kevzep
Its all about the Music
What is a totally good idea, is to not take things off the circuit boards until you are ready to replace the parts.
This way you will not forget where and what way they go, sometimes the markings on the circuit boards can be wrong, and sometimes the schematics are wrong too.
This is because during the production run, things are upgraded and changed along the way, and they dont always release service updates for the schematics and circuit boards.
So as a habit, I dont take anything off unless I am ready to fit the new part or take the part off the board to test it.
When I do take something off, I take a picture or I draw my own diagram to make double sure it goes back in the right place and the right way round.
This applies to Capacitors, transistors and diodes.....
What would be the first thing to do now, is test the output transistors.
Do you have a diode testing function on your multimeter?
This is by far the easiest testing function to give a definitive diagnoses on your transistors...
Do you know how to test transistors?
Do you know the pin out for the T0-3 type transistors?
What we will do is we will take one out, test it and then if it is good, put it back in. Make sure you have thermal paste, and when you apply it, dont put too much on, there will also be a mica washer, which insulates the body of the transistor from the heatsink, this is because there is the full DC rail voltage on it and the heatsink is obviously earthed because it is bolted to the chassis.
So, no mica washer........it goes BOOM!! No thermal paste.....it gets too hot and then goes BOOM!!
I can guide you to the way to test the transistors if you need me to.
When you test them report the findings....like Ive shown below.
For example B>E = .450, B>C= .450, C>E= OL like that.....then we know exactly whats going on.
da times:O and yes:withstpd:times But at the end when everything come's together there will be:thmbsp:
:beer:
:yippy:TIMES
