Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
:idea: ... you know ... one could read post #1 & 2 ... then just skip the other 63 pages. Just saying.
th
Ah, but then you'd miss the Hepastat which doesn't appear until page 51! I like the Tolstoy reference; bu I feel like it's mostly my fault.
Paully, 5ml of Triton per gallon of water should be about right, regardless of how you get to it. Be careful you don't end up with too much Triton in your US bath or you'll have a ton of suds, which you don't want. I recommend starting with less rather than more for your first tests. You can then increase the amount of Triton if you're looking from more cleaning action up until you start getting foam in your tank.
Remember to mix the Triton into some alcohol first so that it fully blends, then dump the Triton/alcohol into water. If you dump the Triton directly into water or you'll have some difficulty getting it to mix, at least this is the case with Tergitol and I suspect also the case with the Triton.
Thanks for the response. I also really appreciate that letter you wrote to some publication where you summed it all up. That helped. I didn't use alcohol in the 10% solution but I set it several days ago, so it is completely dissolved. It actually only took a couple of hours. I made some more this morning and it is also completely dissolved now too. I found that just putting in the 9 teaspoons of water and 1 teaspoon of Triton and giving it a swirl every so often gets everything dissolved fine if you give it some time.
Adding about a cup of alcohol to the final tank solution seemed severe, but I guess it is right. Also good to know that I can up the Triton concentration, if I don't get foaming. All right! Let's see what happens! :)
Paully
Glad you've got a plan for moving ahead, Paully. The value of the isopropyl in the tank is that it is a degreaser - it helps deal with the finger prints and oil that many be on surfaces. At 5% of the total volume, it's really a pretty modest amount of alcohol.
In the spirit of helping newcomers to the thread with summaries, here's the link to the letter to Positive Feedback detailing my approach to ultrasonic cleaning and the materials I've assembled for my cleaning regimen:
http://positive-feedback.com/audio-discourse/rushton-paul-diy-approach-ultrasonic-cleaning-lps/
A replacement source for the Hepastat 256 is quill.com - seems that Staples and Amazon no longer offer it.
http://www.quill.com/brighton-profe...r-handy-mix-dilutable-64-oz/cbs/51805647.html
After about three years of happily using the CCI recommendations for Tergitol with a VPI vacuum, I took advantage of some time off of work to assemble an ultrasonic system and gave it a try this weekend.
Really appreciate @Rushton and his posts for fluid ratios, heat and time settings. Took a lot of guesswork and head scratching out of the picture and I could focus on the work at hand. I was able to completely clean, rinse and vacuum the first eight records in a little over an hour, and expect that will improve with practice.
The records look great and surface noise is diminished- even on records that had been vacuum cleaned earlier.
My only complaint is the noise of the ultrasonic unit. I think some of the seams and panels are loose and vibrating against each other, so tomorrow I'll see if I can quiet them down with some sealants or gaskets. The cleaning performance, though, is just what I was hoping for!
Sure enough!
The bottom panel had plenty of flex, especially at the corners, so i ran an ugly bead of caulk around the rim and added quiet to the system.
After about three years of happily using the CCI recommendations for Tergitol with a VPI vacuum, I took advantage of some time off of work to assemble an ultrasonic system and gave it a try this weekend...
@dcmfan, Glad to hear you've jumped into the ultrasonic cleaning end of this pool! And that you're noticing some good success. Thanks for your kind comments about my efforts to summarize some experiences for everyone.
What ultrasonic tank did you end up with? I'm interested in your quieting results with some caulking to the panel connection points.
I went cheap on the tank. The brand on mine is VEVOR and the model number is jps-40a, 10 liters, 40 Hz. This looks like the larger version of the tank that Cleanervinyl recommends. But honestly, these budget tanks look like they all come from the same factory.
The line of caulk around the base is working great. Fifteen minute fix. Now the only sound is the buzz of the ultrasonics, no metallic rattle.
