hHjrCdurw7WFpsummEku33B9TUgIll76ynOreb0bmOmQFEMnP_9GWxoIIQbtMGg=w1147-h861-no
zhQTnQTAMTR2Y4-W15pBpiKwEME-vOISLYwNtZ40NZLM5rBILm115wWaeMWlvcrhfV0iWrP90BFO1gUkyvjrO3Rc6Xcgt6_IwY1f78GtxkZEf5JUCrGicF-Gz6Vz2jVnbYVkBUbaAR0rjhDg4_biPos74w58pFspPc6Ul2UtPNw0GVNSaE_GNuVSBiSC3UX_l1R1GyTVDQKxPu9Sd0OuC50UdL0N6jlJLF6hB5_pnPFhVQaOn_beYYbnY9djtRRXTWcaw40vR79vexhvRHEDSaOfnJaRHEuvoumavwtDPSWB5LaKFeIVxtWD7x3zkHh4yxgG7pGZ7ZDiX4r8xJ8WMKR1o0P048f5fwPuSLKOB0RVY_Myqaa7AeGuPf6IiKS2QNbIBn9GGtyOUMqK8Sr9vg5ph8ZIwMWvC1jt9hlqrpAM4baPNlO4KxfcsIIjZlDDZxuIhCcccTMeFIBdGLYRvQThRWmQinGGslhNWTgNG_euQ3JNDoDHSArB4eU9dzjsOffHE8q3SDs0dNEklAU5z72hIiw_iDdOGWB75u3GJgnnuyy4xtim1BhG2OQBEaSoPgXOQM_U2UjliZsPpujMjVDbO4nNS5ZPrp0uGUcGj9GsrgGQr_WTTc_Gc_RedwvibmCGxxW8k-eDb9vNqt9nGF1K6vvgq6MQA7dX5so9jnUo6BcEvQePIbJ01nVhdlLyOFwhF6lkwx8Fc-y641oCD91e5EGoEWlEPr7wJ-peMDc3Bcs6AzVvIQ=w1147-h861-no
atzQfxMIqN86sInkZ8SOswoHoug5p3cOhDrvuB_LjIrGAOH3vchmCgoylYPskAARpML76VQAXH4EN08tOk0cZztO6OSj5ZACe-QTPNbfIsumf8DfiQ0g5FJ0lVHfSf-0HN3wIMkHOCy6Uw_qOMVDbY8zU4JpXiNFOKCCZx5VdfBndoVi1nOYZ9khbWR3m-6uxYToi3vTlF8Q0VUhfxe4fZoxCx8RzvXgJbpWsTzWf7Gf_8dio4P_BponZqki4Bc7Gawl2wCAMR2iLFl7HJFYSZKOMwAO5K_FKHbceO9VVKrLtudG0shPV-TmvY51SzCp7bRpt0v-nsvzp1j1SgVd7aXrishQTWDwqyyAoTG1dBJHfQPhXQq-7RKUmj2jCaQtuF1el3bUYpI_fzukcGgMz6EWxLw2m7v9eBFiptFsHE7AAnaCh6Fdi1yYQ26TFKtWyHRtrPET1lyGdLBBCMZufBW30aMlqVHozdaCq5jI5q4DvtIx71-TpMD9oMyTo98QBXGuZnMVvwdC-wLPfCFeCGJdtbeUksk3psOdBTH1pJ9IWSESWiZzCLSgVUJ_2UY1vOlCIcvK-NGloVkoCPq8EVwoc6ybtbt3IGFn0od8mO36OdTuYokyL681xlc8n1yU7OIdmE9N5QRh4t01i_mjtLcNi4BpGZ5bft3PTXFOJcfi6T6y4byOcUEWMdWgNCIYLR0NF0DSeEDKRiNCAIV82txDE7JhjbckOQ-syoeRHgL3eGu-z7TlaA=w645-h860-no
fcDF7VrxSjw1bmU77aUmMeBJpyOa-Oa7XTrC2BXyyFHiKxG669bWvsaoKEQ1CvX41RiEXU_zUmluKde1CdTRMPIR6QJE91PU4llG5ZfWMtLxlesnJ9l3HRkAb9IN2IL1QqzZ2_p6BsJUrQBxfr2atvsQLGJ7zdg9JndjeXL42_8HDDRurtv0zVnuGUiaVq9n6FtUvoy3H4Yn3egoOuEcvwJLmnjW-FM9fC_vPkgAQqQuxxHlH_Mx1N6wmNir7DcQefxKAZD7QbjgAJB9tOFuzF9LB0tVKvLnnPf0tQ5RUEfrGenIe_gmTe_IZ2FlndLuqfqduaFlc9eVcGrHh2W74NI5GzGi0-aJ-G0R8Qivnf0iTeWaiZDEa-Zda_oHgzPn0jyc0akTUhGMSUt4y_hNtfyrvV5vAaV0o7PQazoTUF8ekrlzRwy2zN6pF4AmxubyWNNr2jZ9JKQnisF0x7xx2lLX2azpFKrNbNuzTVLdQK2d5A2musBHestvnD9VEsHxKti1TxSoSpEEqTfneTuh151BlzStDgODQWl408y7KyeBxXh9XKMsmGv2qrQNzjcYsuRP8JSoezNuRbvpBfT98wsTj09e1SDhvXJv-nJHIyM3Bco3S3JSmOCXCLuveaX4TZcHgFiyO4KYALZeLhLbrPq7ncS7tN_RV_PYT97FDhVE6EEPvzYlOGHatN0NFmuvx5z_tX_9HN6hBB2phuxlb4Q1_HyZUy6JSsJwvkBRZLtGXPyyQKAAGw=w645-h860-no
zbo1z_bwlwZF7jjhyw8bC9tLHVNeFZSDHNt0LpSQgxt3h85efY5McE2EfOF30HFgusnqriPbwSO-Qxtg3leuWhXeUJjqm2aXhMG81_CFRuXBNl72tcKkwKhaF7-5SOpvVWYreB-yQfVayKa8O50Qa7525wKs6EuRPTaBZ3-_RhdMmlTp9W_GMdY1KbKQn22QKilXgLIeGZc_CkQibdqtM4U_TudH3JmGYqu8P7FbLXP_z5tdE6kBYzohcwzi_J-jNS9-F6_HDZfzmm4YyQkavXxtOSmkp-KmvFAGL-3W-7HvUIz6nlM0JwNgCs9S8yoHD-BVXZwlx9PrvPPTVE8eyV7V0rqvjEdfnbgiE8ywNcLfs4fr3RIlYgL7ZgTLdIEB4oVvMbawpmvRwGMq60kGCG4DXqoB1NB5u1M8_o9rBNIW8xmTT4NqT9V8wOrI_jYDVOlA-aJYp7WgUFn-thB_oQ-r5WPtZKEf1hdUcqwGzTTXQmvtx2QTfPb8YN_ci9bmQ4pACeXXUhgQn-X2AaAeOD7A4jfGHl-hIg8rdGRQYIWiJbFcZoGgZN0FdIGiYWYjbOZoAUoIyTM7RraGbRj18BoakAGHV_B2JuCylea_N1DP8mJbgn683PddPl4hr_FViPT34DDBp1w_bzU5af4eXKYTQ-mctQ_dWmfzz0h8pbOfePuVL_tp3J0dDlocHu46nBqEHwLFUKTrDA9RKM5irOrfxHbIOIY61YzC1OZxm22sU2gpxsLDEQ=w645-h860-no
4OwSvPHRl10S439WpqmXU9fA5cK7p92kl-JtJOY0VN4ufD9Xzbt4cKBjaghGGHaqyLy8XZuG2srNRl4xuV2R1S4lrl_vc68kudQiygORqGcDX-YTPtz8MdI0SiJNhyfAwWhxrShrQSQu2jOq5UVCKoUXn6Z4ZcN3KmGZV3dkbp_Rea4NsYGcjZbQGXOLMwlmQGWas8T0VYDXz8DolaJKgdkvKOQ0yhV-iPgdvJNV38GmJD8gUOU9Ty9aKJTplqbdD0g9kH3xCYVwZ4xWTW-rzz_ZK739GVfuDkVScGbr0FB3AQhAayr0NkWu0yLAR0GAAQTMPokdOu1NUNOBMbsvl4Zg-lSEdCNAMRBk25Q-AuyWZNtHWp9xcO7XzaNy89PXQmngGUs9GenyqDkEqa7dRszLtsJxmVvVgWyCLmtk67H0Y9lEmvxwqxnDVq6x-pXUY2ymw1strTwyVAn3F6Ewh3viA4gs4Rbz5zO-eAhantCwi71mlIgudHIXIWrZq6p0TAAcHIPb6xTmsTf3POqWQhyjJzEBfDD5ij32gC6I6i30mSKp9Ee2arGyOtdUoE3eaJM8fEp-KpHbnBSYe1SZt9fT0aewrUcWlMwtPHTfcBC1fz1lIAQCgnsh5CZ0A24NC_HtBdB1t5YrajOPkJaLH11hImbiS2nzi3QX4YDu71gCiOEaTaQ4-uYfYxwWYCaRf8q2Q1ajNcUO7ysEhtJgIt3fAaoqw-UfA3NNESxjSlRudVvUGFE_Hg=w645-h860-no
leWZhEE4OhnNo4mW3tNacI0lp17SHR8rcPKXLHnhkG7ne9XZhDZVp2RnTL1e45i3d3xhCf-rKtnqcHZHBftY72mx8Niesvh-aD9Ch1wGZYlqBl69svvzK0nVw8VBRz70nowfqg6v20PTg_Ntfb9OugRjo-lcLoq7O55ZF1j8cgtFi6mRBmorETR7K7HtewoQ9gVqEgVALvhsygyTvVLauzhjFj6GA5g2AiuDEDmpoZPknO6YlRCnrvukC4cZAuQ6h3ULk-HV4eYC7V10wIxSJMy-9k_vJhV3HePm6pGvkJLM1l3y4f2uJXg_n10sPOSceNgK4A77P9IO7KI-sBdjA-nhC8T_wGBmDTH47Z3CPzSqGbKOyOderT6zfXGkIiYkw6llsWf-Xg8I-Jca4XWGO1V2yhLwZwf6zcsgnG1gWWxl1iZ3ShfuU_14F96vPYhzXKfeDAUkarH_KcsEseIc3q9gWQL9zY7UsFvuUGpt7Rl2BD5jnY3piII_O9awc6rG9_ckbuwR03mfMikz37MfQGcbF5h0mFMevgylCphSIWK2qYAFYgkYH7YKjLwx-iPCrUtPr6c9ZMnu4_7h39QDeHztXdEdK8AJBRPHvCUdmcWao3R6fzsm8SsZ16AjEd2OuaKRvIdMnPF-MVc_rHtAyIY7M8aT2jvaNeNR-ifS0g32ZWD1t4b4PWmJJMDuiGihfR359RJhv4BWijnRvlDoDhIMhJgUgCu7QdCAU7ewBmg9mZaxs-ZT8Q=w645-h860-no
Main Outputs:
Should Be:
Q1-Q4, 2SC1116A, NPN , HFE 60, 200V, 10 A, 100 W, 10 MHz
Q5-Q8, 2SA747A, PNP, HFE 60, 140V, 10 A, 100 W, 15 MHZ
Recommend retaining the original outputs = as you will not find replacements with similar specs in the same package (TO3).
