One can just do a search for Derlin or HPDE plastic balls, but there’s specific suppliers:Where did you locate the HPDE balls?
No problem Bill…Thank you.
Question. In the manual parts list and on some pics of the B-12, there is a wire connected from the motor bottom and a bracket beside it. On mine, the tabs are there but no wire. I connected a wire with alligator clips, seems to do nothing. Should I go ahead and solder a wire in, anyway?
I'm still getting a little crackle when I touch the headshell.Interesting, your B12 has the same wire issue mine has if I’m looking at your picture correctly, one of the indicator light wires is severed/broken. Coincidence?
I think my table has this ground wire you’re referencing, I’ll see if I took a picture or if there’s any proof on the table, but it’s in a state of disassembly so I can only show you the wire taken off unless I sometime took a picture before it was disassembled.
That's the same pic I posted. Here is the only pics with the parts list and service info I've found. Scroll down a little. https://audiokarma.org/forums/index.php?threads/rek-o-kut-turntables-rok.146608/page-2Found a picture! You have to zoom in but it’s there. Can’t say the impact of it being there vs not.
Do you have a link to the manual parts list for the B12H? I’m searching for it but can only find reference to the vinyl engine file and they’re not accepting new users to log in. I thought there might be one uploaded to this thread but it’s evading me.
Finally rewired the tonearm. Looks very nice with the new wiring. Now all I have to do is make new interconnects.
It is the same for my table.No matter how many times (maybe 6-8 times) I adjust the speed fine tune to sound correct, if the table sits for a while it runs slow and it takes several minutes to start moving to correct speed. I assume it's as the motor warms up.
