SidSmith
Good to hear regarding your capstan. I agree with you about mechanism driven turntables... I'm just trying to have it engage at all 3 speeds. I'll look into to dealing with the capstan and report back.
Thanks for your response
I recommend you to adjust precisely the height of the washers that supporting the idler wheel. The adjustment need to be precise because the motor pulley steps are not tall enough to allow room for adjustment. In my case, I wanted to used use PTFE washer exclusively for that task, and was limited by their thickness.
It is strange that Rek O Kut didn't design the B12 to make full contact with the motor pulley at 78 RPM. Using for a long time exclusively this speed will use unevenly the elastomer portion of the idler wheel, degrading the noise performance of turntable.