My unit was like a box of chocolates in regards to outputs... one side had 2SC1079, SYL ECG280, SA679 R, SYL ECG281. These were working - but looked rough. The specs are similar to MJ15024G/MJ15025G (HFEs actually higher on new MJs than old replacements = similar MHz and 16A vs 12A). I used 24G/25Gs because I had inventory here.
The other channel had NEC 2SD287B & 2SB539B... which were in better physical shape and had similar or better specs than the originals or what I could replace with. Elected to retain these on that channel. Some folks don't like to mix outputs as a preference, and I am usually in that camp; however, the NECs in the one channel were retained.
If you are going to replace outputs = here are the recommended replacements (better HFE).
Q1-Q4, 2SC1116A, MJ21194G
Q5-Q8, 2SA747A, MJ21193G
JCPl6OD4uH4zzvR7coj9T5IgG4Wvaq8P-Yn84grdOd0OpUgQRM6Iz5_l0UTphSBlEd_tneX2aR8_-InC-6YztDU_NW3aQJrzUaDJh-DxbwTwvLIy80U5k2B7Lg306lzmIERVyfAToml4chl0zkQy-S8Epf3fUzvRDxUq-M92og7jWDFnkopDNaLZeqeHozUaH9T6nypT3HfcDyzE8q512DCS5h6u_842HQFD1JxGLKbPYYmY37TvVOBRKPMhKVQFVdI7Sh0MSh4viBnLLp4VDkqs7eWEyvRCvGPJnLN3Q6AWZtxYvib98ksCgKGFK7IxxvmKA12iUzpUmhzazzGSCWTgTOurdhrxghl3FOuseBUtLLyqKWR5Y1-en168RvJwB4cmeL_JUjvzVa4nDBfHqqOeULwBus3wTmamP4PIk8w8d4Y52bdWBamaHyw5u_b8bTAiuhUaNQ-IiQfv_cP0nL7AfhgiAZIPZKDwMUH2FYBolZlEXt1_ZyFtACszJjDqTfB59I1RgHLPMRMpNbnksEB_omGRlBxbWklGbyybAEcQepJbvFIh_wRceaJNxS4FnybnQ_hL_gtTtmmJGVjIUqWRcf_nTT2TQJUPdq091TLUjGJz9pU3OYoQqs5H-iJzgnCOOrF1fbww1Bt8LuOLHnBNI2nDgTEcrgTgvDkdygJ6L4-G8sLZDnuyTsoXl-voZEu4W85MleuncT3j0r5tbtT75tlqlwoqa3UuS_U5eqhAJjjJ-_y0rA=w645-h860-no
7xzOjf8G5X_9zmsPvNYsPlj771tKaI99tpmOwg52gbzCecUrsGiYY2EVPBZBeq3YcAfeFOuI0UtnXsiYHekv4EFlvEME0CmNaDGqzO3wg57w2orXBpjDThRDAFUrpWLDS2ZDQbWqETQKeO_9hQLZEjgcq99inqCPKnhdBxeOrXj6KfCWzs3gG13pLC3Qj3XoAPvue2HTwfiPU5kdOfF8RoHZ80cGeg2Tv2QmkPmxN9xG9c6924V0B8Kca11iJOOBcCECMPAn-a9JIr4q5AOutboHeV-7MpVO38ga1n-pEg525UBuVTATnH1Dfw_47haj2cm4GTMW4pFguBTmLBRjkXfoFjovzvNbVsaxFcUKiAVDHjkZ1w2DxftbDwVc-gSrTlLFazhEc5YtGS_PH99mUxpEyHynN0ykQvmXJ64BitV-JDlxlke7MOasM-91ASeEdto9fPgP5MWybk6e0P3dp0UN4c3WUvnvFbEjaZnolo3fb4i_Y74Hip9NBJ9XPDomG729eiP_UlHWyOEcftmvSDenPsaw_QWh6bK5_etYEG5pkk13P-mn94eK4eWKRegEz6DYhdevnOfNK1RKzCQM8C77Mo7zcGg3fQlP6lQpovm0EWrF8-9gnUuqc8ddIVEHb54lf5HjGxqsndP3JEe5-JUOIO8P_Yt_IzRV8NcjaW4iaAF9wiMnyV9D-dszfqVSJd0QjKibE2JDGVbvhn9BBdxap7kEY94IoA-guQrmpIydnodac0fxPA=w645-h860-no
N1vQ0gIft5kNlsAwZktqIzYfzS1Gg1GAXLh-OXi4r9XTsf3NbbTX8KCDqptCaJuC-CGmzFwoyONUdv3VLt3V1TdAkbpCdQH5mgCwlbb2RakQVjuV50_qTGfXBJYs7kJbWoke3sXUtwknGyBzr5X5wYj7Xp_neDUQVEAJlyJisBG0ms23VbiPVpy70FrnwuqPxV8daRGOmVnCte5zDjdR8mlh9clsHIbOJp4ZNmaczBLwYI2KMNEMKBh7uNHf808b2VFQG7KIokd17LJaGaMZJ9Sazcwi754ra0rzhk1Nupb_I3hWY4oTyFmPVX4eIfa81_ps82c_xcB89aYXmhFG9iJsYCgax61xzeZQWAEkpVi20J0O20w73fIrNwD0WRC91jkOq7PqTgzEaug_NgZM7bajziN-YVAQ8KqJfzqPMDuyV-B7pujZKBoAzH7FUngPIj9q_JGI6LitGoi2FfMznNATXfFVriWfEOFuUJ2ko-wXRkkqyU2eXqo5XwWeRIRmXfVf9A2mGsRkrW78GcnOJ-KMlzWad5KRsASanVxzPvw8dy-T2BkF3vId-ELr5fOjBtJayrdzLb1ai2LcNB0UQ5B5k2D6T1DmYGNqbutD7UN3QqI1GIqNhoHSsvBsNc3WqlzcAYtxusZ4bymBEGhIW4qq1ojYf-fJRFTeVxrFuzQo8AtMYxJpiHOGyXccTKOOdXkSVrSM1J5kFOZjO3m-GyMwCxCl61B1ymKL-Aj1-RjOMU6mf32G-g=w645-h860-no
Jumpers looked to be of the coat hanger variant.... made some new ones. My method is to use 8 AWG solid copper then tin them up with solder.
zMtL5T6Jve9PRZF3iy5Ii4UJTpUSQmnlUnoeXjpTS3I8ChiiWngMLKsKeGW2NeflP4HAMiqn565FTqVE-3IQ1eTtqa8frfqtP8laRCAuG8GnsCG2bRwBKmIuTNN0WYOC3J9SRSX-L8xdoApvoFrMr9iqGkSUu59LUehhFZmeQnLiMRwMpOMAc-8vzs4eOZP-I68Io6t0DE1I1HoSO3M6c0M43g6g_bzBC3s-KeNq-3A2qU3yfIZ90xY6tDokV7nigOw3j2R0Sbt7HIvKp6VXZwkGDQcM6R9POAM2OQEKiJHETtb5PEw0Y_tuYOe7xG_HkFbYrOe2c1NfOr41X3wgjGZzEOU8hMXc9CMxUII7k6VGKKvxmX6GmjhER1GWlbsYwmBodUia0B5cB_mUk95qKe0Q_NB828UpCd_LP2dcpScVEiU8Ie89g5LNj-rFZYJupwyL1O70Xlg86TedVaeTKS6m5Xo23JDQ_j1s1n9cDpzBd3RiQqmZY36T1LtJqePBK_MK_p84HlsmgpMftsfxAh2IjN8K5ET4fHsM7hw74HDDScx0nyfycwVa8lFr1IVXuCsDenCCuRrVyugRG2Pmkn_ykSGzzOV6Nf6zA7cwhiULIWnmSQG_D7jlWXg9gb8QCMvw0qjPDfC4AuyXGoFfB6mW-4fdcPs7UwtbKRia4TS3-_cZb-oNRdAUcmv7Kst65m23wSVNvi8KGyJv75EH62270-V2qZUQvhx8XYPd4B8bGfUfeH0hgQ=w645-h860-no
Control Amp (AWH-027-A)
Capacitors:
C1, 0.33 uF, 25v, Electro (CSSA), 0.33 uF, ECW-FE2W334J
C2, 0.33 uF, 25v, Electro (CSSA), 0.33 uF, ECW-FE2W334J
C7, 100 uF, 10v, Electro (CEA), 100 uF, 16v, UPW1C101MED
C8, 100 uF, 10v, Electro (CEA), 100 uF, 16v, UPW1C101MED
C13, 2.2 uF, 25v Electro (CEA), 2.2 uF, 63v, MKS2C043301K00JO00
C14, 2.2 uF, 25v Electro (CEA), 2.2 uF, 63v, MKS2C043301K00JO00
C15, 4.7 uF, 35v, 4.7 uF, 63v, MKS2C044701M00JO00
C16, 4.7 uF, 35v, 4.7 uF, 63v, MKS2C044701M00JO00
C23 ,4.7 uF, 25v, 4.7 uF, 63v, MKS2C044701M00JO00
C24 ,4.7 uF, 25v, 4.7 uF, 63v, MKS2C044701M00JO00
C25,10 uF, 16v, 10 uF, 25v, UPW1E100MDD
C26,10 uF, 16v, 10 uF, 25v, UPW1E100MDD
C29, 100 uF, 10v, Electro (CEA), 100 uF, 16v, UPW1C101MED
C30, 100 uF, 10v, Electro (CEA), 100 uF, 16v, UPW1C101MED
C31, 4.7 uF, 35v, 4.7 uF, 63v, MKS2C044701M00JO00
C32, 4.7 uF, 35v, 4.7 uF, 63v, MKS2C044701M00JO00
C39, 4.7 uF, 25v, 4.7 uF, 63v , MKS2C044701M00JO00
C40, 4.7 uF, 25v, 4.7 uF, 63v , MKS2C044701M00JO00
C41,10 uF, 16v, 10 uF, 25v, UPW1E100MDD
C42,10 uF, 16v, 10 uF, 25v, UPW1E100MDD
C45, 100 uF, 10v, Electro (CEA), 100 uF, 16v, UPW1C101MED
C46, 100 uF, 10v, Electro (CEA), 100 uF, 16v, UPW1C101MED
C47, 2.2 uF, 50v, Electro (CSSA), 2.2 uF, 63v MKS2C043301K00JO00
C48, 2.2 uF, 50v, Electro (CSSA), 2.2 uF, 63v MKS2C043301K00JO00
C49, 47 uF, 16v (A Version = 100uF not 47uF), 100 uF, 25v, UPW1E101MED
C50, 47 uF, 16v (A Version = 100uF not 47uF), 100 uF, 25v, UPW1E101MED
C51, 47 uF, 16v (A Version = 100uF not 47uF), 100 uF, 25v, UPW1E101MED
C52, 47 uF, 16v (A Version = 100uF not 47uF), 100 uF, 25v, UPW1E101MED
Transistors:
Q1, 2SA725, KSA992FBU
Q2, 2SA725, KSA992FBU
Q3, 2SC945, KSC1845FTA
Q4, 2SC945, KSC1845FTA
Q5, 2SC945, KSC1845FTA
Q6, 2SC945, KSC1845FTA
Q7, 2SC945, KSC1845FTA
Q8, 2SC945, KSC1845FTA
