What are the differences effected by the distinctions above?If you read that link more carefully and in context, it is about tanks with CIRCULATING fluids, not about tanks that have water that is standing still in the tank.
Enjoy,
Rich P
Enjoy,
Rich P
On a different note, the last batch of records that I cleaned came out quite noisy, something must have gone wrong.
I know you should not let enzyme dry on the record. Just in case it does, how can you remove dried enzyme (Nexazyme) from the record?
....Well, it seems that cetrimide is fine ( https://www.iasa-web.org/tc04/microgroove-cleaning-and-carrier-restoration ). But what about chlorexidine gluconate? I know it is used in mouthwashes... But is it good for vinyl?
It is OK, but I would include a DI water rinse afterwards. Cetrimide is popular in Europe, not so much so in the US. What dilution are you planning to use? I would suspect the product also contains isopropanol (alcole isopropilico)? You might get away with using this product by itself, no extra detergent required. Let us know how it works out.
Nice process. As long as this thread is, this may be the first time someone has checked cleaning a pop free first, as a sanity check, and reported on it. Well done.Thank you Phantomrebel. Last night I had the time to clean some records and try Cetrisan. I made 100 ml solution of demineralised water and cetrisan ( 3-4 ml) I also used demineraised water to rinse and... It all worked quite well. First I washed a record that didn't really need to be cleaned (and that I don't care about...), just to check if my liquid adds Pops and clicks rather than removing them... The result was fine. Then I recovered my copy of Genesis "Trespass" which I thought it was lost after a previous awkard atttempt to clean it... Well now it is almost completely silent and sounds very very good. Have a nice day.![]()
That's great. Glad to hear there is another option for folks in Europe.Thank you Phantomrebel. Last night I had the time to clean some records and try Cetrisan. I made 100 ml solution of demineralised water and cetrisan ( 3-4 ml) I also used demineraised water to rinse and... It all worked quite well. First I washed a record that didn't really need to be cleaned (and that I don't care about...), just to check if my liquid adds Pops and clicks rather than removing them... The result was fine. Then I recovered my copy of Genesis "Trespass" which I thought it was lost after a previous awkard atttempt to clean it... Well now it is almost completely silent and sounds very very good. Have a nice day.![]()
Is there a difference in the recommended formula for hand wash versus Ultrasonic cleaner formula?
I am also confused by the 10% stock initially recommended for the Triton x100 stock. I understand that is 100% concentrate so it needs to be diluted but I assume the Tergikleen is already diluted and just needs 10 - 20 drops (about 15 ml of surfactant). Can I just mix these measured volume percentages to an equal gallon and pour onto each vinyl record?
I’ve been reading the thread... let’s say 30% of it. Thanks for the amazing information and contribution.
So my base ingredients will be Triton X-100, ISO 99% and dH2O. I’m still trying to find Hepastat 256 in Canada... not easy.
I found 2 products at a distributor called Lalema: Polyquat 5 and Eko-quat.
What ingredients Im I looking for, and trying to avoid?
Thank for your help!
Question: isn’t Reverse osmosis at the Home level using a pre-carbon filter and a post carbon filter to remove organics? The one I have claims to reduce most of the organics to the 98.3% range were higher. I’m assuming the organic carbon are caught up in those carbon filters?
You are correct, but in the Reef Aquarium hobby we add the use of de-ionization filter media and get 0 TDS water for use in mixing the salt water for the tanks. Thus 0 TDS de-ionized water.
You can add a DI canister to any unit, but drinking DI water is not recommended long term. What I do is use a "Y" splitter and valves to bypass the DI if I want standard RO water. As an FYI those guys at AquaFX are great to talk to, have the parts you need and will be happy to walk you through the steps to set it up...Thank you. I know RO removes most TDS but I believe mine claims only in the 95% range. Where in the chain would a de-ion filter be best? Do you know if one is available for combined use with a home RO unit? Or if only for the aquarium hobby?
