Thanks! And thanks for the arm. It was ready-to-go right out of the box.Super nice work!
Yeh, me too! I'm finding the ROK arm to be very microphonic. I might be able to make more audio samples this evening.Nice that you can enjoy the fruits of your labor,and how sweet it is!I will be very interested to know if you can get the noise floor inaudible.
It's there. I'm sure you'd hear it if you played it though your good system in a quiet room.That sounded good even on my P.C speakers.I can't say that I was able to hear any rumble.
I've been thinking about damping the underside of the platter with Dynamat. It does seem like it's currently radiating a lot of the motor noise. I'm concerned about over-damping though...or is that even possible?G'Day Brett. Do you have enough room to dampen under the platter with 2mm cork? I used this regular Thorens platter dampening technique on a BSR idler changer. This plus polishing the drive surface and freshening up the rubber on the idler wheel with it spun under some wet and dry 1200 made a difference.
Did you end up lubricating the bearing with grease or oil? What was the original lubricant used?
Starting the GL-75 project soon.
I love this thread.
So far, the only oil I've tried in the main bearing is standard, non-detergent 30 weight I had in the barn for the lawnmower. They originally spec'd the main bearing oil as some grade of motor oil, I forget which exactly.