CR3XRotdYE-AU_MFbS581PnCzs6nZWSYkRHDF6-pfyu5TYpAlJo_2DiDAOAPTarcwZCtvNsMJSVqhBqit5samgSyK5GRoR6ihAvidgHVX2M6MLehrHjuRN7GXM91nwN4_iJklbHhK4ln68tyPHbXJrHgD10wteTdcrM4aq5lSVX-P1ALaqKNVRngC7b_jDhrwwJsT7ujBZGC8qdOckiKl0PN9juRbD0s0rKLUnFx1DTQfP1zKvulVRFulozyvJKjS6h-_43qUISKqRjtskKy-AeE5TLWmnk2y5aG_BL4tDxhMG_auKgBHFbJzHlQCuH6L2sbpUANkbZpbXCFtblD5FzF5i5qm7-vNba-5eBzoA8Q_a6WZfa5DmRdh6jGLS8PxAlL98h-v7F-cJXmjPUim1xoF5eSKFYRCaM2vBdj0Jvwv4JWyOcpp5tGTR9DDgJsSn628rDlUfkBtGOjj9ZdsRKSAVMd2OvXmGKOYrHYDjS5jYdIoPlRKYS1ro4aoqz95UC0aW3gOjrlSNBchg16LKt7tQwRsqvXvnlCoPed4PCmXBS6jPYIgkWmC1UU6AMvvj3wAEE8clgjF1V2TuGr0E5oFz-612bKWf5OVp6BB7CgSsB8q7Ddn1QRGvYkgBS14FTayUbBgjSA96Iw0tJTZfSRZsCSbTMpbzBnKaeG4az3O9lPJPFq8cFtKOetvXDkSOc74GvMyN23HRhicURQ29lCN5NkfosrRZuJfvIm4DkjnM9Z9aCYEA=w990-h750-no
EZoT5b3KRSYKOy4M_HzEpu0h03xV6KN0umyvMvEiRtHFgS_Qkc723z8RG9v5lgy1MSGzKeZ56ra1fyO-U4hevAt4352DOTmgDMsfNZTx4wHetA5Dt76v8sFum_ymOxzuNVdijlWXLHAGaSEtIJEKW_lwK2vw9BSdnDF6mkuYBheSkb0jmmAu-4XUOjIirfCl1ru2jUVY3ZdnzsN7GgUWY3IIUgYZHFrnbnORTgkG-PW4i1uUKv8CICS_aFaLcd31yskcc48oMoyHwASBtcEbdpAfn1D0R6E99rwGNr7f2EzVFbQjZN-sxLsSMBLJcDjvW_kuyqxeMVxeOaaxbDGpc6prBqthXZNI0GeF1wrSKcl4XXjqnh-WI7yFF7B_xbDnCfWcPJT8wXCEkbGLLG-7D-vlW-XX_9lNEDsozy6crKki97-L1i8yFumouMlI8X4k9ch3KWow8o5YbxMI-_WZoHAFqAGPTkbWe3sNzExx1QI40qqwR2_Xrmuj9NFAOL5Y37AwlSZATyKnrXa_5dKO9BkX_nuawSMFCEOtpxZmPgsL0P1HKHytLR9gO_ZFKiJgK5Mm67Jq4yVbq7bLl9lZmD4_ppLbUsYZ_WsOcUMXIX_b8QNKSs-DgYcEtVFEp5lWtArXh6hABsgaNZtaXsHJQoA9hBi9mG7WsG3CLEiswrt0vkMRMynPk_UAXyFLDfPSVnBMkE-gmZVP282ABVZBfi2xkSsN_70GxrSaGLvWjM35cLGo0fPzGQ=w1076-h784-no
VubW84wvpoOqQD9G2WuXMQYe5EwUR4b-eR0MsbsnFUOIrYELCFJlhCykGkRnWxlqjZ4MyaKzNr6OLNUo4w7tPeaQPRaXNYOkNYDho78Dy_5oLmCxqU97DT290DKKEWOljfVY5O2EbVR_hOJA8N9RmeEcMEeBqN7JgLU9ms9vwH3zng8zzGd5Ix-tPUGa6hA1nWrMaIYbNrjo1W0ZDQwnhF7CxTon_R2-_dmm2KlH4NAvjt6pXB8IzobdxBw7-ExZIBGMiGFAEFYdXBwc_w-tUynGSVKO5JvWPdnc5UxjZX-scGXKXBVkl6sv5mxqAYpqej0UaDGt1oTwWdwigTI1-6amBxk---jeLMbgu3tErFGXdc3aaW2YweWTXOZkC9DWmJaz0ymianSScl4fvfcXd3MOdzTUd97R47MIuB6zEtsfCLv1w6L7hHAAsV6bCtM3j9fs4C97f-9obsHPrabbWbNGhhyFgnGVPDqtqfOYYd8U6d0SvRswpCZJXcq__ssI7HP_167znAkDPqAjB2dDSBVmqQt8JD_ZhpBApnMwUEvNGo1O8eByStEQMijeovOkB3PpXzLqMcwTr5WMFr3it7TCEOmwHDA7r_-AVtEXrGEFVkAFOqqZoL5SKi0QssLW-CZAYT-NFkpadWGN2xt-1Krn3UKSkkO4oQFePQPcCtwXoXwm9CPrA2CaKSkgZsh2YH11uKE-FEV79bnyY1zuSdel810tv_f9yGLumaASvhkWWVKKCOFjMA=w380-h570-no
YppL1Ij_oNyxNGEjcmqfLwu0lEer-gtMutlVC20MJ-4NTAbSE3t8VRZ8lC0J2toT4bh3_S5wREV-qNcn3IaL6W8BIF5HiRFlqt5bptwU1DSg3p8_bqg3baI4M1ps3XXtrTm__y351aRV4Ni88JqVJ6vP6iKE_JcnG_fv3pRx_5oLKabtxDCGqdPMilXFyv0JoGi27DWp-eObH7VR2Tv9ZhpKmrulUZ3yR6PrqX4TmvGlkqDOW6tLlLT6a7Sn0pLX17XiY9Xl5HjctiuvzKm5XhRUmX9RZzuonwUZL2D2o6cHFrXak5ycpJAgBndJZ-dA73t-n_9odf0yMzF-QCLFnC1l7fqx745iN4oZBOTVryl_ppdis7r1JcWa7uaxiyHvIpT0PQTvWZDTO6rx6yn-XAt2D39-NvSPKsHOQMxVBptolrUThJnk9D_ycjpbJpuSu9iCHypSB0-fkPfuSfADbJYGNyx5q2YwENOn56sMr97tG2vL94GCU441sh89HQKRC_tb2QOGetLtPP1XnGMhMQq3ivFUV_sOjHL7CaZCiPHTdK5HqyEb76xUPiMUtOjUXGICxYntbAAu-r8aIqhInGF9fvEDCjhFaE9e0Modm_-BVpHXTkT2NXGvWtYulG12enH0pLe4Wsm0ETiydQsKggN4eXcYyurAEQi-cm-k_J2-Uz7TzkHoutDnezFSnjbrEkD9Zip8CoqrKC5vl1XwBY337Jzze6UFJiauZIffxUqcCb1j7cK9-A=w645-h860-no
OkTXjR2npwpOSh4lfyfX0zPxmyNyaFHa0UUqbALezY14SmYtCaPc5stwQ5QILxZHsn9H4Vmmsi2dkBGVB-weiJMGIvZbdtqbpNJxRonL9QCWmzHuzglB1q6pKy8kv_equVLaN1sl5A=w633-h844-no
(needless to say I am disappointed that I missed a good pic of all those beautiful RED WIMAs on that board - unless you have done one of these style rebuilds, you have a lot going on between the parts, lists updates, testing, and thinking ahead).
All the pots where routined with D5 and followed up / flushed with F5 later.
Lighting Upgrades - LEDs
Appreciate the green glow that original incandescent yellowish / orange bulbs display with the blue dial and meters. However, for me I like the look of bright white LED on the original dial, meters, and indicator lights.
C1, 220uF, 16v, Electro, 220 uF, 25v, UPW1E221MPD
W-a3zUsp3h6tL3ItbOpynO0YE_nRXdsOfwM-FxbVsSa4xPWOkp8nFyS5glSzwwBOVRDlGkjWC1xET2fcV9p_pMpar7M74dqY_HlJNNE_6fAS5Gi4SEEJ0mDQY6602NNeNFcLyJZVJ6HgYtIiyiyyi1xIhbKruzwtnzcyqv_nnFQsFJOt_9zE8t4n68q-VazrMOq_chFe1ZYY4e_CWyIPB6Vbc30FN42fBu7ZHYvOegPbilQxZPHGLTiQqxtgLqO9HceAxahxrUMJQ86nPm814tRo5fydmLvgDWPOzAJZHMjteqRptOK-_8mi3tGdxkmU4ZuKNc2Df0ayVNcl4fhoPn9C20c2P22bu1XTpVnr7q9nyrcrroPrgsKnEmyxgk2H_0vxN2TIvpGBSl0AdPTqAkvY1jZaHYEJ-4aN3OREIjgV_y5lMQ4SHo56DjCFRqsvhpS6bKlv67JjpIXFWwq0WHhTospyMLbYJMQjFr3UeP9AfrZU2cJfudutZh7c9nF8Ncusu2o25Z9JI5vxh3Sq1jf2jis9dBoGoRcVaIY4n650BDoeP74y1Qg6sLX3Ixv9DVdEAGP7ystomeTmOJEdrJtVgApnIBBPlw35kVhEEnrhb8v1PgkmY6Dq_0CUMrLWcdb0D3-VN205CftocP5-zyD88JsEqIoyGXfmocToyjHhXoL2XvRDkIYfNG2p1_DKtfdVyBCSeO7PNTfeHAVOvtM1C08yC22tj5MzRmEZ5PmeJcMZdrNdhw=w645-h860-no
w8OEOWRKkhQICyjvvBQ7khWf0xNrwF1HUvW16RDmK_NyRZz7rE7Hd7SABDBnWiGTOf0aSDO-g5b7b9YHGKEJalirlDJVk9_g9AGfaAuJUv7jfOFKiJylU5c0KTTruEDFZ0hl8ofYqEm0KZOiOhJYxuM3KKlpZI2jwe2LZDbDH78KFckJ7Iv8m5wEyCNgZVOZNKpVnbL91teEU4wdCBFQ0fFT7pEwye8bc_0v5FVJlqJ06ZJyDc5lAmHwllqJpRMLkZqSNrdgACU0d7tvAw8rw8TO2WXCZg7aFflnZWJtuUmsX4s-d45-qE4ovkKD6yVfB1k3828ckJ0xvfTYKzsFzNIVRvZZSB2vXxfg17pDcfej3Tr3JsKj59QWiOwiDi9bYLTsu5hy1aAiMa-gqR66CoZpnSY8d54MwvUzPr6oT9hAbISnEijwcaqqOLKb-0x67_ITJWdsk-xuf4ZFRv-Be37pQzH7rThYcb83jWqJiU84Jn9dyN9Sgf-zrdOehrdkUhVriliP87MFTQb8iUbt5kW9S2F2TukiphAwJrfgAJ6c2zhHh1qGzelBUiv5U-rcOHngu8sVximLYdNnPEEw60Ztnhs3U0FPY8LKLNAiPHtigRgeTYc8Pgv6ogA1V3pLiqy17Wto0w1tJNA9rxelo2_v_6UhHR4HeLrVOFnJeeZ6qM1ek4RBYAyj_idI80N4YFMqmufhtZvCx6KRN15HYHadbV1P2ohIbAwU3lwvvtizxmjqOBwHIg=w645-h860-no
YXutZibFtVwI97aqwVlMaOoQmlmtIub2gRF9GAgN5PVCk790X_6ONdASWJWYwH-kNOJG_etcS-T-PS4diuNFl0LVWOUCiH_6psn2yMNl6oDi7J5mKRd5dE7NIBmLwhf_g6arSDH1pijSlchS_Usvi0J-jzAE1ym_Jjd1bxMzJh4U1ef2hyZywkHHbkNpfWX8SfErXxa-1XOigPWhy5YpsvVBPLnm-NbNqUELykwgXB-pCVlxxSfSA5uNDx2n9VIyy6ThLoYtfi0Sg2wicYF2WhfZq0YYJtyxYZ-fGaV1RaOYhRVBeGvx1D_jNfJBUpxLyhNjzfljucjnFTCgzT1lC-XDnNCSK6RHOY0TwB6TIgulVOg7t126yA8I9RDRQ09Ma8Z8-cSTClxKhFA2mnbz-UgVJrYY7q7eLKWwIH3Eq3cX_uUlUM7z_HV9_IJDLhAtMc_vxTyopaD4wnJ_B5olh96F2Z5XVyl_2A56sYA-uK-QvFNpw_CKqsk2VlWMPvx8Ip6WtOP4OhyR2dcvEnrqwZpXw-gCxPxFRYj-aj-uqph3NBThVDKvKB_c2hOFEnLcgZfnhcALUzI-W7U7DqfLFICDCg4HgxjrPvAx-k1BXQZv-qw7sGCbvQSGWnpt6A5_ekDDx6RcbO2-7GoteJvqshJdoaSzWTruIdB_7vFg_fijqYNI-s7lL7JwQSn6eb12ZuFbmYBOYRdnvF4fObRjXMhDtPq4oH-Y09faU2YvDUswQ9gLzeFt3Q=w645-h860-no
Indicator LEDs are a chore to change... but worth the effort.