I also tried filtering with an old gravity filter I had from my backpacking kit, and it worked, but it leaks a bit, so I may opt for a fishtank filter later. There's not a lot of visible gunk in the tank, but I could see a difference when I compared the filtered solution to the unfiltered solution, so I want to keep that step in the process. If nothing else, filtering is faster than mixing new solution and allows a few more records get cleaned before the cleaning solution needs to be replaced.
Thanks for the confirmation on the quieting. I'll have to look more carefully at the panel joints on my tank when I next empty it.
I strongly advise you to skip the fish tank filter and go with an inline water filter using a pump. It's a much more efficient solution and much easier to work with. I use a 1 micron filter in a setup that mirrors bbftx's design shown in this video:
I run the pump in between spindles of records being cleaning, not when cleaning. The pump bbftx used has been discountinued; but here are two alterntaives that several folks are finding good success with and these are fully self-contained so there are fewer parts to assemble and lower cost:
https://www.amazon.com/gp/product/B01G305PK0/
https://www.amazon.com/attwood-6126-7-Attwood-Potable-Water/dp/B0002F66WY/
I only degas before the start of a session. Since my filtering is done with an inline pump and the solution never has open air contact while filtering (e.g., it's not cascading from the hose through the air and then into the tank), I don't degas after filtering.
The alcohol serves it's own functions as a cleaning agent in the formula. 5-15% range of alcohol is a good range. I prefer keeping it in the 5-10% range.
"So let it be written. So shall it be done." Yul Brynner - The Ten Commandments
Thanks, Rushton. I'm actually mixing now. You reply is quite timely.
Well, I've cleaned 3 and played 1 with the new solution and 2 distilled water rinses using a hand-held vac system. You really do need 2 rinses before the foaming stops.
The LP I played was one that I had cleaned a year ago with Pfan-Stat before playing to see if the LP was worth keeping. (It came from another's collection) I wrote on the sleeve after listening 'hand cleaned 12/16. Still noisey.)
Tonight it sounded like virgin vinyl except for the dead wax. I mean I heard no surface noise at all when music was playing! I am amazed. I can't say too much about other changes in SQ, because I'd only listened to this LP once, a year ago; but I think there were a few more background singers this time around and I thoroughly enjoyed the music.
Many thanks to Guest110, Phantomrebel, ETLS, and all the other patient, experienced souls who helped me get it right, especially poor Rushton!
Today's cleaning discoveries:
1) This stuff is good for cleaning eyeglasses!
2) Triton-X-100 solidifies in the fridge.
3) The SQ improvements are not always really dramatic. I guess it depends on the LP and what it's contaminated with.
Questions:
1) Can you over-rinse after cleaning with the Triton/Hepa/Iso formula?
2) Are there other good uses for Triton X-100 around the home and what dilution? Not much info on the net.
Questions:
Can you post the exact mix amounts you are using? Maybe you have and I missed it. Slight warming, even microwaving, can reconstitute your Triton stock.
You cannot over-rinse in my experience. You can use Triton for almost anything you normally use detergent for. Concentrated dishsoaps are around 20% detergent so substitute accordingly. More useful is the Hepastat, which will sterilize all hard surfaces. There is a trend in the janitorial field to go towards these multi-quat solutions in place of bleach and other toxic cleaners.
If the formula for hand vac solution is 20% Hepastat, can I reduce or eliminate the Alcohol?
20% is WAY too high. Or are you talking about a stock solution?? Final working concentrations in the 0.1% quat range or less work well (hepastat concentrate is up to 20% quat). :crazy:
Oops! Decimal point in the wrong place.:confused:
For 500 ml of solution I used:
Hepa 1.0 ml/0.2%
Triton 1.4 ml/0.28%
ISO 25 ml/5%
The Triton was back to normal a few minutes after removing it from the fridge.
From my work at hospitals (where Hepastat is provided ready to use for all patient contact surfaces) I, um, acquired some sterile syringes for drawing up the reagents.
Status
