As I said earlier in this thread, this is a common issue with the Rega's
https://forum.audiogon.com/discussions/hum-decreases-with-tonearm-position-huh
From thread above,
"The preamp is connected to the amps with W4S XLR interconnects. The TT to the Ray Samuels is via the dedicated cable on the P3. I've tried various interconnects from the phono pre to the preamp with no difference.
Here's the story:
There's a hum, which can be heard with the volume set even fairly low, at even low listening levels. But it is loudest when the tonearm is in its resting position, lessening as I move the arm toward the spindle.
I've tried moving the preamp away from the TT, but that doesn't change anything.
The hum isn't so loud as to interfere with listening to records, but it is loud enough to be very, very annoying when I'm, say, getting ready to spin a favorite platter. Or when I'vm flipping one over.
Any thoughts about what might be causing this? My cartridge is getting a bit long in the tooth -- I've been thinking about an upgrade -- but I don't see how that could be causing this. And I'm not really excited about dropping some real green on a new cart until I've got this hum thing resolved.
Is it odd -- it seems so to me -- that I've got hum with a battery-operated phono preamp?
Thanks so much for any help you might be able to give me with this."
And
"The motor on the Rega P3 may or may not be of low quality, but quality has nothing to do with the hum. The problem is that the glass platter affords no shielding against EMI emitted by the motor that may or may not interact with the cartridge. As someone else wrote, installing a shield will and did cure the problem. Another alternative is to ditch the glass platter in favor of a metal one that in itself will serve as an EMI shield."
And here
https://forums.stevehoffman.tv/thre...sues-with-rega-rp3-and-rp6-turntables.373883/
"One other thing to mention, is that the hum/buz
lowers as you move the tonearm from the resting position to the middle of the LP, and then as you get closer to the center (label of LP) it gets louder..."
If you search there are more like this, a lot more.
Athanasios
