Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
I found a steamer (Shark SC-505) at GW for eight bucks. It was missing most of the parts but it has what I'll need to clean records (see pic). I tried it out on an album I have a replacement for and the surface noise was very low. The record looked like there was some kind of film or residue still there so I'll be mixing up a cleaning solution and doing a little scrubbing with a paint pad and then steam again. I'd love to get a RCM but until then, an eight dollar steam cleaner is hard to pass up.
When you use the Triton/Hepastat/Alcohol solution is it counterproductive to rinse with distilled water as a final step?
When you use this solution you MUST rinse. If you don't rinse, you will hear the residue dried on the surface of your record. Rinse and rinse a second time. Vacuum drying each rinse works best, in my experience, but some are doing a very thorough rinse and then air drying.
There will be an unavoidable molecular layer left behind of the Triton or Tergitol, no matter how many times you rinse. But you do want to rinse until you get to that minimum residue. That is why the non-ionic detergent is what you want to use. If I remember correctly, stuff like Dawn's molecular layer of residue will be ionic, and will orient negative tails up, hence attractive to static build-up. I might not be remembering completely correctly, so re-read the thread. :smoke:
Enjoy,
Rich P
Maybe I'm reading wrong or misunderstanding, but it sounds as if you are saying or inferring that Triton is ionic and therefore not a desirable detergent to use. I googled and found "Triton X-100 is a nonionic surfactant".
No. Those 2 detergents are not ionic. That was essentially Vince's original intent to convey by posting this thread, However, the molecules are polar (positive and negative poles) or they would not form the micelles required to solubize and segregate what is being cleaned off of your vinyl. As micelles are forming, so is the molecular layer on the vinyl. It is just nature of the beast. Once you have rinsed off the loose solution and its contents, you will be left with just the molecular layer of Triton or Tergitol, which is an order of magnitude better than a molecular layer of an ionic detergent like Dawn. i'm not a chemist (I only play one on TV) , so maybe one will come by and correct my false assumptions...Paging Vince, or his alter ego (you know who you are).
Enjoy,
Rich P
What Rich said is accurate. The rinse is important as is the use of non-ionic detergent. We also can include cationic detergents (quats) to counter static charges. These are the same surfactants found in conditioners, antistatic sprays, and fabric softeners. We don't use anionic detergents, the most prevalent of which is sodium dodecyl sulfate (SDS, a.k.a. lauryl sulfate) which is the main component of dish soaps, shampoos, and laundry detergents as their negative charged heads can promote static issues.
It's not just about cleaning and static prevention. All these surfactants do leave a molecular layer behind that is beneficial from the standpoint of lubrication. There are patents for vinyl mix preparations that incorporate them into the record for this purpose and also commercial record "conditioners" and groove lubricants that include them as the main active ingredient (though some use siloxane based compounds). The quats are also antimicrobial, breaking up molds and fungi on those really dirty thrift found records and protecting them against further attack. For all these reasons, it is highly recommended to wash records, even new ones, with "good" detergents.
Just a quick note on the Hepastat as people have been messaging me regarding it's use. It is called 256 because that is it's concentration (they recommend diluting it 1:256 for normal use, or 1 ounce in 2 gallons). This is way too much for record cleaning so I dilute it 500 to 1000 fold (depending whether I am using an RCM or US cleaner, respectively). Lately I've been using it without added Triton and it works great. At the very least, people should be using it to clean up their brushes, machines, and tanks to prevent fungal contamination and eliminate static. I recently saw a VPI at a record store with live mold visible in the clear drain tube and on the white bristles of the cleaning brush. And people pay to use this!
So about 7.5 ml to a gallon? Geeze! 1 gal. of Hepastat should be enough for all the LPs in NJ!
Yup, and I can't seem to find it sold in smaller sizes. There's an opportunity here for the business-minded record cleaner I suppose.... definitely not me! But it does go along with our objective of DIY cleaning solutions at pennies per gallon rather than the high$/gallon certain preparations cost. When it's cheap, we'll use it liberally which is important.
If we are using it at 1:1000, your $24 investment (depending on where your purchased it) is enough to fill almost 24 oil barrels of cleaning solution (or 16 wine/whiskey barrels). ~$1/barrel...not too shabby! For many, the purified water costs more.
The smallest I could order was a one gallon size, so I have plenty to clean every record I own a few thousand times.
Well if there is such a business-minded reader in North or Central New Jersey, here is one customer. PM me, please.
Hi phantomrebel, I'm in the UK and am having real difficulties it getting the Hepastat 256. However, I have found Behentrimonium Methosulfate in this format: http://www.gracefruit.com/additives/actives/emulsifiers-thickeners/btms.html. Is this a suitable substitute or should it only be Behentrimonium Chloride?
sorry quackhandle, but that one is insoluble in water (requires an oil to get it into solution) and only 20-30% pure (mixed with Cetearyl alcohol for hair conditioning).
Status
