phantomrebel
Serial Tapist
That's useful info as it shows the lemon fresh product, while containing a detergent (alcohol ethoxylate) and EDTA, is not preferable due to high pH (over 12). It also shows the regular version, while neutral, is higher in quats than I estimated: the stock is ~5 to 13% (they give a range as unfortunately is typical). I would use this in a "working solution" at 1:500 dilution (final 0.01%-0.026%) along with a 1:1000 dilution or Triton (0.1%) or even 1:2000 of Triton if you can get away with it. That would be a safe starting point for the quat as we don't know what the inactive ingredients are or what end of the range they actually put out. As stated many times, beware the Triton is slow to dissolve so give it time or dissolve it in your ISO first.Sam's Club also has a lemon scent version that is a littler higher on the quat concentration and contains edta and alcohol. Not sure if it would be better?
https://www.samsclub.com/sams/image...fectant-cleaner-safety.pdf?mobiledetect=false
I also found the msds for the sanitizer on Sam's website. It's here: https://www.samsclub.com/sams/images/pdf/proforce-sanitizer-safety.pdf
If static remains an issue, the quat could later be increased 5-fold but I would hold off at first as they are plenty powerful and you don't want to leave a cloudy film or residues behind.
Hence, the amounts of detergent and quat in your recipe above are way too high.
The amounts I am giving assume you are rinsing well with distilled water.
How great that your first LPs are getting a healthy wash from the beginning! Hopefully you have some fresh sleeves to place them in. Let us know how your cleaning goes.