FM Muting (AWH-39-A)
Capacitors:
C1, 0.47 uF, 50v, Electro (CEA), 0.47 uF, 63v, MKS2D034701E00JSSD
C2, 47 uF, 50v Electro (CEA), 47 uF, 63v, UPW1J470MPD
In regards to changing transistors & diodes on FM related functions = elect to retain (recommended) - unless you are good with tuner alignment.
cWyrCrVuqETpx3L5wWn3HL6-tbGLwsvwYflWnbHcSIHpM2gkSLNF4edYH6nSVlnlcwYrjM4_-qIwCAdLrM46Sq_Y3ygb32KesOATruMU6j_PxGnRWR3lu2luQ-ek77qi8FkRAGN8Y_Y5DK2XpPy_qhHV2p-pwqAHXMtlnT8p5156xSovpgXVEtL1a2QPcJMG4Y4MC3QLFpKtczrW9Yw2tXtNCewUYWAig8T9qpmnbZ9aAFt2oA3RUNneqnnQ-kmQCBJU_m7qXT9B4OQvm9L56etyW3gTHMsyfApiYCVz-jOIj6EZjYHCOa_OKMSzBx3rdUk9MZO57-0llcylRVgPcKTIB9R2vgBZjDxdmENuPJoHLh0fSGTAWASX9vHQVOWabviDYCOiIVfKVbLIK30PiLMUugT7qyhD4seOXrpVyvrS1SToZavVQOa1ieSTgzY92vRvjxIMFZzjnfCch8SD0YvBfLBm7sAharRa4XdVz4GG8qe8ptCZkjmWNZwwGl2JHi1wPOKtB-Rv3qvBUGsaOGSmyPi960_TgZvJR9ufupakqC5Ig4icUUq4FCVgonrL9ElNQe1hJQeGuo11Esyhtgt81zT0WXJSO_WxAy5N8RlOuOyjpEoVglJWi2qT-WV0XcgHERw7yx9HRDX9ejnMympVvBFzjKqx_l1l6Aypl-JvxUJx-7X68UT-xPb_le4fWiQJK4xJMYqd2Ox2DmqfSGAkqxiaku7JHzZdzqIgs1zRjGRVkZJeqA=w939-h680-no
XuiQRu12JEJ4tfznuItyO2E95G7vubwSd9GaqmVrtALGe_ozjCFWxOjQzR-nF388bDs3A9cIZe8gBocAo8SDgGIIxira8Oxoc2bILLprmeaK2pHXStYPXwmHEVYRwO1rXsHiDWgUE951qEjXxeaS1xSEQVuP_MH9O813YXYTqjJqkmWNnBqkMMiCVScj2sHT8hjCjGnqya7urRleGcTdg3v5rT0GSYpDJAn7RlpEkMeS7CSq3N1bmyYl5RIJWBtY7V8tXCaM6s4DVCSZSd3JRIYvQVsYn-aLTrOM--MlVjbodTx8rf8KPtIS9ZOwyK1qtGAM_l2SbBGKZDeovdPw068eWqhQQWcyVYq3E5UpgrxWxO-MdEUzTfuuMypogm7238XPncq5FDWeCBknVG7HTv1hoGAUcVCyrWlulDxSW13dOxfSZVrOy6cQUA4DuBQd35R5g-OKD0idjsQwheYIMLQOzD2Zi3h7JIzSL3lf7YL9je6YpA3Pc_lyuweR2pesCltreGRnZF3oBqFPH6FnXtev0oHrLIG5PzYcuNnYYvRMnBlw3db8IdsCUJIsMwPepSHE9FBE7NqXgJWdUG9NQd4_MB-6IpwTWBhw30bx6AAkNTB_wObOXQwDzmPHoLJbFS43jJzeIhWNjZFw6gdKc_kuZma3p3Mh--cSOSp7Xib3pLhegiK8gwLVsl7x9zee2JXuRE-Vf4LLtyZ0zLvk4OvP1v9sbQIRFoR3JSbLHtTw1FPYKSIQKg=w687-h657-no
r9iK62zG7zeD2sMov1LSTuGUy87fzoTtue2SNb00uSgH4vxgPBCxzq-CeDLCnx68c4oUbl21cOuFk7uGT5weesbAvDGVyQx7qk6ePCSkUuZcASt_sVSbY9XmAjThpwROvrvpzwuRty1N0waAGNNESDFcS9aRNTGgE0SWQOlTYNdnmVThWYFqKydlVwIozEN_4Hsb-pbMcbaAddmAcd394YVqpGF_etFjJu4sWLozo9ydDOPEVAW85Pca6slClwvXkJsJacMnkB_9RjhP3etxRwpMeUPtHyRSs-_PU1Pf83aaZczo2he9yTGsJe4xKo_Ji7h-NepNNNjFXiNj6VXQ1g6ReCCl5e8tPeZ-zoD1-w3pKynabjhp2QpLLfJYiuIPQ_O3JMYaLehp6tBS__U2l-qE3Nz_J8-rxadRzFxxHqkv9yEpgWvJ4BDz3_C9mf-PKc8HMLZebExeNbOI8YqOAr9E2AZ1xXFXE2dbOln0YeMadLGFdrR4ky0xwSA_cJYGo1HYvl2kQ7waeExTtzUnJMaEfD9loMOHlk2wPiCT6v6h1BBP8p_3RrjvJ8-IcOnlDhmuySJBNrRiq3YOeySRDra-Q69nddpG3NXkUiMesVp0KxgR0MWft6w1RpSxj3szn0x0p5I77fCvVj5YA-otgOVMfqQKKz27AJESeonBD6LPRV-1eqBAfLigdXfC0ttXI4rmoCwUtl5WbdhybfMcKLBgZGpWR3x2s5p3Tf6EJk3czZXK-EfNPA=w645-h860-no
Q-Mlz8krAtT1S8De-J1CgD3W-2VJ1mWUsz-lkSMyZnb-HJGYXcH9erQGngveFTSLt6BZBMAaSvqowyvZ-0uFPfzTqi0C8KBvb9QHqnasWATLVqWkh5F6cAbyKLzdFLtJ_-7bFttsLXYHT3AZ9vyFPSNOHPnP4RGow4timO8fv-39UPZVsWhqO2GH5n1wMi87b5gDsAQ7HnB7WZuMGZAfd4MjosEAOQBOwy9OfHmUn-wXzYto9boQeM_z9CY1R0yuowpFUzFDpNmsw2Sfche_6sRBoDfCABM2QwXWLe6eHo296nLvTHifG4yROwQKMMLtvI9njCAFNOtx_f8hxOdZYR7jjGhLJmc7e6oPTc3QGYiyK_UtSxbhj6KpH6m4VwshkYi27j7bdd-jgABK_YtESUbrh836G2AHroNKE8hgZ4ZdRtvvHkpuwP5kFkmwwJ-XT4OasOFpPx_TYRm3OroY-q7CSnYL1pw-fpL7DdcjbDn_ALHSw3eD9LmvZ5YTkGHjimlw0sljr9P7onBgD_Sn-QQNE7bQsrmXJt73J6J8XM_vhjb6J-UjPMn1cRcC-kLJGgIIQrXVxMTDazBp3VK2_YDs4LH7si0XLfa7ROG5ZMUsnuR_CNotE7-wImsEJv7nNLtbKgumeR96Q0LBdMxB6YH8Pvni_X6vvo0AcO4Jn3K0rUQT1mo0R6ranq-yTz4P01kOI4B61MsYZEpIEog1ApXXWI5X-87zclcrVkUXEo5IXSs8njt-kQ=w645-h860-no
Equalizer Amp (AWF-013)
Capacitors:
C1, 2.2 uF, 25v, Tantilum, (CSSA), 2.2 uF, 63v, MKS2C042201K00JO
C2, 2.2 uF, 25v, Tantilum (CSSA), 2.2 uF, 63v, MKS2C042201K00JO
C5,470 uF, 6.3v, Electro (CEANL), 470 uF, 16v, UKL1C471MPD1TD
C6,470 uF, 6.3v, Electro (CEANL), 470 uF, 16v, UKL1C471MPD1TD
C9 ,100 uF, 6.3v, Electro (CEANL), 100 uF 16v, UKL1C101KPDANA
C10 ,100 uF, 6.3v, Electro (CEANL), 100 uF 16v, UKL1C101KPDANA
C11,10 uF, 10v, Electro (CEANL), 10 uF, 16v, UKL1C100MDDANA
C12,10 uF, 10v, Electro (CEANL), 10 uF, 16v, UKL1C100MDDANA
C19, 100 uF, 35v, Electro (CEANL), 100 uF, 35v, UKL1V101MPDANA
C20, 100 uF, 35v, Electro (CEANL), 100 uF, 35v, UKL1V101MPDANA
C21, 220 uF, 16v, Electro (CEANL), 220 uF, 16v, UKL1C221KPDANA
Transistors:
Q1, 2SA725, (gain match Q1-Q4), KSA992FBU
Q2, 2SA725, (gain match Q1-Q4), KSA992FBU
Q3, 2SA725, (gain match Q1-Q4), KSA992FBU
Q4, 2SA725, (gain match Q1-Q4), KSA992FBU
Q5, 2SC1313, KSC1845FTA
Q6, 2SC1313, KSC1845FTA
Q7, 2SC1313, KSC1845FTA
Q8, 2SC1313, KSC1845FTA
-11kXO5nVRMEXk29sYJhA_pzJSS57Eu98ZbVPyFjAhMf7lsc5yn-y96Y7qiTgxkGXsrswo9Ab6LMfeFdZeUQ9mej7_ru0x2zzZmB_iUtktd4yTmI4cp8EKZiV-ZhAYV8xh8vBB0Iz3v7G56vuz39Gpx6_Qbt21_pLG46qSCcQXvNjQbjugwQ3A99roHJELj1ADWUbhdvIFhkAnYvLaFzPaTH13OfOq_Cr1adJm_19s3_MqPmU8WW8b0ZHr-brL0fqp5gNYfo4hFc4_2CkkBsIrtLxci4jg2vDSzjaG9eV2nA6kD0NpaYoIcggiuqpbcNx97QcxJWAFdhpvqAsvxRYaMAE4r5TcZ52cmFRqhNvRwv301OKam4A26-LaZfoMssX8-pOVhmzaWPqoUL-Jf9Z2lAWvWy-dWHO0_ZZKaXASCTpmghlcIX5Cqdw0uuNeC0IHY-wRYwqdchouwGtmmb-r2gyO6VlOQwAQ_J6ys6T7EiZZCMR56-2Q2payXG1sMTmgIECpcH66q7eW04livJPZe6leMY63gNgmDDSSCfLx8kHvWZi4M7IERgs-dxwe3jHnU4gtEJ07RYQ_zw2lGJ48yG-HtJK62BTijG_gmVlIx0MTw0k3cLjnt0LN9UuZpgfE2y0xudlVFVWRpa4YRaWlJoV_7Il9SVcYIz6ockNkIfQgQ7wnXJyHyKfROY2Po5IsAsaoPCu1yXJk_bZgktl2tAO1ZEVVAm7RGRLgXSE7g6a6_urUF3NQ=w903-h829-no
g33La8cuCUIRTdtRq7Jczr0YtU7SkgbuSeCcz20tHJZ1US5AT5umNyYEVSXeu3F9V92_NngL98xSMAd3jvtWSxVEdB5HwlpqszTKqULOlZGKtrrfssT57WV1L8UAzwe9JQAopPPJia_WHtGUwJY6b8kYFPN1essNRj6i3d-Pjp4wB3iPV-CBsaJOY-TmpSRFsGMo30LnrVfqrhkjrnNBW-LoWsOL9s_3yVPxs-h2YRSlRzJLbnAs-1q49ZI44NXBdpITL1vw186b1Bv7tHBq2AeuCXw6TIhCCzTHtxQ-u5k7i-eiNJLgKEpS-_nSQc3APOsOHOJbCr8QYzIySAVD_-rGw3xSpFdQ4OlT71zWBOuEvRV1WmKWjj4tXaJNq1kLVeFZ8wlOhoNCGblFt7xjPbHjjMyLvOHxuYeQPeUyUlaFLhEUpYIjDGrmICKEw7HfGqkdBacsqlIn6L0dYBdCItmwqwqWVgkWsdTlYhfvH-2lXBw8tWViWvXQaB7-Ty71PydaxCyDGqzNbjHtOIHFqY43URY9OUg4UUfjSU9kyn3EBOv9SwDbz9gKUwWRmXAiOxRFSaJqLcx4f06alTMwvaF3iXEXg8mEhxEzFHZh4YECDFZlvVvUqji_ksRXaZ4xmCxvIAeVihwhYWM5Wgesr5uXrL0NpMILWdHyVy03-ctv4tUDR3Y8pjYpvkJrShFShhpfxUexB0qgdewjRhHJJ_xNyRQ5CKFdxf4hD2u0-hH6At8H0FuuQg=w1070-h742-no
