nate, by "anchoring" you mean they're creating an enclosed space below, so the bottom end of the thing is anchored in a bottom plate? or are they using a strip of wood/material with a hole drilled in it? or? any link to a thread at lenco heaven?
I've seen it done both ways, but I can't find a photo of the most elegant solution that comes to mind, a cross-brace bar with an integral clamp that was affixed to the bottom-side of the plinth.
EDIT: Found a couple examples from our own mfrench, builder extraordinaire!
http://www.lencoheaven.net/forum/index.php?topic=1087.msg47422#msg47422
I highly recommend this tweak in building up an idler TT plinth.
Brett,
That REK has a thin top plate, and a bearing support system would go a long way in firming up the top plate. I've done two of them on two plinth builds now, and really like the results.
On my Presto T18 build, posted in Nates linked thread at LencoHeaven, I utilize an aluminum ring around the bearing housing. This ring pulls the bearing housing and top plate down onto the face of the plinth, which adds major rigidity, and kills any top plate flex. I also used a secondary layer of support, the aluminum cross bar, which is intended to support the base of the bearing housing cap. I used a gasket between the cap and housing to seal the lube into the housing. I didn't want the gasket to allow any flexibility to be introduced, so the al. cross bar pushes up against the bearing cap, adding rigidity to that end of the bearing housing.
On the deck that has the included image, above; That is a Bogen-Presto B51 that I converted from a light platter deck, to a dual platter deck. This took the platter load from maybe 4lbs to 17lbs. The original top plate was not designed to handle this load. So to support the upgraded bearing and platter load, I routed in a channel into the soapstone that accepts an aluminum cross bar that supports the bearing load. I could probably stand on the platter now, without introducing any top plate flex.
Ultimately, the reason behind these cross bars was two fold:
1) To eliminate top plate flex.
2) To dampen out vibrations and noise from the bearing into the plinth, rather than causing the platter to take it all in. It is a major mode to eliminate drivetrain noise.
Nate,
I was reading this thread, and when I came on that image, i did a head scratch, as it looked so familiar. Duh! It was mine.
Interesting how big of a difference it made. Was there any appreciable slippage at startup that the new idler corrected?
Yes, it really brought it into this century.
The old idler did not have any traction problems, but the new one does grip better with lighter pressure which helps make it quieter. Now that i think about it; it seems to have improve bass "weight". Could this be related?
I started drawing up plans for a new plinth over the weekend. My local lumber seller has 60" by 60" by 3/4 sheets of Baltic ply for $50. This will give me enough for the new plinth at half the cost I've seen elsewhere.
I custom-made a set of 2 cut-out templates that will allow me to leave as much support and mass under the deck as possible. There's two b/c the top-most layer needs to have a bigger opening than the lower layers to accommodate the hardware on the underside of the mounting plate. I'm also planning on drilling a tight-fitting hole in the base plinth for the main bearing to set in.
I also want to make the 'table match the dimentions of my other gear. Right now it's a 50 pound coffee-table sized behemoth. The new one will be able to join the main set-up and I can do away with the 50 foot cables.
If the templates work well, I'll make them available as PDFs. But that'll be a while from now.
Well done on getting the wheel retread. Too many people depend on the
sanding the wheel theory as some sort of a rehabilitive fix for a 40 to 60 year old rubber idler wheel. New rubber makes a huge difference, as you found out; same goes for the new motor mounts.
Ed Crockett is a good guy, and good choice. I've had three wheels OH'd by Ed. I also like Terry's Rubber Rollers - both great resources.
congrats on your efforts to this point!
Now that you've honed your skills with wood - try some stone!
