you can unhook the screen taps and run it in pentode mode by connecting the screens to a spot in the B+ supply, but if the transformer is bad thats not going to fix the problem. Transformers don't develop capacitence problems or any of that as a matter of course. They basically work perfectly normally, develop a short between windings, or go open. No idea where you may have read that other nonsense, but its nonsense. Bad transformers are bad transformers and unhooking the screen taps doesn't make them usable again.
if you replace it with anything other than an original, you'll want to change both so its matched and its going to need some re-tuning of the feedback bits to make sure its stable.
Cool. Thanks for your patience. Rest assured I'm being very careful and respectful of what I'm doing.
I had a replacement transformer here for a leslie model 25, a non UL one, that seemed to be a good fit, as it was made for high voltage p-p 6L6 output, in the same wattage as this one... I'm making another node for the screen supplies of the EL37'S, coming off the main power node.
I wanted to separate this node as much as possible, so I read that 1000 ohms is typical for their supply, and I am also considering adding a 10uf cap for each. Using a standoff up at the main can. The multi cap can was as close as i could get to the original, rated at 500v with a bit more filtration, which was fine, since the power supplies with modern components were coming out a little on the hot side.
I split this into a dual monoblock, as mentioned, and on the side which is still stock transformers, the power goes through a single high power rectifier diodes for each AC lead and combined before a 250ohm 5w resistor to get a near perfect 488 volts. Then, going into a 40uf and 20uf, before headed to the center tap. Then the nodes for 12kohm/20uf 420v (driver tube) and 39kohm/20uf source for the input 12at7/PI tube. This differs, but i think is more filtered than the original, which combined power supplies for mains, now separated into the one just described, using a 500v 40/20/20/20 can on each side. And now on this side, adding the supply for the screens. I was thinking that the 1k resistor before the 10uf 500v cap would keep it clean sounding. I've already gotten a good idea of the NFB loop, using a 2 meg wire wound pot and mica cap... and i may convert the other side, as you mentioned, and as I thought might be necessary before that, if using this for hifi use. I just had a fellow contact me with another one of these, so this one is now destined to be a nice instrument amp, so a difference in tone between channels may not be necessary. Indeed, it may be changed to EL34/6550 OR 6L6'S to reserve the el37 tubes for the hifi unit.
What I'm asking is re: the screen resistors... is it advised to filter the node up at the can and put the resistor directly on the pin for the screen? I was thinking that resistors first, then a 10uf cap for each node running to the screens. Sorry if my posts are a bit meandering... I try to wrap my head around the reason for each action; thinking of the why and mechanics behind these methods. Thanks again. Pictures of the build currently, the NFB caps/resistors are the wires hanging out. I've insulated nearly every hot wire in the new build with shrink tube, and grounded the chassis. Also adding the original schematic. It realky looks like they just shoved their 30w amps into a single chassis, likely the case, which made it a no-brainer to separate them and improve their sound.
