see post #191 (page 10) of this threadI wonder if they were used in Sound Guard, one of my favorite products of the 1980s.
This is an interesting one. The active component is a silahydrocarbon mixed with a small amount of tris(phenoxyphenyl)phosphate, a mixture first developed as a dry lubricant for aerospace. It was invented by the Ball Bros corporation (the very same one that makes those glass jars for preserving) and was originally called VacKote. Some great surface chemists worked on this invention, including Marion Fulk, and as a result, the Ball corp. quickly became a leader in the aerospace industry since the lube doesn't evaporate and lasts forever, even in a radiation rich environment. Hence, it was perfect for greasing metal parts on satellites and, in fact, was used to lube the wheels on the Apollo land rover!. They later re-packaged the lube for records and changed the name to Soundguard Record Preservative (they also made a cleaner and sold them together). Their patent expired a few years ago so I think the formula is now marketed by another group, but it has a fascinating history. Not something I think we need on our records though as, due to its incredible stability, you can never get rid of it. Chemically, it's more like GroOve lube than Last as a surface treatment.
BTW. This is the first thing that popped up when I googled it. :^oHas anyone tried GroOve Lube? I've been tempted, but... Maybe I'll try it on a LP from my wife's old, poorly handled collection and examine the stylus after a few sides.
As explained in this thread, the soap you use matters. Lots of products remove dirt, but we aren't washing dishes here, we are washing a piece of plastic carefully pressed with fine, varying microgrooves used to reproduce sound. Everything that touches it can effect the integrity of the sound. But yes, it doesn't have to be complicated. A little non-ionic detergent and distilled water and you're generally good to go.Washing piece of dirty vinyl not needing to be complicated or costing any real money
Watch film on how Lp gets made from beginning to end for decades
Soap and water LOTS of water maybe little alcohol and few drops of phot-flo
Little bit of mild soap safe for plastic and clean distilled water water water water
Record cleaning machine good too best way to go for efficiency
I wish I had penny for every word written on this subject! ; - )
JJ
Careful clean and rinse matters more than soap dawn is fine but just very small amount like few drops
Dawn can not create static on plastic has to be something else but I hear what you say not the first timeAs always said in this thread, if you are happy with your results, then that's great! Some of us noticed Dawn gave us issues with static so we looked for something better and discuss our results. To each their own, there are no fouls here.
My son works at a NASA lab in Boulder. They use quats as antistats. So do all hospitals and chip makers. Dawn's main ingredient is SDS...an anionic detergent. Water alone kills the static charge when wet so any aqueous solution will do in that case. However, a micro layer of this charge is left behind after drying. This is what makes the record susceptible to static charge. I have verified this myself with an electrostatic voltmeter that I got from a friend at Xerox (where they also use quats as antistats).Dawn can not create static on plastic has to be something else but I hear what you say not the first time
So I am not going to argue with what any person say happens to them how can I know I am not there?
I tell truth I have not read whole thread but dawn is surfactant and kill static on plastic
Been used at aerospace missile facilities for same purpose static electricity control elimination
Plenty published papers on internet some by U.S. Navy on subject if interested in mechanism of action
Here is story just one consumer worker guy but same point
http://hingstssignpost.blogspot.com/2014/07/prepping-acrylic-sheet-prior-to.html
Plenty more consumer type stories a lot by hard core computer guys wanting to protect equipment in plastic cases
But NEVER use ones with hand softener that sort of junk just the soap
JJ
Jimmy this thread has shone a light on the process of record cleaning. It has been a revelation and to my knowledge there is not another one like it in English anywhere else. You could expend your time in far worse ways than to take the time to read through it all. Take your time read a couple of pages at a time. In comparison you have leaped in with Dawn dishwashing liquid as if this is some Wonder product. Jimmy in the context of what is being discussed here, Dawn is not comparable.Dawn can not create static on plastic has to be something else but I hear what you say not the first time
JJ
You sound very condescending dawn just a well known example only reason I cite no wonder productJimmy this thread has shone a light on the process of record cleaning. It has been a revelation and to my knowledge there is not another one like it in English anywhere else. You could expend your time in far worse ways than to take the time to read through it all. Take your time read a couple of pages at a time. In comparison you have leaped in with Dawn dishwashing liquid as if this is some Wonder product. Jimmy in the context of what is being discussed here, Dawn is not comparable.
Do yourself a favour Jimmy. Read the thread. Keep the Dawn for your dishes.
That is fine thank you for nice post! ; - )My son works at a NASA lab in Boulder. They use quats as antistats. So do all hospitals and chip makers. Dawn's main ingredient is SDS...an anionic detergent. Water alone kills the static charge when wet so any aqueous solution will do in that case. However, a micro layer of this charge is left behind after drying. This is what makes the record susceptible to static charge. I have verified this myself with an electrostatic voltmeter that I got from a friend at Xerox (where they also use quats as antistats).
Don't get me wrong, SDS is a great detergent...even stronger than the non-ionics we are discussing here so if it yielding the results you desire and you aren't having issues with static...keep using it.
As a chemist, what is your opinion of Kodak Photo-flo? (That is what I use as my surfactant)
