Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Thanks guys that is why I like this site. A lot of great knowledge. So is there any other way or something you can buy if you have only one phono hook up on amp. I have three turntables and two amps with only one phono hook up each. I guess I can hook up two and let the other rest might be the easy and cheap way to do it.
You just need an audio input selector switch – something like this http://www.jaycar.com.au/productView.asp?ID=AC1655 . They are usually available at many electronics stores, either as audio, or audio/video selectors. Plug 3 turntables in, and the output into your amp's phono input, and select the required turntable with the switch.
:thmbsp: A switcher is perfect for your situation.
I use a JVC JX-300 A/V switcher for a similar application. It has a remote control so you can switch between sources from your listening position and it is dead quiet on the switching.
