Yes, I've completely re-done one driver board: all fusible resistors replaced with 1/2 W metal film, all e-caps replaced with Nichicon UPW (KMET film in for the two 0.47 µF caps C01,02), two 1N4148 in series for VD1212.
I'm putting the reconditioned driver board in the Front position. I assume I don't need to have the Rear driver board for testing. If I do, I'll have to restore that board as well. Just testing for sound out of the two front channels, anything, really.
Always have the 4 pin input connector in place on the driver board (can't expect any sound without that!)
I agree, logic says there is a loss of signal somewhere between the pre-amp and the output. Also agree I am not getting bad DC output at the protection relay, but I might be getting zero signal, so that would be no surprise.
Will check voltages to the driver board. Will also try the restored driver board in the Rear position, haven't done that yet. Loss of power to the drivers makes more sense than all four channels individually having a fault, unless there is something else common to them.
Thanks! The odyssey continues!