o5bQejhChTU1SmNy-J1yrC2qHdW7-rXRDGlya048qhhxgod6Y_7VttHz3izs3XupPMXgLACy7PNKnlU_AvQpA6IV_I1NUBtMb_D8kjZHivNhfwUZhfbqYvF2cbD7ka4dU4flW_0o9thEVZYj936qCPxUexDo_LT1g-9GJIxgNxA9ju5MKDngV2Dqz6FN1Xvk7qehph5sWWGlZLxs80pBHm_TwKvEnm7l6nCwqlxgFLWX9VUtDZZQCwPmTOcGtPAWS5AXQcu3cNPgMFg9l1Z_EQoEzAmkVgVhwvhJHc1EhZtw3xsNtsqJQeyXfyyAm1l7lHzXokCKp6Z9KWGRugrUbnAZ-puM9FKD8QdI6krf0F2TdLy8dnw4SCLAsO0JhvISuLYx5XD30ZCp2zxlFuw7KylrT-hxH6YxGhP26xUAC10wq63MDH5wMWUlHxV_RIgY4g_WTiZQcn_sxMkF7GA4tN374w0Px42--IHBD--EGrelxUw8LR7QEz0MPjESrn7PG6AMFgYhfeK-YPUjf3KLGstZWz5DllEJ4MijLjlJ4vlNIUrIOi356YQdHS-BSlSPWwx2MMGoBJUNgv5sHtVw-DFH6Q5D0miNVBZyepAC2Q9-HMPdAkmmFZBOFP3nCtEQbqS1ssthN6aBxGmjsVw9HM14R0SLV6x6K7EKq-aYgbBupM1ogR7YRLkKY7DjsbJWaB2rDi-bPykSec0BFdoXKR2scgRdLRUGTpsz4dqp3oufY7kxCtXBHw=w550-h754-no
QS0gcpkqTTIZx3CY0gdEd9Z18Akjosei8zL5_dRBjPgoqIxTzkKs3W8O1oTlYfEgz8thL8TzVcTNEa7mJfxIlvN4kCjUG_rX9MFSifQ2QCpNAQ1_u-DGNc2cE1NxSiEn-9YG9BrzAljcgpjPOCThJDdy8rshUmEnnmM6aV_2wyISSANlSDPqyBWvxYI8xQ8BOXLhIKAN_ZCHArSquXtVpPyl-3RF4S1m1ioeookd80iL5r7jpG-J-FKg1RZ1KH1YbJ5JfN7DQfiFb9i9_4rztxI-cdjzi4yU4QyidzYWJUBDy4SoG4urUoZzR5MNSKZSJjA8EFChFxK_4aJ8zPs7NFfA-JsZFVi5gEg5iFJJv2WcePujYsNQiR-Yg-H5dZY1yKlQlyt1-Ngxm1awXSkl80s7ksiQDLCuNxvCvTba5hhawffno4bo_K4RKB00E0J4y7_pa8XSPj8ilLy4e0jl8H1WuKVCIEhSJFwhLfzmnbUsyk980FJlYDeDkTkYK2W_DXcx4y9ForIBP9YDEgokIKDPAqyRLfS0ZmMs_ttQydmSUUV7XggH4WZJTrt2BFFqQ_hyVtx78nOJQWhP3sJX1fmi-S00_IVT_-41BMYQhoM3BVIjwL48uvspRLmm_NeEKVADVKYYo9UkiNNIlyJq7pR6dgu-xO0BDn_2QPTngExrw4zQUifxgobwaDE6QyqWBM7ivseuEFCiBaDoOB0Khb5HNm-msc4DddyQzpEegGM97cRk-xsE_Q=w645-h860-no
I8oKg7u8gGWdVrmFryKqvW3tcj2EYt51WovGfFbkhnn4AX_kXtFJzHLlktEW8ywE-KYWoxmZjMPbU8-q1NX_yGZAfUBuWKOmBFDJvyfQW9LiRcEA-eMu8U5C1asHqaxVRgcpXgkIhepWsbCco2odWBsV-WGKRFUpByrJTjL0rRFGWhK997eu_SZOg3vkmHLdmhdi1tQQn4gHGHurBvg2TuRkK9wQvfiLo3-lPm1-Nydc1fMHNO2C3YDqG4tuLuOa1MU_g4Kkejqzt3gfXgzAROJit_AOGl064vk6OV39PHUNnKIOBtMFQBohJ5-btY0I7l95QN4KIz3J3MiGmzb0f0_s8_Hm-vs1-SE-iMmTpBUb_pcldMdphzXBk4psLD7MJRe7azpQTQZPUpjP_YtYiD-yvnv8JKxKrTMCHv571kj-BA8JS7G5tTaYZ09xMucR344V17smn9IEmgVHEiXJZt5S7P8L-MjXJl7pd4FJK-4awMxa4-9JecKYzM4Ito1RYBrDrPlJ8laDRQlgIqdty_qdBodQU4SlxhgkHmxXI2jntqUJyUYatJSXES7S9IGrCRhgAsrmvVWn6lGnmAqLZRykjRUKDdZAXBeIo1yX-4bnFIJDlatu4I_qsLDXGg1eXq6imlkY7R8UJVEW4YndIavnbHD-pr9sdICVft5zKn7rfTMl2O4n9ZV48YUWqEcbQGbwb19FnUW401qevhfNafYES--agELnB1AQ3y4aagwwJIviubw30A=w645-h860-no
6hLmCudw4XSqFWES6qo8nfgC-ayMnmdWSYZWakcLQFuqS320KaI3DJ67qzJRRpHeX-q6oIW-knhJIqpKQ1cuqHe44AuwRkFguDSWiYtciY-8Zt_DcZ-7_Tg9P-ngzSpnTQTnTUelBp_4em6tSDS3y5XnyZhhfLVBd-XhsgJB0QYmLGxME30WoWzWwV4gKXkk3f7m3I8YDZmbz4T_pyM9-Ip6OZC1AoWATq19PuiOZogsWMZAJzdVDwGyIJu80wkrIO712v_M8Ei-ioSx7OH2SX9LUnOl0m69VYacxrHErn9-r82Fy7Up8hMK4ThfxxVtYq2Dt5e2N820Pew_LUOQBRSefnWm6aEglFWR_h4Aiazq6fWrNqHd5bW1vZ0sIEI8X30mEHP40-0KwnRwBaFGatcp7SQU5VxcJ9MViswSqhaowOW5yttgATHiGBTQIFZgp6W54efKI_qY3mOW450MSp3CiZkfhKdN0-UpMOnBBp0yyymjxTk0qDOp91wzi57jO7kp3wGZhEt7RGJ7jgNMSP9WBTbwrJYy9y5lKvwJvISZR9CNQPs_xb7egt6QYLh69ApCFM6J-EaTVCWKfoOX4FZjsZN9ESKKCNL-Kjj2Tc5HMpYU0SLk7ALxXxuwJI4oAXJDSN2sWGSBlJWrHRvka1B64h7dS8RO2MVddj9j7zLdHdCDlx6xClr_W-tpwVj09HR91lqnV7QgAhG8E5TR1AzvNQ03GQNjgvwj7xMX8qToq75_o3B4DA=w645-h860-no
jjEPtTB0KujvH9I7VHkKX83sebcfnKw27e4aL3ojr-4or5jjZX6zwOIekDOhftsmLeXf01zFs0kWucpZ0X3DB0R7-pqzW-52GSisg-26tCSfze-H4Sy7OPkIBeu_QQbexIDIe-s84e-hOalIGy92pAduebOSX9QxdSS1Bz9kKXD2zJt-32wbv9QApzWuivWFmW7LBVHfGZRJe9RvYm-2QWdFLAmHucfZl_J-T0ysmwJtXz8FzsBHS7EPhoGdsd0_nYiaN3vnXgndU6JR_2jf5pZR1AbrEJ-Pu9dzydpQAAHEgTFSouX2l2Mgdeeu_MSeygTukipDPvgotW7GghsxBH4giylPIUNdoTQy6rzDZNHG44zLsCREi8-MHgU11vYrPs0DyJiJx-KqQjhPv8R_M9HqMOkVl467V56dGBjsqn4B_--yOysKKnGfAwHBD4msZIaCSVtIqKbSnWVNr_Qq3xlTb9WzDtp_r7OgAYHhxEjVo8ilGbRtTtbYZ4STE2xxfHHPfPD7bcW_AuyKd95DiLPmUhhzqYzDHzy5-E-_HVxWktTsNVOiBUVaPRJxldHhiA1mL3rChRh4lsYsbAt9H1IxIZxX2XWOpDz8BM3bidmCFqVYKFdTRp7UrKEKAHhzLUp3AB4ZpGtpNhmcQ5UrVy6Rdf7CKZivv5H_IkuOkOAxQA85xXQ7KHqGmThviFkEcBRAfPdPZys1WJDLQlcYUtw05Fe7c_S-FgXoVgg3m570YyddZrhrEQ=w645-h860-no
Tuner (AWE-040-0)
Capacitors:
C8, 4.7 uF, 25v, Electro (CEA), 4.7 uF, 63v, MKS2C044701M00JO00
C10, 10 uF,16v, Electro (CEA), 10 uF, 25v, UPW1E100MDD
C11, 0.47 uF, 50v Electro (CEA), 0.47 uF, MKS2C034701E00JSSD
C16, 10 uF,16v, Electro (CEA), 10 uF, 25v, UPW1E100MDD
C18, 1 uF, 50v, Electro (CEA),1 uF, 63v, MKS2C041001F00JA00
C19, 100 uF, 16v, Electro (CEA), 100 uF, 25v, UPW1E101MED
C21, 100 uF, 16v, Electro (CEA), 100 uF, 25v, UPW1E101MED
C23, 0.33 uF, 10v, Electro (CSSA),0.33 uF, 100v, MKS2D033301E00JSSD
C24, 1 uF, 10v, Electro (CSSA),1 uF, 63v, MKS2C041001F00JA00
C25, 0.47 uF, 10v, Electro (CSSA), 0.47 uF, 63v, MKS2D034701E00JSSD
C28, 2.2 uF, 50v, Electro (CEA), 2.2 uF, 63v, MKS2C042201K00JO00
C29, 2.2 uF, 50v, Electro (CEA), 2.2 uF 63v, MKS2C042201K00JO00
C30, 0.47 uF, 50v, Electro (CEA), 0.47 uF, MKS2C034701E00JSSD
C31, 0.47 uF, 50v, Electro (CEA),0.47 uF, MKS2C034701E00JSSD
C32, 4.7 uF, 25v, Electro (CEA), 4.7 uF, 63v, MKS2C044701M00JO00
C33, 4.7 uF, 6v, Found 47uf / 10v, 47 uF, 16v, UPW1C470MDD
C45, 10 uF, 16v, Electro (CEA), 10 uF, 25v, UPW1E100MDD
C48, 0.1 uF, 25v, Electro (CSSA), 0.1 uF, 25v, MKP2C031001F00JSSD
C49, 220 uF, 16v Electro (CEA), 220 uF, 16v, UPW1E221MPD
Straight recap. Will say it again... many folks worry about recapping tuners. Bottom line if the tuner is aligned, refreshed caps will not degrade the tuner's performance (just the opposite) = especially in regards to those Sanyo aluminum caps.
