Look at you Trek! Glad the alcohol helped.I only play a chemist on TV!![]()
AVfan: Interested to hear your impressions. I can't seem to find my files on the static experiment. I still have the surface DC voltmeter so I'll re-do the experiment (after the visiting family leaves town!).
WntRmute: There are differences in the detergents you listed. While they are all non-ionic, the average length and configuration of the non-polar "tails" (and hence the average molecular weight) varies. This effects the micelle size, critical concentration, and solubility. It's not something we need to worry about for our use, but in scientific or industrial applications, it matters as you want to select the perfect detergent for the task. As I mentioned previously, record grime is diverse, so we don't need to be so specific. We are concerned with solubility however, so choosing the lower Tergitols may make things easier to work with. I'm generalizing here, but the less soluble the detergent, the better it can be for removing certain oils. The more soluble, the better it rinses away. So some people do mixtures to cover the bases. I suggest you pick the one that is readily available and you find easy to work with. They all will do a good job cleaning your records.
