PSB 800: impedance
steelglam
Does anyone know the impedance rating for PSB 800 speakers? The original version, not the "Century"/800i version. I cannot find a definitive answer online. Thanks in advance!
30hz - 21khz
+- 1.5db 48hz-20khz
+- 3db 42hz-21khz
+- 1.5db 48hz-10khz 30 degree off axis
30hz -10db cutoff
8 Ohm nominal
8 Ohm min.
90db anechoic
92 db room
150 watts program 10w-200w power range
2000hz B3 crossover
35.25" x 10" x 13.5"
Per original brochure
45 lbs each
30hz - 21khz
+- 1.5db 48hz-20khz
+- 3db 42hz-21khz
30hz -10db cutoff
8 Ohm nominal
8 Ohm min.
90db anechoic
92 db room
2000hz B3 crossover
45 lbs each
Thank you much!
