I feel the need to recap on this 15th page of the thread - and also because I decided to give the Triton X-100 a try.
For a 50 ml batch:
(1 teaspoon = 4.929 ml> say 5 ml for those using droppers)
5 ml (1 teaspoon) of Triton X-100
45 ml (9 teaspoons) of Distilled Water
Mix solution and let sit approx 10 hrs (overnight) or add 99% IPA to speed dilution
From Vince "You want a final concentration of detergent around 0.1 to 0.2%"
50 ml = 1.69 oz
1 gal = 128 oz
1.69 oz solution / 128 (oz/gal) water = 0.013 =1.3%
therefore
1 oz of solution to 1 gal water = 1.3%;
1 oz of solution to 10 gal water = 0.13%;
Use 5 ml solution per gallon of water
So for my 10 L Ultrasonic Cleaner that uses 2 gals of Distilled Water, I would need 10 ml of solution.
For the Spin Clean tank that uses 24 ozs (.1875 gals) of Distilled Water, I would need 2 ml of solution.
Thanks for summarizing Jeff. Remember you can go with higher detergent if you need to. I use 0.5% to 1% all the time for rough cleaning with no problems rinsing it away. Lower detergent is better for Ultrasonic (to keep foaming down) and for touch-up cleaning (light rinsing).
If you are substituting Triton for your dish soap, remember that our stock Triton solution (your 50 ml batch) is 10% while Dawn is 10- 30% detergent (I guess it varies according to the MSDS)..
