I would be interested in hearing about flocculants. I use a Spin Clean with my own formula, which was an attempt to copy the Spin Clean formula. I use Triton and EDTA.
Hi Donal:
Most flocculants are multivalent cations, the most common being a polymer of aluminium chloride. If you imagine the contaminants within the Spinclean bath to be surrounded by the negatively charged detergent (SDS in their case), you can see how they can be disrupted and attracted to a positively charged polymer, forcing them to aggregate. The flocculant further reacts with water to form an insoluble hydroxide, creating gelatinous precipitates that settle to the bottom of the chamber. Though the length of the polymer can be dialed in as they are each effective at specific pH ranges, the most common is Al
12Cl
12(OH)
24 and I assume this is what Spin-clean uses (though they will not say). It is also the main component of most pool/spa, pond, and tank water clarifiers (Some may be familiar with the shorter polymer Al
2Cl(OH)
5, which is what is in many deodorant/antiperspirants).
Pure chemical reagent polyaluminum sulfate (typically added to about 0.1mM) may be difficult to find for most DIY-ers, but one can look to the pool/spa chemical suppliers (like HTH) or aquarium suppliers (like Tetra) for their “water clarifiers” and use them as directed as they are, for the most part, the same thing. Cationic polyacrylamide is another flocculant that can be used and sometimes found at water treatment supply houses, but it breaks down with time and with mixing.
I have played with the polyaluminum sulfate for use in an Ultrasonic cleaner tank, but found it unnecessary.
