Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
First try with my Triton x-100 brew on a thrift shop Bowie album.
Used a paint pad and a diy vacuum wand on a converted lazy Susan.
Hopefully fewer scary monsters in the groves after this.
Hah, it's no Okki Nokki but you can buy hardware with the difference in price. I bet it worked out just fine.
I still haven't uploaded an updated spreadsheet for you guys. Life has been a bit nuts around here but I haven't forgotten. It's on the list! :confused:
Depends in what form the ingredients come in, I guess. For me, the quats come in pellets that take a long time to dissolve, even in warm water. The rest I mix in after the quats are fully dissolved. The Tergs are thick, syrupy liquids but dissolve readily, and the EDTA is a powder that also dissolves readily. It helps to shake the bejeezus out of it....
Everything is in liquid form except for the EDTA.
I use what was on the spreadsheet, so:
Triton X-100
Hepastat
EDTA
The mixture sat for a few days and the chunks were still hard as a rock. Not sure what's going wrong
It is very hard to get the Triton X-100 into solution. But I work in a chemistry lab and it is very easy for me. I use a magnetic spin /hot plate.
I put a beaker or flask with 90 ml's distilled water on the spin / hot plate, and bring up temperature to just under a boil. Then slowly add 10 ml of the Triton X-100. It does take a while and you have to add it slowly.
If you had to do it at home, I do it on your stove. But you will have to stirr constantly and add the Triton drop by drop. But if you make a 100 ml stock solution it shold be enough to last you far a lot of years.
So
Triton X-100 is a non-ionic detergent. It is neutral and has no anti-static effect. For that, you need to add a cationic detergent. Even after this addition, you should never skip the rinse step. A molecular layer of surfactant remains even after multiple deionized water rinses.
Thanks for answering my question. Here's a very late follow up:
What can I get that is a cationic detergent, available for an ordinary consumer (in Sweden)?
Is hepastat this?
Here's my mixture. Takes about 4 days from order to receipt.
So
Is hepastat this?
Hepastat has quats in it so it's got an antistatic effect. :)
Quats are really good disinfectants so it makes sense that they're in hepastat considering it's intended use.
So I've been trying to make the mixture that has been posted here multiple times and I keep getting hard clumps or chunks. Is there a proper order to adding the ingredients and is there anything I'm missing? I'm not sure if it's the EDTA (which I added last) or maybe I heard the Triton can be hard to mix. But this latest batch had real hard to break chunks in it that looked like maybe the EDTA. I did all the mixing at room temp FWIW
It is likely the EDTA. What form are you using? If it is the typical dihydrate, then it needs to be prepared separately in a solution where the pH is raised to ~8.0 with NaOH. The tetrahydrate is more soluble. I would recommend you skip the EDTA as it isn't really needed, unless you are following an enzymatic treatment or are having issues with mineral deposits. There should be NO precipitate or cloudiness in your record cleaning solution. Triton will disperse if you give it time, or you can mix it with a little isopropanol prior to adding it to the solution for instant dispersement. Triton may become cloudy if it is stored too cold but this goes away upon warming.
Is hepastat this?
There are many sources for quats referenced in this thread, Hepastat is just one of them. More and more consumer products are incorporating quats as a bleach substitute and as a biocide (particularly in the US since many of the anti-bacterials in use were recently banned). As mentioned many times, they are the main ingredient in hospital and food service cleaners, pool/fish tank algicides, antistatic treatments, hair conditioners, etc. so check around where such products are sold. Try to find a solution concentrated in quats with little else in the mix (look up the MSDS if they don't have ingredients listed on the bottle). Back in the day, they were incorporated into some plastic resin formulas used for records and they are still used to make anti-static sleeves. Unfortunately much of the art in plastic formulations and product handling has been forgotten or left out for cost-savings and a lot of new records today carry a big charge right out of the sleeve.
Thanks for your reply, phantomrebel! I've just found a pool anti algae product that might be interesting. The datasheet in Swedish says: "Polykvaternära ammoniumföreningar 2,5-10g/100 ml"
In English this should mean "quaternary ammonium compounds". If so, could I use this stuff as my quat in my cleaning solution? If so, how many ml should I put in a 1000ml batch of my finished solution?
Before you use it, do a search or call the company to find out which quat, and what other chemicals are in the product. Also inquire about the pH of the solution. Manufacturers always give a ridiculous % range (4 fold in this case) of ingredients as if that somehow protects their formulation. It's frustrating, but take the cautious route and assume the higher number, or 10% in this case. We like to use quats, depending on which one, at around 0.025% (or less) in our cleaning solutions, so that would be a 1:400 dilution or 2.5ml/1000ml batch. Again, this is merely conjecture: do not use it until you know what is in it.
For comparison, Hepastat is ~22% Quat with 6% non-ionic detergent, 3% EDTA, and 2.8% Ethanol (and other minor ingredients). At least a 1:1000 dilution is recommended which gets the quat to 0.022% (a 1:2000 dilution = 0.011% has been found to be effective as well). The non-ionic detergent gets diluted past it's critical micelle concentration at this dilution so we still add Triton or, better yet, Tergitols to the mix though Hepastat by itself can still clean records depending on their condition.
In the USA, manufacturers are required to post Material Safety Data Sheets. Not sure what you have in Sweden. Here's an example: https://facilities.ofa.ncsu.edu/files/2016/07/SDS_Hepastat-256.pdf
  • Like
Reactions: T68
The only substance named I can find in the datasheet-pdf for the product - and it's in English - is:
"Polymeric quaternary
ammonium chloride)".
Is this sufficient information?
Waiting for some quats I might as well use up my existing solution (tritonx-ipa-distilled water) on weekends thrift shop finds on my lazy Susan vac convert.
The Amazon link says tetrasodium EDTA. Is this not the right stuff?
https://www.amazon.com/dp/B01LVWMFL1/ref=cm_sw_r_cp_apa_i_R5YXCbQ9ADAMD
That seems like it is the correct stuff, but you should prepare a stock solution (concentrate) first then add the liquid as needed to your detergent mix. There is EDTA in Hepastat so you can leave it out if you are including that quat mix.
Cool. I had no Idea Hepastat had EDTA. Thanks for the help
Status
