cafe latte
Addicted Member
That would eliminate a lot, good idea.I’d hook meters up to the 2 power supplies and then watch the voltages for the first 20 minutes of run time.
Chris
The circuit around the reg's was supposed to help stabilize things, I had suggested a mod that eliminated the zener shunt ckt and subbed a series pass 9V monolithic IC regulator that worked well in the previous case. It's in a past thread in AK turntables somewhere.Non temperature compensated zener diodes maybe ?
Mr Relish
This is getting annoying. I found a suspect wire, fixed it no change, tested the Zeners all good. Tested much of the silicone, some in situ, others looked no good, then you go to the trouble to test out of circuit an all good.The circuit around the reg's was supposed to help stabilize things, I had suggested a mod that eliminated the zener shunt ckt and subbed a series pass 9V monolithic IC regulator that worked well in the previous case. It's in a past thread in AK turntables somewhere.
Besides the 200uF, is it obvious that the previous owner changed the values of the components? Sometimes the schematics do not get updated per changes the manufacturer has made.Wow what the previous owner doing!! C1 is supposed to be 0.22 UF 25v he has 0.47 100v
c4 not so bad 100uf 25v is substituted for the same with 100v
c5 is nuts 1uf 50v has been replaced with 10uf 160v!!!
c7 10uf 25v replaced with10uf 160v not ideal but ok I suppose
c12 100uf 25v replaced with same 100v, again ok
another curly one c19 1uf 50v replaced with 10uf 160v!!!
I dont think this is the issue but really not going to help!!
Need to see what caps I have, hopefully I can improve this.
Chris
The previous owner is a retired tv repair man so my guess it he replaced the caps with the closest he had. It is possible that he did not have any 1uf so he put 10uf as it is closest he had. I know he has not been well and his work is clearly been done since he became unwell as really a mess and I know he used to be very good indeed.Besides the 200uF, is it obvious that the previous owner changed the values of the components? Sometimes the schematics do not get updated per changes the manufacturer has made.
I wouldn't worry about the 2 x 100uF, 175uF is/was still within spec (20% tolerance)
Also, the values of the rest not critical especially if not in the signal path.
Best
Soundork
P.S. This thread raised my levels of concern with regards part obsolescence, so in the middle of the night I pulled the schematic for my DP-1200. Luckily, I could still find NOS parts on that auction site for it. Phew...![]()
It does not have an oscillator as not quartz locked.Does this model have a crystal for frequency control? Perhaps that’s wonky.
Hmm wonder though if the TA7061 ap is having issues?It does not have an oscillator as not quartz locked.
Chris
Thanks mate,I feel for you Chris! Correcting the corrections leads to a jungle for troubleshooting!
You’ll get it! You’re smart!
If you believe you can repair this table by try and error method, it is wrong! Simply look at schematic and measure. You should not replace parts if you are not sure they are bad. Blackened legs are nothing important and do not point to possible fault. I had the same issue with Technics SP-15. Do not remember what was wrong, it was long time ago, but something very simple. So find technician.Bringing this thread back to life a 3rd time. I have a Denon DP-1200 I bought from Japan that arrived with the infamous platter spinning like a bat-out-of-hell issue. De-oxit on all pots and switches. No joy.
On the speed control board, all caps have been replaced. The semiconductor has been replaced, and the blackened leg IC semiconductor has been replaced. Still no joy.
The turntable progresses to a speed from start-up to the point where the plinth is shaking. I also readjusted and cleaned the magnetic speed control head as it had clearly been tampered with. Going to replace the blackened-legged TR1,2 and 3 C458 with the BC549.
Is there ANYTHING ELSE I should be looking at? Other than the blackened legs, the board and parts look like they came off the assembly line a month ago. None of the old caps looked like they had been compromised. The ONLY thing I see wrong is the blackened legs on the C458 and the IC. What am I missing?
The last picture is the speed control board when I opened it up for the first time. The red circled all the parts I replaced and the yellow is the C458 locations that are next on the replacement agenda.
These days finding a good tech locally who works on TTs is quite troublesome.So find technician.