7v-pSEoIzRdTg88d1o81b1Hv1OefEU9IxW_62zPNYutr3PQp5vk6-HuFqczWalckZS_KtkD1w-5EfG-2fYRg_U27XqMZthEhiSBo28V1WqvF4lBcGsJkavzpQGenBZ_O2w-JiG9si6koQYmhsXXVxs1mCi9h3fQp6coBMJD3Dd7T2h5ZVlfW_HMT-1EZcEAMseqFXCeGeU26ED_CAIYoUu3pbf8x1UniamwUTPidwHjoZS8LxVUxkPEGF_odnuqtHbDYvHcTW0ELk-B46rZXIGtKhAEeBm2C1lehgz9pazqc49fgtbJAWgIR2CpIqYMgMFsIjHfmFfP-iUyESoHcLYqHmfYkfy-PbwvF352Nd9TZwYfk3aiOVJO2Lf_JT2cRKBhi5PpZLqgqlnNE6GsOnQuPrbGYisIeNJb-yruwxpJ7UxeV4OXSUdf86Ud-6f1Oxz4UJUfGAk9xoVycFAW_MFSAzZGvqJNqMamkTHEUsqOKLZceJGB3XOY_TaSU77OWriGo636lcW77AJYvfB7i5_5Ggw9oZlLgns9-jRtSmp6lnkGN4GmQpJ_CFOUuqkLQg0aSUDS7jHrALiJnb-wXVhtZR11Cnoh3egyT3AoXQ79W9mQm0iNnfMLSkvB2t6Lc4zk0miRCFT-vmCTSsl1iOUZ5yjHnSvslkX30C9opyQBnZUEAOFwEd163B0iSq3jw8Qoyn0DoY-ey8hXlMn4-xssL0ppJiAxRLPHwa-DXiGGolSZ3vz1o-Q=w964-h518-no
zPjwN-VLCMlh-YZZe1feNfAWTm1jhIpA8rQaMCr1jsXv2Hq-o2s4OhMuPOYao6MiPAT6fd1mE6h8vRFQrUWcnZVd8GAM5RYBZDgZR-_00Zbq_ueIAncbJK09QzLPsulNjSmWk6wTaBqcIseHJPzvtw2J_wxI92cPXZb-JQDcT5ttVz1bySCuo9jREWfaufv9odrUvuhhMQlWrzZDyyPYFxChUOvdFrhHl9ftTpGOYVMV2_8DWVK_5EcyN3NNGu-P4JoCevtIzw1jU2oW_A6Wpbyp8ADJeEq7b6q898s9HepFekX8l6jhwbSFCvukogK3r8gJwTXtfmxuRcs3rPcFYpTSjwcul4dvwAq9B_1cktdraB1cK-BkeJ5mtNSSHgeaCtQ75wHXZ5H-AuqDpRmN6B5u6IrMrS6ui-ETOhO48oSa_JUXo7LwAeF3VzTJyu0C77qsOrwNBI_8Wii9KpxNvikBCvQuY2dRbq8oXGkPcuI_ZzhwYfjl2yfwyQ0hSvYq5mDBZz0FYHioxcxp5nMeMmwO3JNrmNazhFhfJ8wRZXAXcIZta9uXbMT7jKvo3Ei--vPIzJMsTpbdxRmN1iV1YC3Q8xiR-XI3u9NCdMexlRJUcmzcb3jSPTHZitfo3nCrNU1td2L0nJn1ii9TZKbfpZXP_dmbYDZcgKqj1BkNVQ6xWKTQHVVqXbg_61rI1P6AjjZt_mPEpu2t8uC7LYTWhIUA241Gf8PveLLIdUEO-MrdsPK0XdxhQg=w645-h860-no
iEgcN94ewsqbSQZ8AkiPNkgeYvNwyS9gnmWdVyU4lHmOgNX21NSwUimdVvSb63OvIFPEbHYC0vlAA23n40VhrfKbLCKUYinYgPQ3o9QlftxNuEq6LOAvxhVXVpurSmMvYMs7G5HjsV_3Y9QowHzsshNhee3RqoiF20nuK70vNB5QkV26ZDCvUTt6JM65D689QMWfG5RPScqpmdmkjxtYcz_Kj890EtpKcM9KTrcwDNQVQhgtsugORdY1hxJQqMfUblSalEnOwyS8VXSzQ8FIQrhQb34UwtQueEErjN8RpYZXz2X6XVhqniVB9U62vH4vgQP6rT1Op4-FjQxxOJDfKQCBolFJDt4QVgQr9Vw-wnrDTNiq7y6F0-7p0FhAk5U-r1NlmtEuHdKWDM52n4WVEwQeOa3Mi-8523omQ-bDqkmd8lMK9gNTMo-3uDqWOk_EI0emQLI90dxTkZUa6QRfKyDyYvVE_gZsZMEoGlV2fQN92wrdS0EbnYdDi3DM9xawV3W6n9ZD4hYOdiUvtKEh83jP9LSaZfR-YCuxcSuzCH4MgvA5ejvJS1fzPBBKlA0SSEtlVpDIEoHxlHwkHzTlWAq993d_TNBWTLqYycwQvtAzhf-PAHjTN8XGicC1DgpXlWDQZJpDriAp_rtEdu4I5Uj_woBoJkN8IniD88G2Q7hOqeGN3jix0tylVCQW_C45Em5G_FxUZfwKK-bX7Oz4wlcXso97D3SzWJ9o2VwrmDQjM8lCPLrIAg=w645-h860-no
ZfNnKVuccThKYQpCKtFSGkGG4_ffSL_db-1hwFH2jBaRjsllV0IQtvjONZ2Xp1HmF6NznARhJ4ltPObowoLy-Q9Y4DrizsW3wTaFWouY9k658n1cjVmVaC1aQo-Awjyiyd8Osq3IvlQIlwhTRtEvmqLAq1uhfoFh19yiFgy9-PswIkDyK8LlxrTkK5wGt84dvIQOpXlXCwlqUnkozgEWwn8XQe5bpf9TQktw5s2LtzMgk-VRFqQVS4z-KyXWjvkttaDUYI7y26NekE2Twst7r6pzSTDkxKAw2irpfTzMzQ-aFTYrdFKia4vijwxhpSJQMiy6vXv4h3HlM99TR4EFRo7RijK10oHcNGE2JIEtKc9NGqIN6MZnW8IGE-flwKJpgjLt9gtHepEsp3cl4T1EFB49sclxT8TODCcfYhGpB3g1_JpMAcAIgyvHBH9Aj3WENpC_3b_am_kA0H8bo3fO0Jj_JbKMX4xVK30ummLY48u4I_u20jWmGBSYI8XYA5MEUDKyxPWB7pqR41seFctlKKEploGEdMk-S4afZnzJYUuM2QW1yC_RjULxwq_57h2Of0uq-6TtMy2lwX0xYZREPMn3DrCmSzYQhY37mSqBn2hX2szFy-mPL3fn5KxdufC6XDbVz4Zbx8NW_xXpVIIAncEBNwI6H4LG7WdP_I5YqqnLk70u8OmmdkxH0Ban_y2uwSq1vXrn9TXKLTTsUG97S_WIHz3I8js3zBAiZC1MTh4FDFpww05N7g=w645-h860-no
N_zCRon6gSTwRUtrRaUWmgKmOL70paXru3q9bJ6H-iVLBWi9IIBVpM2bW4odJtCtB8deXnibSx5QcMDxoG355SheY-Gtxz9Mu3MQ13N6zqyqmDVL5cegJpP-GTu4I9MpPdm8VJkptAHJc3AWQy1_IdnUBLsp0UAUNlanLvWUAZvq6RpsGd73oYdDLBMl2qzHOJtAzKe_eFdNGrJNASgWlKA1A8CbynUY5WGoAoYN0b7JCHQbQ5aTnH-Ndt6kOTAsRQv_KP7NcXQlokK413TCsNgmKm_GQtJar37Y3KfbMwblnoPv_LJ515-v2FaVnzw0DfIOtAaGJeT4YLf8YBybHQhAXfatCDJcor5J1RsJXFvebZu_1nwk_FTW2vzL81JprweoESuLyODzJ-GhTjJsBBSaigNI6i0cIJ0UBo0I7l7hPXLswaVBEP2fDMlCAY_t5UDQd31cq4yBfCI-TpwiYBtn13-uNpl45Pb3VhzymQM0_HHSEg5xle2VJqswz53FAskUJhNsoi_RlP0t-CAcHnF6hWTE_ac3W0LShVL-FwbswW6fDtK8dx2YCclHBA6rRH6NGw-2FRP_obNC3igUe9eeb-cRUkzhl74aTdEddkqhgF6Yr7jMTWnXulflZhhgX83f7Jn5tzL1sC016SY8h41geAH_D7JRDd3utYbSg29pMt3koXtNidr8b9_c7fVkXsI0i2ng6MxPQS_26mSNHnaO-XX7HcDsVOsqyqcCjO2E06yrhwzzqA=w645-h860-no
Okay... we are getting close.
