Can two Turntables be hooked up
naconst
My receiver has only one phono hookup .Can you hook up a second turntable by using RCA splitters or is their another ?
naconst: You should at least use a quality switch-box for the purpose - 'cause if you just connect the two tables in parallel, usually one cart would present itself as parallel load to the other (together with the load of the cabling and phono input) -> not the most splendid idea!
Considering the table in your avatar pic, I'd think'd you better go for an additional separate phono stage, though...
Greetings from Munich!
Manfred / lini
Only if you have a microphone. :smoke:
It'd be much better to use another pre rather than run two into one pre. of course you could use a ratshack switchbox before the pre.... but I don't think it'd be optimal. Many dedicated phono pre's had multiple inputs, one of the vintage amps (that I no longer have because I'm a dummy) had inputs for 5 or 6 TT, switchable between mono and stereo and different eq curves and other things that I didn't understand at the time. If I had understood I'd be posting a picture and bragging rather than typing with my tail between my legs. :sigh:
I know several of the members here run multiple TT's, multiple arms/carts, and hopefully they will chime in-- soon. (I learn soooo much from other peoples questions).
So, to refine and direct a bit:
Which 2 tables?
Which 2 cartridges?
(i.e., are they going to play well with the same preamp in terms of RIAA eq, loading, output, etc?)
Into which phono input/preamp on which amp?
Can you DIY/solder/fabricate or are you looking to buy something that works?
Are you looking to hot swap (A/B comparisons) the 2 tables or just not have to reach in the back of the receiver?
Do you have any kind of a budget in mind?
a.what I have on hand
b.cheap and easy, less the better
c.<$50
d.<$200
e.< cost no object, damn the torpedoes-- I wanna run BOTH my Fisher Price Snow White Portable AND my Rek-o-kut and the same time dammit.
G'day all, there are good quality stereo audio switchboxes commercially available that work well, and that is what I use.
A nice 'easy' solution. Regards, Felix aka catman.
Gawd no, those things are awful sounding!
You might be right when compared to whats in most vintage equipment .
I should have said to get something like the unit in the posting . That one was just the easiest to find a picture of .
Barney
I'd go with some kind of switchbox and, like Felix said, there are good quality ones available. Just get one made for small signal levels.
No need to use up a line level input when they are usually at a premium nowadays anyway.
Doug
I would probably use one designed for video switching thinking it may have better shielding than one strictly for line level audio. Any thoughts?
A quick, simple and cheap solution for two turn tables to one phono input is get three short sets of RCA cables and one pair of RCA male to male connectors from Rat shack etc. One cable to each TT and one cable from the phono input. Plug in RCA M to M connector to the end of the phono cable.
Label all three and find a suitable location in front or side and bottom of receiver.
Just switch cables from the two TTs into the connectors from the phono input as needed.
I have been using this method to get multiple cd and tape decks into a single Aux for years.
Or you can use the desire to run two TTs as an excuse to get a 9090db or Sx-1010 or others that have two phono inputs!
Charlie
I'm pretty sure that would change the load. No big deal for two CD decks but not good for two cartridges.
Edit: never mind. I thought you were using Y adapters. I see now that I misread.
Why not get a tube phono section if you have a SS preamp. or vice versa, hook the best TT up to the one you like best. Now you have the best of both worlds. Some records sound better on tubes, others on SS.
Track down a Supex SDT-180.
It's what I have and allows the use of different types of carts and different load settings.
Good luck.
Eric
Just this past week I experimented with using a 3-way Radio Shack audio component switchbox that I bought back in the '90s, for connecting my three tables to a single preamp.
At first I got some hum, but after changing the placement of the switchbox, the hum completely disappeared. I used it for a few days with no obvious problems.
Last night, just to be sure, I connected my main table directly to the preamp and discovered that there had in fact been some signal degradation with the switchbox. It definitely sounds better with a direct connection. So, now I'm back to plugging and unplugging cables whenever I want to switch tables.
