How important is the rectifier tube in a Fisher X-202 as far a controling the sound? What is it's purpose? It is a GZ34/5AR4. Recommendations on what I should get...
So you think any good GZ34, NOS or New Production tubes are equal in what they do and doesn't do a thing to change the sound...The rectifier produces the plate voltage, which all of the tubes require to work. I don't get into the whole " rectifier sound" thing, but it needs to be in good working shape or things will not run properly. If its weak, the voltages will sag and stuff won't sound right. If yours tests good, I'd run it.
Opinions vary greatly on what to get, but I'm cheap so the last 3 5AR4's I've bought have all been the Sovtek ones. They seem to work OK in things that do not beat the snot out of them. SS rectifiers are an option, but if the voltages of the components aren't up to the task it can be a bad idea. Solid state rectifiers will switch on immediately, so there will be higher voltages available for a time than would normally be seen with a slow warmup 5AR4. Swapping those out can blow up coupling caps and power supply filters if they cannot deal with the increased voltage until the output tubes warm up.
The new ones blow up in applications that abuse them. Dyna ST-70 owners hate them, but those things have poorly designed power supplies that ask too much of the rectifier. In something that doesn't do that, they should hold up OK. I've got a pair in my Bogen 225, and one in my Fisher 600. The Fisher hasn't had many hours on it, but based on the power supply design in it and the Bogen, I expect those tubes ought to last a very long time. I also just can't bring myself to spend 100 bucks a pop on an old production rectifier tube. Even if an old production one does sound better, I doubt its 5x better than my sub-$20 Russian tube produces and its not likely to last 5x longer.
So does and old production rec sound better? I'm willing to spend a 100 bucks to keep my vintage sound and look original... I would be curious what the X-202 came with... No responce from the Fisher forum...
How important is the rectifier tube in a Fisher X-202 as far a controlling the sound? What is it's purpose? It is a GZ34/5AR4. Recommendations on what I should get...
It's more a realiability thing than about sound.
You can also buy a WZ34 Copper cap from Weber Speakers http://www.tedweber.com/catalogsearch/result/?q=copper+cap
8-pin Copper Cap. Replaces GZ34/5AR4. Vdrop: 17V @ Imax: 225ma
