Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
Dual purpose puck. Outer ring protects LP labels, inner ring protects 45rpm labels.
All this talk of record cleaning got me motivated to finish the pile that's been sitting...
Is that a painting pad?
Do you remove the outer ring when cleaning 45s?
Yes, otherwise the cleaning fluids won't reach that point. I had both O-rings inserted for photographic purposes. Also, what's NOT pictured, is an adapter that fits the 1.5 inch hole of the 45s. That additional insert fits into recesses milled into the pucks, keeping large hole 45s centered. The aluminum insert that IS in that picture, is the adapter from my AR-XB turntable.
Thanks! Makes complete sense.
Late to the party, but i have read the first 32 pages and the last 17. Great debates and lots of great ideas!
I have a question regarding my "do what you can with what you have" situation: I have a spin-clean, and i have plenty of Tergitol NP-9. Using the info i have read here, and without buying any additional equiptment, my plans are to make a solution of 99% isopropol alchohol, distilled water and the NP-9 and use that in the Spin-Clean. Any suggestions on ratio?
25% alcohol
75% distilled water now let flame begin over what water to buy
Your surfactant? I do not know all details on your product I am sure different ratio for different uses read sheet with material otherwise I suggest start with just a few drops
I use photo flo only needs eye dropper full if that
I also use two three large drops of dawn
Here is thread may be help you decide
http://vpiindustries.com/forum/viewtopic.php?p=27247
I NEVER in my whole life read so many people worried over NOTHING make something SO SIMPLE so CONVOLUTED and HARD!
Just my opinion after looking at the thread and million others sound just like it not directed at you or your question about recipe ratio surfactant just record cleaning in general ; - )!
JJ
Just use distilled water (about $1/gallon at grocery store) with your alcohol (99% Isopropyl if you can find it).
The best combination with a Spin Clean is a vacuum system to pull everything off of the record once it's clean.
Happy record cleaning!
25% alcohol
JJ
Thank you. I believe i will also combine the alchohol , surfactant and a small amount of distilled water in a small bottle, then add that to a gallon of distilled water once the three have combined well. I am not in a position to justify spending hundreds of dollars on a machine (got a good deal on my spin clean) and my equiptment is very low end so i'm not obsessive about this, i just wanna take care of what i have.
Kitchen sink do just fine to clean Lp if can not afford any machine
PLEASE STOP joining rank of people feel need to disparage apologoze for what they have that worse to my mind than people who feel need to remind forum of how great every thing is they have with almost EVERY post or like peacock signature lines I expect insecure from self important big ego needy for attention and braggarts just not like when has negative impact and create more insecure in self-deprecating way! ; - (
100% pure genine pleasure from audio NOT monolithic recipe despite what some people pushing and pleasure WHOLE point!
Take clean measuring cup drain off quart you do not need save for something else pour in alcohol and what ever else in recipe and done
Plenty of space at top to get good circulating shake thing going on! ; - )
JJ
What is the ratio distilled water to isopropyl? The best I can find is 91%.....
Ratio is about 6 parts water to 1 part alcohol. (Just my preference)
You can buy 99% Isopropyl on Amazon fairly cheap. I used to be able to get it at Safeway, but not anymore.
And you can buy 91% isopropyl at Walmart for $2.58 per 32oz container which what I use. The 99% isopropyl starts getting pretty pricey and I'm not sure it buys us anything in this application.
I like keeping my alcohol ratio in the 6-10% of total solution range per suggestions from guest110 and phantombebel. hi*ball is running at 16-17% which would be the very top of the concentration I'd consider.
Anyone looking at the differences between 71%, 91% and 99% isopropyl should read this post by phantomrebel on how isopropyl is manufactured:
http://audiokarma.org/forums/index....re-doing-it-wrong.689430/page-50#post-9911665
Status
