Darrelltarte
Member
I found a solid state replacement thingy, but I'd rather use the vacuum tubes but I would use the ss replacement if it is recommended.
"the only thing is that getting me is the arm won't hold the cartridge"
These RCA's had the "Feather Action" floating cartridge. The cartridge is held in place by a little prong or clip, usually white or grey in color. The clip is inserted into the front of the tonearm headshell, the cartridge is
on hinges at the rear, and the clip holds the front part of the cartridge and allows it to float. There is also a tiny felt pad on the clip that rides on the record to clean dust away. This arrangement would not allow any force over four grams on the record even if the tonearm was pushed down or dropped. This was to protect the record and stylus. Zenith, Silvertone, Philco, GE and Airline had similar schemes.
This clip has a tendency to fall out when the console is moved or bumped abruptly and is almost always found inside the console. RCA's generally had a plastic pan under the changer and the clip is usually there
or inside the console somewhere else. I hope you didn't throw it out thinking it was trash.
The posted frequency response of the models with the 15" oval woofers and open backed cabinet was 45hz -15,000hz. The response of the models with the 15" round woofers and sealed cabinet was 35hz-15,000hz.
This was the response of the speaker system, the amp was posted at 20-20,000hz.
Those picture tubes come up nos once in a while and you could also check with VDC (Video Display Corporation). Moyers Electronics is a good source for 60's RCA flybacks, it would be prudent to have
a spare if they have one. The folks over at Videokarma have cleaned them out of some of the rarer ones, mostly early 60's models.
Hopefully I can find a bulb for this it illuminates the changer.
