PakProtector
AK member
I have been wavering on 'upgrading' the 6AU6 driver stage. Examine the Altec 260 amplifier circuit. That puppy runs type 813 finals( as pentodes) and feeds them with 6AU6's...
The 6AU6 are fed from a rather neat input transformer. That amplifier is pretty simple.
Here is a clean copy of the schematic. The 6AU6 are not only loaded by the 813 grids but a grid choke bypassed with 180k plate loads. That is a pretty steep load for a 6AU6 with 150kOhm plate loads. Half a percent THD up to ~200W with a 1kHz signal. I have no doubt this would be significantly lower( the power output ) if done at 30 Hz...let alone 20 Hz...
Douglas
Douglas
