Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
Is there anything you don't know? Patent numbers no less!!!!
Would it be OK to wash the LPs treated with LAST, even though the LAST would not be removed, to provide the benefits of THE BREW? I suppose I could test on a junk LP.
Yes. It is fine as the Brew will not affect the LAST coating nor will the components theoretically interact.
Sorry about the extra info but I have a whole binder of patent files that I keep for reading fun. Kinda weird really.:confused:
No need to apologize. I am genuinely impressed and enjoy the details. Thanks for smartening me up. I know that's poor grammar, but it's clear, no?;)
phantomrebel mentions warming the solution and letting it sit on a record for awhile. I tried this on the album I mentioned in my last post and I did get good results on the second clean.
I also cleaned again a couple of Russian Black Sabbath pressings I have. I have quite a lot of records made in Russia. Russian records are legendary for the low low quality of the paper sleeves they came with, the equivalent of a paper garbage sack for 'quality'. so finding mint- records from there is a challenge. These Sabbath albums, when I got them had never been played. They have 30 year or so age wear just from sitting around. The paper sleeve had almost bonded with the lp, so instead of sliding the lp out I tear them off at the seam and throw them away (unless they are printed inner sleeves). I tell all this gory detail for a reason, since the records also have quite a static charge. Anyway they had been cleaned up on my VPI months ago and were played, they cleaned up pretty good. Well when I had a look at one last night after having cleaned a few other albums with this solution, they looked very filthy. So I did a clean with the warmed solution and they cleaned up great, sounded better than ever and the static charge seems much less than I ever expected them to be.
On the other side of the coin I cleaned a recent expensive and high quality German reissue of the rare Finnish album by Charlies "Buttocks". The main problem with this reissue is that it was cut pretty quiet so I have to crank it up pretty high to get a good volume, so the dead wax is pretty loud. Also dust specks are very loud. This album also came in a printed innersleeve and I remember having a hell of a time getting the record out without pre-scratching it. I have a vintage Panasonic BH-653 https://www.vinylengine.com/library/technics/bh-653e.shtml which I use like a zerostat, only it is 100 times better than the useless zerostat. I was able to sort of pry open the sleeve enough to get some use of the BH-653 in there and get the lp out and clean it. Well fast forward to today, I wanted to see how much dust from playback had gathered on this lp from the 2 times It had been played. Record looked filthy. I even noticed some old residue that must have come from the printed innersleeve. But it cleaned up perfectly, residue is gone and I was nicely surprised at how good it sounded, crisp and clean. So having some excellent results. Looking forward to digging out other likely suspects from the collection and cleaning them up.
I was asked a question by a friend today after telling him about my recent successes with lp cleaning. He asks: Is there a formulation and manual process that works well without a RCM or ultrasonic ? He and a couple of other record fiends like myself don't have situations where they can really use a VPI as an example.
Their preservative is perfluoropolyether (see US patent # 5389281) to Walter Davies (Last's owner). It is an inert grease and very difficult to remove. The cleaning solutions in this thread will not remove it. Removal requires very strong solvents that are incompatible with PVC-PVA polymers.
The Soundguard is similarly a lubricant containing dialkanolamine derivatives (see US patent #4125668, #4071460, and #4096079) issued to Ball Brothers. It's basically N-octyl N,N-beta,beta'-diethanolamine at 0.02% in 1,1,1-trichloro-2,2,2-trifluoroethane, essentially a solvent containing quat. In today's world, there is no need to go to this extreme since many water soluble quats are available that also have similar lubricating and anti-stat properties.
In the words of the geniuses at MST3K, "Increase the Flash Gordon noise, and put more science stuff around." :p:rflmao:
I am spreading the solution and lightly scrubbing using a MoFi cleaning brush: http://www.mofi.com/product_p/mfslbrush.htm
Then I vacuum dry with a handheld attachment I bought on ebay that connects to a small shop vac. The LP is on a 5" bearing supported disc and topped with a turning clamp.
For 500 ml of solution I use
Hepa 1.0 ml/0.2%
Triton 1.4 ml/0.28%
ISO 25 ml/5%
Rinse/vac twice with distilled water using a different brush.
I wish I could tell you how to get the vac attachment and mini-manual turntable; but the guy who was selling them on Ebay vanished.
Here's a similar one: http://www.ebay.com/itm/MK1-VACUUM-...996703?hash=item464a1b09df:g:pccAAOSw6DtYS1wH
I take no credit for any of this, as I was kindly and patiently educated by the wisemen (or wisewomen) on this thread.
Good luck
Thanks, forwarded that post to one friend so far. Yeah I think I saw that somewhere way back in the thread...I might have to get one of those mofi applicators. Currently I have the VPI one. I also mention to my friend he might want to just find a cheap old broken down turntable to spin the record on. Though I didn't consider the clamping aspect which I take for granted having had the VPI for so long.
There's many vac attachment producers. My son recently asked me about this one: http://www.vinylvac.net I haven't tried it, but they all seem pretty much alike. Vacuum-based RCMs have been coming down in price due to competition so that may be a better way to go.
The thing I didn't like about that one is it's designed to work with a TT. I suppose you could use it without one or get a junker. Mine came with a bearing supported platform with a spindle. great deal.
I am just learning about the basic solutions. Collected deionized water, 99% isopropyl alcohol, Dawn... Then remembered that 10 years ago, I bought a lot of cleaning stuff from needle doctor and never used it. Out came a giant bottle of Disc Doctor Miracle solution, MoFi brush, etc etc. Interesting part is that Disc Doctor solution says in large letters on the bottle that it is Alcohol Free.
If you're going to use Dawn, you haven't read the thread carefully. The Triton+Iso or Triton+Hepastat+Iso solutions work hella better than Dawn+Iso for me! Even better than Dawn+Iso, then LAST record preservative.
Alcohol-free is important mostly for lacquers, I believe.
I appreciate the comments, but for me right now is more important to clean at least a few records with what's available right away locally. If I can get Triton solution in the future, then obviously great, but I don't see it in the stores.
Basic record cleaning solution that worked well for me ... common ingredients available most places locally. When using grocery store ingredients ... I would add at least one water rinse cycle.
84% Aquafina or Distilled water.
12% Isopropyl Alcohol (91%)
04% Seventh Generation APC or any general purpose high quality "green" type cleaner using natural ingredients.
Couple drops of Kodak Photo Flo per 12oz (camera store) ... you could skip this step but it does a good job as a Surfactant.
I've moved on since this home brew ... but it worked well for me for years.
I see.
I know. By volume it will last my lifetime; but Talas says the shelf life is 2 years. We'll see,
Ah, ok. I've got the Terg3/9 I bought from Talas nearly 10 years ago, still in their original containers on a shelf in the basement. They still do the job, as far as I can tell. :idea:
The ethoxylate detergents like Tergitols and Tritons are very stable in their concentrated forms as they oxidize very slowly. The only thing that prematurely breaks them down is enzymatic action from fungal contamination. Without this, 10 years storage in a sealed container is easily achievable.
Status