PRSpvHAWSvD3Ywpiik4-mRLaKoDLQPqt8gPrAv0Gx_w6fbPo_BD8F0anTjUhYYQdAemtxcRXu4BXff7GLtWqqDYaPZYt7sZMFj0mJDL9L8UxwgP9niFF2tIu9GVpOJZwmTHHgV_8jye7haU_V0WoVx73eXC7acYzmhnRwPDi2eHnxv4cXR8CheUwfT9cmiUY-rqBDRXohbkjyVSAoJIm05s-Q1bvCGB2DMIkDwbnZM1KP3T5cBkEAXXEowkwdqgNGFDmlXqtVD8HmzlqTmk1-wT75D1DiQiFzOcHZEhY4ApKrh8LhEGhY4jlyN6KiJJVQKRnwWEZVk5IyowWUyPxBStB3FLucWZ2W-M7Q9oRG9QyXCOR7mXiU42qwWOIK6m8MMS80rKBwrBFT8o4fDjzaJPPo8aJwGdA_NMTvwURq5j66_BUBqOhKm3EBIoauWc87R78dg-uD7t-htx-xtUrY-6HgEPGIGF9gQ5Lz0_utEXV5IzWNNuiWvfx0RJSYtqanzQEwlV8GbUqbqv_RjUfWSglbB6NFtmSgtnGd-C0E8IohH1WsNBEWmF0PYHNiMgX_R2TgdyPMnpt28hGbcn6dfe9Qmjc4b7wavNSh7fCdpv-qnpUmYT2JKkV2y_6Nv6pTM5UD_f6aTmKmt1eB1eDlCK86AcNgRMP6KgW6a-X1asAjdfDwAqUx0l0ms3LxNSEI6Xdv2A2nZGw54cJ0krXikp0tDUmP7GuzlkdnCQ0ruFYcsjUViwwVA=w645-h860-no
Did I mention that the needle was broken and missing / as well the power toggle end is missing.
Looked on EPray and elected to try to fix this basket unit outside typical methods.
g2h2CGEi8tAonKdBpFZEPupIqtXFSv3HCvmUmoGHV0vCf5Sdrhax8qzhvo9ro8YRlQdmZ74wQcp2NnlL35fyARqvXhcEGkSt-dHfkbevAWWIB1wdfxF4lMR-JhKHaAD6r_NkkjuBy_X9HKao5NHtm_tQ6OhwkDx8Yyy12JIMB3ZJiE4OSeAp_l51NSDOWhhSbBIAWCKjC0s0efotcbAQrC4LVHgti8_3Ck3LcwS2DSpo5efw7SDQ60fHDsJkoF8uC2-jn2x7oG6Lb5UJOTRqFTUZ9g3a2T81qMyE5cyNO6zZ3HruMlm_-nbmRFU7TQWnV0ypKnMyzV1KDXi-Fmz5E451kAlvlnRu0l5ij0IqVGSkrLkvKx5hUFJN1F6OWRzv_3RsR9GJran-jQeMhjdXffTQl1srKbGHEsY7tZOvG_AHwZXjeF5lGbJY5qWZhUtac6o73xwU3Uy796km7SwvoVjwgKkDWohapN3dY-172C8bSbiicYPwg-mV3ZolPqyQhTwENRAugLf_UgtdaqLj5c-Dju1TiTYXkZEeL7mASEpQD3nCzI-3NeImgJPUXFiVSGn4cb3TBNWmrrO6L19BhralKBzsIIN1HuNqv921HGkrzmUDjuhbwemow4DzSeizYZ1xsHpdW-Y4u7ZbTA7W14N91-HymlURNrLDBcgzZ-eyRbz8L72QvRPNh6yHitIC3SMQyjKJgiMKpRFtYzDXYy0ZTmp_MZJLylQ3IdrKig6qOMEzjxC__Q=w645-h860-no
t1SYRmXTnAR2YH9wIsQPOb4_aIaEctHWyiAhJrLA9coh6m1Oft2BeoznmDGp5PkyKGFD6v45FWB3MHz4AQ-O49Eox9_wz9ehSvPtUkQImBBDKDtuI7Prmuq6YZ1wRuyUbbNWp_M1ehBgFbHLIwEv8Br2Z5FLzH56DrYc9HejE3KtQl30ya6bT-W7-m0rXJL4FlysqffqQVKUHU6pgYd0hkllrRY6VwGBv2kGfP4oDFO2BrZqW0c2TrqtaGQaXttmZc5nNMmD3-ayg-rT8DHIuUXTVG5cMkd5qJvKjLMvFKCzrUIljZGEdudYf4qm7-RjblLEJZ27GjAxvAueO-1hKUca_ScJYxr7j8RERrZG9rThu-8ratdwaJVb7btA6yZfO-NBULSgajqK8NiygKz0eoHq3PCbiHmb2PRw8IN0EYPOXSZ5FuC2qakhIRwwEAXk-_QBdsP1F5L2zaUi9t0JJK2KRA05WIuwQqthXJ21PmyetNxlX5X0XJ9llhefbgHS0AgkHgSQ2xbGpnGxZAu3TjbjyO8zUCFlIjxNJlI98B3O1m0eFBnwwAbzssascn0BuZKMCwmRLD6l2xe47vg22pnSGAedYMqrKaz-K-k8ZjNjTzTJMbjyQsKUFdIvZpG3eBLQjtDOlCEvAFS3LBhi4fQOF_5XSqK-s3e7Y-VXbQm62A1xNc2Pjz5kev1ssySU1AXdvCGyPzNzeO-G2wn9hkNkgA_T965G7kwPxRwipssBpZg33VBrGw=w645-h860-no
40zjTuGznSXQBl6cai_Ce1PPNScPPdvgyZTfOfsBe6v0bPxzstcBozSQTfOCNB03ADZ9jmg1o7mBy0dBsgjtUDQglWCIM7GqlfZaQ-r27euS6krIFbvdtD7rzVydge1ZLcpTWIRBIc7hVLPexYTDpleA0m_tzuyuNzNiMd4vNLTTKpWF43kWFZVvDMLbry0bNCIT9fZusuKC4Kqsxf585POKrhFJ3Ths6KWvDm23vIn1aH6C_-o-crstk8JpTr9ZeqA5zoK1NIKEWY-eoKMDxVxeCl2vjoKBNOgGSD4vqgTfLpld4yGMSMPUOuzgc30_HdLkoxZFllZvT2GBb8qZkaVdh5pmMSSmtJz8fk54Uad5aGm2LGUeRprvTnkItWyg6B3NQbyQGXRAfZ1B_XnxwFWu0KfvCym2omg5zlVOivBdj44hSpFfW_0t5RQeY7egpHPSJ9fffxQEHn0D6A-Mo1Lya2wgd91Fp0iOFHXwaV2OLSiSV6je7BPbOKeBA5r1YESXekv6RW5-SGX9-k6oxOERY_SzmtTrIKSKaHuf_ajUzkmQ9bCmE3U3rMQk2Qz5Lg9mrLsGf4QHv5RNUwl992Rh_2zwWr5RQP1Px8dy5QiZ87-kf6E16ZORLVX6zDEZB2eBkrqqtGUwN6sexcaiFwGcxVFe25E74Dkoy8nXMbVosbTlHpcIY82ofDHcLrlyA-npTEpB2vpYT6BMB7e_aZfBszkYwm1xTfxGudICmRpwZAZhjbErfA=w645-h860-no
W-KAwJy3Er6hUFusH5SIhJg24VTXsT7OOS9NTj4GrVpw2QFyVQq6ypdVj4xa2geikBuPm1Xr-JhWQFnAUTqfGTZw835OPrRG4q2KoZcd6Di2VJfW33df4NQl34Am56g1F9DeZgBwih-IQ4Am9mEEW6GSQNUL1DlhAI_LNd4bKsHqh--H0F2v-9yzYl0iZYjxtRbTzqC7FgxgdkRcw8oz6rbRuzMG2FgF0fI3Corus8LiFj37YN9HtbQJT04VxFlcHd2z5IYIB8yXKsIZPVqiLFs9fmkg1DvKF0gZmigLlq1-f3XaHY9bjMqqVeTRr4PPyOlonhTLp9i-qQq37Z6Nas4bjyKsGsTlk1vY8CyY5n4b2oSct1r6geWuW8osqDAPWJ0lw3_fYVJuGZW0uGtCznqEDDg4n8CGDFrJgWpym9_r3EMwZbVkf5aRFvK4d-tAhkGIsgkutIftKIY-7zeNJ6HYcPlz_qs-1DU5vcbO9qJFa4gSPIt79kN5V33LG0uH63cdLgzqnbooTLFJdlyqxJodB59WgGqin35ZWxgdGzkMI_zmULKlSlSkbAaL4QxCkli0DjCUQJdaJd6qbL3y0UfEGgv26Kt_QKYeShs6eUTBCNJeF4sdUyEE6JRMkHcb7NXFVyUBemRPlWzqpoB-0lZc33HXQ-jj2hK7iMffFvfZbd5ltbE32TBMVPHUGvhc10DquyNI-txw5Dyfh2BbBAglwUhLRgV0FScb1QH_dAHrdGdw_1g2Ug=w645-h860-no
QFlrtASLqEcTOMb5csIqG64XSnRI0ArTk8mm9Cd47QJ8KOoTKcTlX-1Jl1dlAIAAN46SNeCle_DrXOB7w8eV3UM_i9R7yu_-OInOrr9Uii28osFl2ORLVaeflFrW6gDf5-hUiuzksUdIqkZsqizLsaqf7rF7CVRotvRP5oS4raoG4glV8tg71tV8sxWmnjGfRWSgA1mebrreF8ho_ACymtGKp0TtAmDrDJnBAhuMDLDbLevi0ynxmJs2jmDHKOwbjgtSYlYDcHt_cmhF6jFhaiFz5ciEkc3DGQvGB22FeClAH7J8QXzIFyDPbyRsEbm4yzei0UJL00XV7XuvgShHmQLsEnqdbDrSe9K06BD7FYtTuhCqwG55Y1XQAozemO1ztWnkOGcZ-Mc9EUWUje5UzeJ75wi-vbtpmSFDyynHjUeq0qsmvj0oaYMuOuNL1qXoss-gA7DfgaTjFvHfPYSwVnYvibNR3xim-lzXuJ61vk8o2DKrt1OyIXAJG6Sw5CHoNT1OT4kkKgJ6K0nMptBGDeydNMaXmV0bvMuR123nYjy-CcmZ6jXzLlsakHt19gzC-IsYedYIMdOoLsDoTttMdgMViIMl6iyo5kTgGMq-GK4sTQKnlcaX9JiuXqPDznvRw3dG2tz1bjmaLvuTTvf9PFud1lYuYwbWKpfUh4PVE4mgIU_Qsv9f-ULJPHQL9O_rDsnepjlZuSkcPk94vUSfuAyq7miZTak0agb8j8FVQlAL9PvKvtv8NA=w645-h860-no
uAM7uPQrQRtLwmpGMmh_8p0iZUywAkIP09Lp1TasMKpBe_r041So6058-iq7feRAdT0fSZiSQRrnKRPN73PNWeaEHFiM_MC-xUlS7Kr5k40syVDiY_RdKXMRoLKb3EbfpQmlZy5TyGBzR4D2EGpr9lfBZRPUc1JSpyd7Xmw-wuU7uX5hZs5aP4z2t3Q8ZhdOgGHwsA_hJ_y_0BUYvxoB_B4mKC9wKSwH9BODZvaUDpVM2n1oi_pQKzpW4G-goQBZlptxID3CWPVHv9Jw_gH3U0lhfBWKXDzei5vCnFmdp657QHjQmb2qtQk3y4mLwK-3ljXfOmnAYyz7nxIOlAC1xY5bfzYWZM70WodIRZB6O0qwYOeVivsGv20CppwhkE6DsYIKA0-C_ClimjFffEiKxA67ta7foTuzP47pLN2tjACW8-E94sag8wSx9F-o-6GZvJF37o682Kpqz6Bo2D7Q2xy4zOJsjVKI0EJsgsFjZtVYZe9I3_q1ZNXcWtjpO_PCX-1-wKfJwNEnXWLvLr6kGsr4sJlTfF1UMZXHndJSKrT3aWx9qy_FjOnChl4kfMvsuPoPc9Ix036vYXk24z81r9dejHhp5FhbLt29bEJCX5RzuukSlqyigVwayzCyRD6lI7ibZ2sDuexqPGFYC4TSgzr6l99y1AZ-_kziOpOO-5RySqC6QL0oztne4KFxf2CCWV8-VpZigI1Zz9TUinXxGj2vMiyXjzwHpF6XmcPOg1c_s0KJR545eA=w645-h860-no
Not too shabby...
