Recently picked up a QRX-8001, and just started doing some initial evaluation. Here are the symptoms, all tests on DBT:
1. Both driver boards in unit does not come out of protection.
2. With rear channel driver board out, unit comes out of protection. This is the case if I use either of the driver boards in the front channel position.
3. With driver board in front channel position I get no movement of the power meters no matter source or volume pot level. They just don't move at all.
4. This one I've not seen before: with headphones plugged in either front or rear jack, the unit does not come out of protection with the driver board in the front position, or no driver boards in at all.
I know there are many fuse resistors to replace on the driver boards, but there seems to be something else going on with the rear channel?
Also wondering what would cause the unit to not come out of protection with headphones plugged in?
I've checked all of the fuses and none of them appear blown.
Just wondering where the starting point should be. I don't have replacement resistors on hand, but are there other things that could be the source of these issues?
The "fault" could be because the 2nd driver board increases the DC offset enough to trigger the protection. And there is no question, ALL of the fusible resistors ARE bad to some extent, with some worse than others. Some will test "OK" when cold, but go High Z under load. The 180 Ohm are 1/4w and the rest 1/2w. I use 1/2w metal film for all fusibles on this board. I also always replace the (two each board) 24v 1/2w zener diodes on the driver boards. They can, and many times do become noisy. The VD1212 will get replaced with two each 1N4148 in series. All other small signal diodes get 1N4148. I'm already in there and they are pennies each. Signal diode failures have had me scratching my head many times so I don't hesitate anymore replacing them.
Anyone have any thoughts?
