@SidSmith, can you post a picture of the bearing well and tell me more about the bearing design? Does the spindle have a ball on the end or is it flat? What is at the bottom of the bearing well? Does it use a set screw to hold a ball or thrust pad?
Russco used two different bearing designs. One used a ball at the end of the shaft and a ball set into a setscrew coming up from the bottom of the bearing well. The other design used the same bearing well design but had a flat bottomed spindle. Neither is a good design in my opinion, steel on steel is an efficient transmitter of vibration. Using a new setscrew of brass, I machined a pocket in the end of it and machined a Delrin plug to press in. Now the spindle, either with a ball or a flat bottom is spinning against a very slippery plastic and the Delrin being much less dense that steel acts as a barrier preventing most of the vibration from passing through.
I had been tossing this idea around in my head, lot's of empty room in there, and made a few up. Andy was the first to test it and he was surprised at the improvement.
BillWojo