pRNe2DWkmxbpZzLqAy4oyY6SL9zaUij1QQOsBFE58D8CnIQdaG_GYeTztQ3eHbrvaF7CxdSiSyyQQeB_GEpenesahwXhMNEk4mySJcuGM7c0Z2J5pLKKS7s3aQma3uPK7ZQFnxMweaFCY3j6HPosEi0-cCndDOIRmCgYNmCCbnm9uulPO4hQz-jjDyCQgUf_YPcFLcAWxVrU6s2HSR3fSL2Htfp8RknJ1IiJ19o2DbI3MGajOdDfnB5eEFvpEk6VtTLuEP8_I7L0v1uXfzuPft_mmMulhUY7PK9qjKx7H3R3u62WQMM0u1g2VhiYAvXE_GNVuxDKS2MHkJtwNJknGoPfjSjloj5pJGhgC04pMiXjIE2j9bdb0uo-nBoy7fRzfYHq5AQmppE20sREREoDlGgov8VVdMSyRSK4o4WCJaTu0o1Whvu8EVU4pVUCUlJs-z1N5ayLPyFPgX0NuSloof8PVTKuIcXXk59C5N18b65NLTzZx9tanhSQTzcFUH7bCHLEJHkrDlvOI0iM99BBtlcGwx0bvQl-aYiYmHEEX8Q1VFWy0Ka2zwew-rKXoEjiFVotKCY6b0kO2wIncO00K9PDnjTN33I085UNT4HZWevy2jxFkHsYXmeOVM-92lh0QTT-qPYEc6lPjRMcLawfwCnwfvY6UA5r-K-plC39n0PLQYWZTsK3zWdJVpH7P0_MO1XqlZKdVumaXr9qZboSN7H1PgRlCw2zqMmwWEATvQyWqHwWEWgQPQ=w645-h860-no
Repainted the transformer top too...
UdafB8_X1haDsow3-Bk7N8ZGaomfO_0KgCQ7-MA1p98MxkJFYH1OEfeZx1tQg8C_dr2hpNrrDlTgKib4Xjzmvrds5s_sofTaHgyFEL4u-a2JTV3XXyRCn_8uk7rcTtlhUjQ8kORP2VfSa4Hrf6spmmKUletmVNxXYhtrp1pT9gGw6lBZW6WbRdeLptesFkF4m1I2trRif9gRuj_D3PPZRQuXWPbQuPfhBh5j6p2Xa4WP03eSlO2E50WZOFwVlH7_YmyRJ6qYttfi5JrFB7gcsOgbVpm70j4r1cuMTUCTHbCUnm6V4Az-s8_z6wFb2L1nYXBSR0hgn0rVlfQvyOV8Z3AaWPQR8sCERivMMpcleYL2O726xZ_q8Em_tdFIFLCpWwpqA-7IqnKu-2qzggcTx-eoYm0vhZI5wYzgD0h61XOx14bE6GbrSQZmzxpArNEEtwqxoI3Rcou_YEfvjIWQLo9t0IPixs-l_8KbiYsJ0TPyEgqdrGdh_C5mXRJF6blwnP50QXdxOc9Qd1HMzHkikPiaFvkZhdde6gG34Bi1MWVwOQx57RYgYWApT7PNQt6ETOv1cru7IqegNzKl8tUurKoeM6k6vSwTLiPXI8QhzcKEKyPuotHO0M3n1iuhQd8WSG5oV43weypZYGRkqriGftK6LB0FlKHcuAiEq8A04-Cxdb4BUb8H5rwh6qjdo4kiRx4aSiz3-Lyt90M4c7SE2AsB1muJr_n7B6B6OEX7K6lWBAKOv_Ue5A=w1147-h861-no
Really nice job! Did you try swapping the cases for the relay? You can typically take the new relay out of it's case and replace with the old case for correct attachment to the receiver. Some don't fit though.
Rough Part Replacement:
59 Transistors
* 55 Small and Medium & 4 Outputs
86 Capacitors
* 80 Electros & 6 Tantalums
4 Variable Resistors / Trimmers
1 Relay
5 Resistors
22 LEDs
* 14 Indicators LEDs
* 8 Fuse Meter / Dial LEDs
2 Added Polypropleyne Bypass Capacitors
2 Pre-Amp / Main Amp Jumpers
oYPyde746fio1fSTVzpItA0WubuOCxm6SM2_jvYQqyCyLyQD24pfZQF9uQt9yZA3yrONzMG6MHh4MG9yojEANkf7uju8NNo6iCGBus2VEwJvMSGAHIt7ZB6WTlQTiywphoWc7FbQPcx1D3862Ph9jt_I8b1poKl7OPYqEsU55OtuGJNwRSH36943NKft5vQCcovXQ9tbeWOggM_ph9sdiMxxX11XoQOmCUEwzlQNk_NJMqmqrbbyG7P1DedKh8ll6i0QP6DQbAI72XuIdtLqtzaWCFbQmdEuIYi6mAyvLp3S_1xMjvs6nb3ACEX8qTHA_UU-coxe2ov2li9f9CE5MLEEl_4yiAaZiP_o6v6b1L8pJcLCka8qbTcjhp7hTYh_up-VGWLl-mNXfrGz3Qt3zwOnzfe3NtXMwwy8efRxeLzx0Kf6TEIeAzIEXmeXFRRyK85q8mR5qDb7f-nSmBg1QosiwJ8VVB7N0DRGXNYyeiswviPL8AO4sjXBDhDiGEtqzGXipXT_rmUlSNbp30y7WK4YVm38topBowE9YU2P184k3AF0NHI0r9FYsg7rUoYf8vlgRnI0S7ZenXzdMXfRWmMoOhB1hjKGRB-QZFDKPFRde63oVnvf3c7VApJwS4iIlxl3pULdyncfmCkN2wEvAnUM9PUUk94YTHkrQGyWPbO3eEqltBWf1yYXBbiAbSLRbTkNAtIPYjltZcRq09RBzc1v3PIewjnDporr11Gre22T_Na9yJTVGA=w1147-h861-no
GHhv0XfxT6mv3izRm0YAF4pAsqKCoa__Q7zb-HYau1GPeBHNb6bsceI2OzQH8Xtt6EvAxW2OKxItifCQw-WjafAKlw1TgUy3u0_vEjWGuz99Qfe73nQme8YUr1jtbUhMJZSrdl7tRRU92Homaq92QU3deTEkqG0KLlnPL0qw65NiDP5-LaMY9d918O7pR8y0BSknwo_ZouBAh_L6NkajPSsKAMbB1Bbu8iQyjXEqQZ8R2CgpEyRNo8EhJfcLfmqgvxHiCc0Rj8Un-fd0d0EHCbJ9ksMRBrq9ZYlePuRLwtxgN892DXGp-zAigkQY51A0x0ErlsAwsCVoC_PJjZ7ABxZpEGTZndfuqAZdcb8eN0MvBCFTNNsKzggLagksQknb4AhFNT7-JjFjJnVmnSKqpUPT3vUsK8Fur_KkILljpFs_6Kf0jMumF6g3ppln9FQfNLpZVoXXuAA-9ul8ET8maQ2D2C7wDkMpJdyrEOe4GTQtEbuZeHtmWn3pSNBbvoOsnooaPw4KdcMj7UMEekb6n5rRDewQJbWJZfXO0rcf5ADWN2AIFpuhlDoNWzAegizcZtQkkc7_-bm1poUwJagLiSfhX_6Urv_VVDmZ_h6gN2DC7MI8B4Aq2vYYZD0uVucT0rQPXacRprKn6m6UT2SScEQHqxMVDuWRoC2wzalHYEEnhCMIyXh74vEqgsIX93enRy0IteBBWq6vlVSPQyHOJxvTDnlCsC5pXlVvQ4Kv0KaAGw08kz-lYw=w1147-h861-no
nz8DRbBNj2pKj8SAyRDK0h8vzmeWiC3c872SO2-O5Akr3-ot6e58EB4XySzpR53DpJZsTzaRNrNSr6HuQ8Pjb4-7GA0nEOs5IXQlR0VykA9wsEvxgVVH-9rmPKZRCG4k8CeFGaaX9B7RS5aIgp_2PaWzFgzpnoa4PaEkIzDaYofAg01Ufa_tswBOi0jHAL_xHxNB8IqQtQoqiSweweEZiyd0PxWpIdiahMpLn4l9D_r-PznMKIH3qb1N4u-PPm2ndefq2cHKTYGmseMTUZTXiAA05VKpHJjg6RS4bRaaQrYDXJcnl3zqUl6mz7rGdh2ia-wZ6R-X-Gw9tgQbi-YiGNUaAldfVPaLNN1y7PIKqHt94rH67Bfuzs3Hk59sPxkeuNjVocWfzVNzZOQvohrA44_RstDftHPpgLjLSa0hnyFyRJRgnbEmOqYlsl_NLs0Q8fioqPlJ4B8VGTxQLTWhA0GZfZGmKGSOn7A9miXfCO0jQhS_8_Zp8PUdm8HgRoXSV93i2eq-M9ID_xDT0cQ2pYSWXwJU9HUtC6mjnipAHiVDMNe_PYzpeYybqF_L3U4mFd6tdtj3IdOSjrjqSglmpCPoAXfgPXDz9q6FEccHUWFsMyG3kDXrOKVCzkc0gw2craKNUreVDnvt62AHSHPjxCuPFCVKqcWzXidCkcP0ju3eYNurWuYwSDMQn7EpnDdD3JDngN9I0igHYtcSAv2OpTlohFlm-YK_-eF0H4_13Lqg8yjL-prApw=w1147-h861-no
