It's kinda like replacing the fan belt. Next thing you know you're rebuilding the alternator 'cause the bearings are shot.Go figure. :scratch2:
It's still about the fan belt.
Tweeters ordered per your recommendation.... :thmbsp:
It's still about the fan belt....:
Black curve in first pic is what happens when the pot is removed entirely, a bad idea.
That's just wrong, Jerry.Now, I admit that I'm ignoring the response above 10KHz, but that's intentional. Most of us can't hear it anyway and our dogs certainly don't care. Then for those who can, there is very little music there anyway.
Are we picking nits here? Well, maybe, but there's no denying the voice is being altered; the increased tweeter output does not extend across the full HF bandwidth, as many have supposed, and the action's all below 5 kHz....
I've had this discussion in other forums. I can't hear sine waves up there myself, either, and haven't heard a TV whistle in 20 years, but I seem to perceive high frequencies in music or pink noise well enough to get the balance correct by ear. The proponents of ultra uber-tweeters argue that there are other means at work which allow us to "hear" out to 40 kHz and beyond. Of course, there's also a major industry trend unfolding which relies upon that concept for sales and income. :yes:Well, Zilch, I have a set of Koss Pro 4 Plus headphones, signal generator and a scope. I know for a fact that I cannot hear any pure sine wave beyond 11KHz.
By my calcs, it's more like 20% of the power is going into the resistor, actually, no?Yep, probably are nit picking! It's a little hard to believe, however, that the 15 ohm resistor dissipates zero power at 10Khz and that's what your curve says!
:tresbon:Yes, and harmonics are what enable you to distinguish between an oboe and a clarinet. Timbre is in harmonics.Nevertheless, I can still hear cymbals. I listen to jazz trios all of the time, so the fundamental frequencies of the cymbals must be way below 11KHz. What you see on scopes are the harmonics.
No problem, but bear in mind this is just me diddling around to illustrate stuff, and not a recommended anything:Zilch, would you mind explaining in more detail what changes you made to crossover the tweeter and early woofer higher (to take care of the 2000hz funny business).
BUT, I just re-verified, using the tweeter, 20 uF capacitor, and a 15-Ohm resistor, so I'm gonna punt, say "inductive reactance," and pass the baton to Ray to explain why that is....:
Ooops, just figured it out. It's dB shown, of course, 10 log power ratio, and the difference is less than 1 dB. We all knew that, right? If HALF the power was going into the resistor, the tweeter output would only drop 3.01 dB.
[No need to wake Ray up....]
One more thought on this. While all the above seems to focus on db changes, isn't the real problem in removing the pot the fact that it will increase the crossover freq thereby creating a hole in the spectrum?
Certainly there are compromises in the original design, and they may not be consistent with contemporary standards and/or performance objectives in some ways, BUT, used as intended, stock vintage AR4xs stand up quite well from a frequency response standpoint, once restored:
Does that mean they cannot be "improved?"
